Author Topic: Which one: FC660M vs Minila vs Poker 2?  (Read 5225 times)
Offline 3doog
« on: Fri, 12 July 2013, 11:28:40 »
So I am looking to get a compact keyboard. Arrow keys are quite important for me. I primarily use a Mac. Currently I am looking at 3 keyboards: FC660M, Filco Minila and Poker 2. Poker 2 looks the best to me but I am a bit worry about how usable the fn and arrow key will be. Any recommendation or comments on the 3 keyboard?
I will be traveling to Japan at the end of this month and think I might pick up a keyboard there since it might be cheaper than buying it in my country(Thailand). Does anybody know where I could get these keyboard? I know that Yodobashi camera has Filcos because the last time I went, I found them there, but don't remember seeing the other two. If it's hard to find I might just buy from qtan.
WASD Keyboard V1
Re: Which one: FC660M vs Minila vs Poker 2?
« Reply #1 on: Fri, 12 July 2013, 12:41:44 »
Do you want to be able to easily replace the key caps?  If so, the Poker is the best option of the ones you mentioned.  There are also keyboards like the Keycool 84 and KBT Race that keep an arrow cluster while being a smaller footprint and, at least I'm pretty sure on this, more standard key cap sizing.
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #2 on: Fri, 12 July 2013, 14:32:22 »
My vote is for the 660M. I love my 660C and the layout is far superior to the other compact boards imo. The only things I use my function row for is Del, Arrows, and ~. The 660M has two of those three available as dedicated keys already, while maintaining a 60% footprint.
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline TimIsABat
  • MX Clears are life
    • Instagram
« Reply #3 on: Fri, 12 July 2013, 16:36:47 »
I have both the Poker X and the FC660M. The keycaps for the FC660M take some getting used to if your not used to using small keycaps that are almost flat. Otherwise it is a solid board. The Poker II and X are great for customization, and i personally like the format better than the fc660m, because the keys aren't as small. The arrow keys are a plus with the FC660M but honestly, pressing Fn+Spacebar isn't too much of a hassle. The Poker II even uses the WASD keys instead of right shift, alt, and control. Personally I like the lightness of the Poker X because I am planning to bring it around campus. You really have to get used to the small form factor though. The keys feel kinda squished at first but you get used to it.
The most ideal thing though would be to get a GH-60 because it is just always better to build your own thang.
Leopold FC660M MX Reds | Poker X 62g  Ergoclear modded and plate modded (out of comission) | IBM Model M 1391401 | Dell AT101 | Compaq RT101 | HHKB Pro 2 | WASD CODE TKL MX Clears
Avid vape collector and advocate. I used to work at to renowned vape shops here in New Jersey. Message me for any vape related questions.
Main driver : WASD CODE TKL MX Clear
Offline meiosis
  • Time
« Reply #4 on: Fri, 12 July 2013, 16:43:55 »
Poker II enjoy your feeling.
I'd say no on Minila, but FC660M and PokerII are solid boards, depends on your preference in layout
Keyboards:
Aripeko TKL
Offline Hypersphere
« Reply #5 on: Fri, 12 July 2013, 17:18:34 »
If you are primarily a Mac user, you might want to look at a Mac-centric compact board like the Matias Mini Tactile Pro, which has both arrow keys and F-keys. If you use arrow keys a great deal and want them on the primary layer, then the Poker II is out. The Minila is interesting, but it has a number of non-standard features that might make it frustrating to use; you might want to look at the Tex Beetle instead. The Leopold FC660M has dedicated arrow keys and, with the exception of the bottom row, a standard layout. However, if you use F-keys in conjunction with others (as in programs like Photoshop), you might want to go with a TKL board, so that you would have everything standard except the Num Pad. Some TKLs even have an embedded NumPad, such as the IBM Model M SSK and the Realforce 87u. If you have to choose among the 3 boards you listed, I would recommend the FC660M.
« Last Edit: Fri, 12 July 2013, 17:24:29 by rjrich »
Offline 3doog
« Reply #6 on: Mon, 15 July 2013, 09:26:03 »
So I just went ahead and ordered a FC660M with red from qtan.
Thanks for the advise!
WASD Keyboard V1
Offline TimIsABat
    • Instagram
« Reply #7 on: Mon, 15 July 2013, 16:09:09 »
Enjoy like I did. Just be patient to get any customization done to the board.
Offline Lastpilot
  • Power stance
« Reply #8 on: Mon, 15 July 2013, 16:11:39 »
As a photoshop user and previous Poker owner, I would say that rjrich has it spot on.
Function layer is also important for my other hobby: mmorpgs!
