Author Topic: New Search Engine  (Read 6372 times)
Offline rknize
    • metaruss
New Search Engine
« on: Wed, 10 July 2013, 14:32:33 »
GeekHack is far too large for SMF's normal search indexer to cope with.  This problem has been on my back burner for a while.  We now have Sphinx up and running, which is not only much faster but should produce results with greater quality.  For example, you can use search terms with less than 3 characters.
Let me know if there are any issues.
Russ
Re: New Search Engine
« Reply #1 on: Wed, 10 July 2013, 14:33:32 »
Woot!! This is so awesome....now to try it out.... ;)
« Last Edit: Wed, 10 July 2013, 15:21:35 by SpAmRaY »
Offline Tym
« Reply #2 on: Wed, 10 July 2013, 14:38:38 »
Thank Christ, good work lads, thank you!
« Reply #3 on: Wed, 10 July 2013, 15:13:31 »
Assuming it is accessed from the search field in the upper right corner of the main page, I searched for "model m keycaps" (without quotes) and got this error:
Each word must be at least two characters long.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #4 on: Wed, 10 July 2013, 15:15:02 »
well, 2 is less than 3  :)
Filco w/ Imsto thick PBT
« Reply #5 on: Wed, 10 July 2013, 17:19:27 »
1 is also less than three ;)
Offline CommunistWitchDr
  • >implying keyboards
« Reply #6 on: Wed, 10 July 2013, 17:30:36 »
Now searching for all posts containing phrases "a" or "e" or "i" or "o" or "u".
« Reply #7 on: Wed, 10 July 2013, 17:35:28 »
Ok, so I searched for: "model m" keycaps
(quotes around "model m", no quote around keycaps, thinking that it might search for posts containing those two phrases, but ...
Offline alaricljs
« Reply #8 on: Wed, 10 July 2013, 19:25:33 »
You tricked it!
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #9 on: Wed, 10 July 2013, 23:44:59 »
in theory, the query "model m" AND keycaps should work.
the query language documentation is here: http://sphinxsearch.com/docs/current.html#searching
however, to get this working, rknize had to rip out the smf search engine and glue in the sphinx backend, so consider this still to be a beta feature. however, the changeover to sphinx has been planned for a long time (a year, basically), so this is not in any way experimental. report bugs to the massive bug report thread (rknize has a possible method for that madness in the works as well, by the way).
Offline rknize
    • metaruss
« Reply #10 on: Thu, 11 July 2013, 00:25:23 »
I have it setup for extended syntax:
http://sphinxsearch.com/docs/current.html#extended-syntax
It seems like the phrase operator (quotes) don't work as expected.  I'll look into this.  Perhaps SMF is stripping the quotes.
Russ
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #11 on: Thu, 11 July 2013, 17:30:23 »
Hmmm the syntax is similar to a combination of Concordance, dtSearch, and Lucene if anyone has worked in the legal industry like i do.
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #12 on: Thu, 11 July 2013, 17:42:21 »
regex plz
