Author Topic: [IC] Vortex Filco Case Universal/Phantom Plate Adapters (should fit QFR too)  (Read 13915 times)
Offline Leslieann
These would allow you to run flat/universal plates in the Vortex Filco case.
If you already have a QFR in a Vortex case, this should work with it as well.
Currently I'm testing and revising, I made small samples to get the right measurements and they seem to fit good. I'll be desoldering the switches on mine this weekend to change the plate and make sure everything fits how I want. Unfortunately, you will still have to desolder all your switches to swap the plate, there's nothing I can do about that.
I have no idea what they are worth to people, but I think I can get the adapters made and shipped (to the US and EU) for about $15 or less. This won't be a group buy as I can simply make them on an as needed basis, I'm just trying to see if there's any interest before I get too crazy into making them easy to use, and how precision they are.
Update: They work.
Looks stock from the outside. (Note: Case is being stripped for paint)
Please note that these are not just flat strips, they have a (.5mm) lip on them and are designed to hold themselves in place (yes, they need to be that precise).
They are made in multiple parts for several reasons, but trust me, it makes sense from a design and shipping standpoint. You need 9 parts, but I would include 10 to cover bad parts, breakage, etc..
« Last Edit: Sat, 13 July 2013, 19:37:58 by Leslieann »
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline BliTzKiN
Re: [IC] Vortex Filco Case Universal plate adapters (should fit QFR too)
« Reply #1 on: Sat, 13 July 2013, 11:12:41 »
Let me get this straight. So you're making a backplate for Filco, Vortex and maybe QFR cases? If so I might be interested.
Offline Photoelectric
« Reply #2 on: Sat, 13 July 2013, 11:15:12 »
She is gathering interest for plate support / plate adapters for Vortex-made aluminum cases, which are made to fit Filcos and QFRs and similar.  Not for backplates for proprietary cases.
Offline Leslieann
« Reply #3 on: Sat, 13 July 2013, 16:04:49 »
Photoelectric is correct.
Universal plate group buys are common, the problem is that they cannot be used with the Vortex case.
Here is WhiteFireDragon's picture showing the problem...
The bottom plate is the stock Filco, you can clearly see the bent edges, the Vortex case uses those edges to clamp the plate in place.
The top plate shown is a flat universal plate, which lacks the bent edges, and therefore unusable in the Vortex case without some sort of adapter. It's for the adapter that I'm trying to gauge interest.
Photo by WhiteFireDragon, from here.
« Last Edit: Sat, 13 July 2013, 16:08:10 by Leslieann »
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline pasph
« Reply #4 on: Sat, 13 July 2013, 16:29:44 »
Great idea to adapt also the Phantom to Vortex case
Offline Leslieann
« Reply #5 on: Sat, 13 July 2013, 19:36:06 »
Updated first post.
They work, and pics included.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline WhiteFireDragon
    • youtube
So you got your 3d printer working now. I'll grab a set of these when you make them available.
I don't see a huge interest on these though. It eliminates everyone that doesn't have a Vortex case AND custom plate.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
Interested.
Offline Leslieann
I didn't expect a lot, which is why I went with an interest check first, however, this may spur some fresh interest in the case and plates.
The plastic shrank a bit when making these, I didn't compensate on purpose, as such, they fit a tad loose but worked great regardless. I want to run a second set with compensation for shrinkage before I call them done. I should have some ready to ship early or later this week.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline SeriouSSpotS
  • 60% is love, 60% is life
Looks very interesting
I wish I had a blue or red Vortex case to fit these into =/
Offline t2russo
In for two sets if you do it.
Offline ___q
I thought the stock QFR plate already had the right angles on the edges like the Filco does?
Offline Leslieann
I think it does, but this is about NOT using the stock plate. So a QFR owner could use these and a universal plate to mount a QFR into the Vortex case.
Theoretically, this opens up a bunch of boards to be used.
Since it no longer relies on the plate for mounting, any other TKL board with the right measurements could now be used. For example, if a Ducky TKL PCB was similar in size to the Filco PCB, a universal plate and adapters would allow for a Ducky to fit the Vortex. This could get interesting.
« Last Edit: Sun, 14 July 2013, 15:46:00 by Leslieann »
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline ___q
Ahh, ok.  I misread the original comment as "this will work if you use a filco with a custom plate, as well as if you use a (stock) QFR", hence the confusion.
Thanks for the clarification!
« Last Edit: Sun, 14 July 2013, 16:04:22 by ___q »
Offline meiosis
  • Time
Will this keep out humidity from reaching the pcb? (airtight)?
Keyboards:
Aripeko TKL
Offline Leslieann
You can't make it airtight as your keys would create pressure when you pressed them, also, there's no way to realistically make it airtight even if you wanted to. The sides of the case would bow under any sort of serious sealing, then there is the fact that the cord exits out the back is through a gaping hole, and of course you have the keys themselves which have to move.
Is there a reason you want it sealed?
Mmmmm fresh paint... (Evo potato cam)
Oh, and while the block off plate (awesomely) snaps into place and looks okay from this angle, it's not quite ready for prime time.
« Last Edit: Mon, 15 July 2013, 04:49:36 by Leslieann »
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline Leslieann
Closed
Moving to production soon.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline Leslieann
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
