Author Topic: SP ABS Color Ring Scans  (Read 278779 times)
Offline Dianoda
Re: SP ABS Color Ring Scans
« Reply #100 on: Tue, 06 August 2013, 10:06:51 »
The only picture I can safely calibrate is the one Dianoda took.
Well, then shouldn't we just use his scans? If his are more accurate, then let's go with his scans.
we don't have the full color ring though
So, Dianoda hasn't photographed the rest of the PBT ring? Meh, I don't see the point in cropping out the chips if Dianoda's are going to represent the color more accurately. I guess we can wait until he's done.
I just have the ABS chips - no PBT.  For the ABS, I still need to shoot the gray chips - I was planning to take and upload these tonight (I've been out of town for the past week, just got back on Sun evening).  I'll probably reshoot the color chips at the same time as a comparison point to the last shoot - I'll be using the same lighting setup as before, just want to be sure that I am eliminating potential variables that I should be able to control (such as possible variations in metering and light output/color temperature of my strobes).
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #101 on: Tue, 06 August 2013, 10:13:37 »
i have to lend dianoda my pbt ring still. i might as well lend him the PC ring while i'm at it.
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #102 on: Tue, 06 August 2013, 10:19:19 »
I'm trying to figure out why the PBT scans seem so overexposed. Maybe it's because I used more chips for the ABS scans, and it cut down on the light? Same scanner, same settings -- why such a difference?  :(
I think I'll rescan the ABS as well, just to get a second (third, with Dianoda's) set of values, and better scans for better crop-outs.
I wonder how the polycarb will look -- that's translucent, yes?
Quote from: Samuel Adams
Offline mkawa
« Reply #103 on: Tue, 06 August 2013, 10:22:09 »
it's trying to expose for middle gray, like any other exposure meter. so it takes a quick snapshot of reflectivity and computes an amount of light that will make the mean of the luminosities middle gray.
in short, scan the dark stuff separately from the light stuff.
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #104 on: Tue, 06 August 2013, 10:38:52 »
(YEEEEEEEEEEEEEARRRRRRRRRRRRGHHHHHHHHHHHHHHH!!!!!!!!!!) (TIE fighter screeches over Krog's head)
 :D
I put the tiles on the scanner bed!  :D  LOL
Offline Dianoda
« Reply #105 on: Tue, 06 August 2013, 23:16:08 »
Ok, finished the reshoot of the ABS color chips and did the gray ABS chips as well.  Both images were shot using identical everything - same camera settings, same lighting setup from the same position, same post-processing steps, etc.  Here are links to the color corrected JPEGs (each JPEG file is about 12MB, btw):
http://dianoda.minus.com/muyOgFJnwJ8hW
The RAW files can be found on dropbox.
Offline Dianoda
« Reply #106 on: Tue, 06 August 2013, 23:24:36 »
Oh, mkawa, just noticed your post asking about the color checker passport/i1 display pro - I bought the color checker stand alone, so no i1 for for me.  I use a spyder3 elite w/ argyllCMS+dispcalGUI for my screen calibrations, which I'm pretty happy with (the argyllCMS+dispcalGUI software is quite a bit more in depth than spyder's own software).  The color checker passport is great for studio work.
Offline jil_jil32
  • Tokyo Press <3
« Reply #107 on: Wed, 07 August 2013, 04:09:51 »
It would be great if someone can send Dianoda those missing chips... ^~^
Offline mkawa
« Reply #108 on: Wed, 07 August 2013, 09:56:38 »
hah. i bought the i1 without the passport. i suspect if we combine forces, we could be _unstoppable_...
Offline ijprest
« Reply #109 on: Fri, 18 October 2013, 15:54:18 »
Just FYI:  Not sure how the scanning has progressed, but I've got a access to a ColorMunki spectrophotometer at work, if you wanted another set of calibrated samples.
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #110 on: Fri, 18 October 2013, 17:16:29 »
PM me with your address, and I'll send out the color chips (ABS) that Mashby sent to me a few months back. That work for everyone?
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #111 on: Fri, 18 October 2013, 18:09:07 »
Works for me.
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #112 on: Mon, 21 October 2013, 11:42:37 »
Works for me.
Package deployed.
Offline ijprest
« Reply #113 on: Thu, 24 October 2013, 21:39:48 »
Got the package tonight, and borrowed the ColorMunki from work.  The scanning is actually going pretty quickly... did about 60 (roughly half) of the PBT chips over a couple hours, and I think I've got the process down pat.  Given the pace I'm going at, I should be able to get them all scanned over the weekend.
I'm sampling the chips from the smooth part... away from any texture or writing that might throw off the sample.  I'll do each chip five times, and average out the data.  The ColorMunki gives me raw data (samples of wavelengths from 380nm -> 730nm at 10nm intervals), as well as L*a*b* values.  I should be able to calculate sRGB values without any trouble.
Offline codyeatworld
« Reply #114 on: Thu, 24 October 2013, 21:42:38 »
Just gonna say I've been using these scans for the recent group buys, and thanks a lot for doing this.
Offline ijprest
« Reply #115 on: Fri, 25 October 2013, 22:05:39 »
OK, I've scanned all the PBT chips... went pretty quick.
Of course, I've also added the colors to my online Keyboard Layout Editor.
I'll move on to the ABS chips tomorrow.
Offline Photoelectric
« Reply #116 on: Fri, 25 October 2013, 22:36:22 »
Kroengar, if you do own any IMSTO white / beige PBT sets at some point, it'd be great if you could compare them to the ABS and PBT whites and beiges/grays to find the closest matches.  Mostly because IMSTO's sets only come in ANSI layouts, and I've been looking at KeycapsDirect for blank 1.5x, 1x caps and 7x spacebars.  There are many off-whites that look *similar* but even with color scans, it's uncertain which is the closest.  Would be best to have a color sample ring on hand to compare directly.
(For example, I ordered 4 1.5x modifiers in WFJ "white" PBT, and WFJ has been described as crisp clean white.  Upon arrival, I can see that it's in fact quite a bit creamier / more yellow than white Vortex caps and more cream than pure white PBT used for ZOMG dyesub caps (I thought those were WFJ, as well as that's what Portal dye sub caps used)--perhaps SP sent me wrong caps, I don't know.
P.S.: Well, as I was writing this, I've realized that indeed, my supposed WFJ modifiers are not correct, next to WFJ ZOMG dye sub caps, so I've sent an e-mail to SP customer service :) )
« Last Edit: Fri, 25 October 2013, 22:49:20 by Photoelectric »
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #117 on: Sat, 26 October 2013, 05:45:37 »
No, I don't own any IMSTO anything, unfortunately. Many people have pointed out that the color rings from SP do differ over time. I encounter the same sort of thing in my business, where I use dyed rolls of fabric. The color is slightly different between "dye lots" and so I've got to keep all my sewing work within the same roll to keep it all consistent. SP mixes their colors, so we'll never be able to make perfect matches. But if people can come reasonably close that's good enough for us.
Quote from: Photo
Yeah, so now you know from experience.  :( Think of this, though -- if the GH community can provide good, color-corrected scans of the various chips and materials, then it's easier (and more likely) that vendors will specify (or be asked to specify) what color chips they're using. But also, from what I have heard, SP will custom mix colors. So maybe the vendor said, "gimme WFJ with a dash of yellow, please."? The colors I find most interesting on the color rings so far have been YCC (soft yellow), YCA (translucent yellow) and RCU (eraser salmon). I feel like no one has done much with them. There's also a bewildering array of grays, LOL!
A tremendous thanks to ijprest, who is exactly the right kind of scientist (it's color science people, that's not a joke), computer scientist and keyboard aficionado. When these scans get into emulators and prototyping software, etc. -- like ijprest's -- then all kinds of awesome will happen. I'm hoping kaporkle, or someone with his skills, will arrive and make accurate rendering of new keycap colorways easier and faster.
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #118 on: Sat, 26 October 2013, 05:58:51 »
Note that these colors will only be accurate if your monitor and/or graphics software is calibrated properly to display sRGB colors.
That's awesome work! Checked out the PBT color scans on your editor, and yes, you should definitely calibrate your monitor if it's possible.
Offline ijprest
« Reply #119 on: Sat, 26 October 2013, 12:35:34 »
Yeah... color-management is hard.
My monitor has an sRGB-mode, which makes a big difference.  I compared a few chips against the on-screen values, and they're reasonably close when I switch my monitor to sRGB... I chalk up the minor differences to my ****ty CFL lighting.  There's a reason the pros use monitor hoods!
But while I've got the ColorMunki here, I might try my hand at creating an ICC profile for my monitor and see if it gets even better.  :)
Offline korrelate
  • iubeo stultum esse libenter
« Reply #120 on: Sat, 26 October 2013, 16:54:31 »
Krogenar, you closet socialist: thank you for this link! I don't have to ask that many questions out here because every time I search for something somebody like you has already posted the answer. You rock!
Topre REALFORCE
Offline bpiphany
« Reply #121 on: Sun, 27 October 2013, 04:01:07 »
[ Specified attachment is not available ]I had some scans uploaded at one point. I think they disappeared in the big file cleanse, and somehow I had deleted my copies as well =P So I scanned them again for fun... These are the ones I've got.
ABS
41140-1
PBT
41144-2
« Last Edit: Sun, 27 October 2013, 04:58:01 by bpiphany »
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #122 on: Sun, 27 October 2013, 09:31:53 »
You're welcome! Be sure to thank all the other people who did the majority of the heavy lifting. mkawa, Dianoda, ijprest, and more. I started the thread, and then things got very quickly over my head in terms of technical sophistication.  :) Thank you bpiphany for the additional scans.
Offline ijprest
« Reply #123 on: Sun, 27 October 2013, 23:24:30 »
I managed to scan all the ABS chips tonight... tomorrow night I'll double-check the data (e.g., make sure I typed the color-code correctly) and then post it online.
Offline ijprest
« Reply #124 on: Mon, 28 October 2013, 19:05:44 »
OK, here's the ABS data (and links to the PBT data again, for good measure... though it hasn't changed).
Edit: I found & fixed a couple places where I had transposed a couple characters in the color-names, and one instance where I had mis-read an 'L' as a 'C'.  Plus, I discovered that we have two VBQ chips. :)
« Last Edit: Mon, 28 October 2013, 20:09:11 by ijprest »
Offline ijprest
« Reply #125 on: Mon, 28 October 2013, 20:24:12 »
P.S., I'm not sure how accurate the YCA (glow-in-the-dark) samples are.  It was glowing for a few seconds after each sample I took.  :)
Offline korrelate
« Reply #126 on: Wed, 30 October 2013, 11:14:46 »
Roger that!
mkawa, you know I already love you (and your heart stickers) so of course, of course: many thanks!!
Dianoda, ijprest, et al.: big thanks to all of you as well. I haven't had a chance to interact with any of you yet, but I'm sure that will happen sooner or later.
And to all:
Thanks for being interested in the things that you're interested in and thanks for sharing the info! You guys all make me very glad I decided to join this forum. Feel that? That's good karma being sent your way!!
Topre REALFORCE
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #127 on: Wed, 30 October 2013, 13:25:54 »
Ok, I'm working on getting some of these scans cropped out so they can be used. I've figured out a way to crop them with rounded corners, so they look a bit more like the tiles. Now, if only I can figure out how to tag each one with some of this new data. Here's what some of the new cropped jpeg will look:
41743-0
Offline ijprest
« Reply #128 on: Wed, 30 October 2013, 15:01:37 »
What sort of tagging were you considering?  Something to allow for programmatic access?
Putting stuff into the image metadata is an option.  The Exif metadata format supports lots of different bits of metadata, and PropertyTagExifMakerNote or PropertyTagExifUserComment fields can be used for just about anything, if none of the other fields make sense.
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #129 on: Thu, 31 October 2013, 08:39:47 »
Hrm... I hadn't actually thought about using IPTC or EXIF to put the data right into the file itself.
I was thinking something more like this:
41942-0
Putting that information in the metadata of the file would be awesome. I'm trying to think in terms of what would be most useful to someone designing a color scheme, or putting together a groupbuy. Ultimately, if someone could use this information to create better CG renderings, that would also be fantastic. I had also pictured a PS or Illustrator swatch that could be loaded while designing, so people could have a palette of ABS chip colors to choose from. Again, we can't mention the profiled monitor caveat often enough!
Your integration of the swatches into your colorscheme designer is looking awesome. How difficult would it be to have the swatches (the cropped photos) appear in the design window? I'll kludge something together to show you what I mean.
« Last Edit: Thu, 31 October 2013, 08:48:42 by Krogenar »
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #130 on: Thu, 31 October 2013, 08:55:04 »
I'm finally giving this thread some needed attention. OP updated.
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #131 on: Thu, 31 October 2013, 09:15:09 »
For the purposes of this discussion, we'll be using the "Straight Up House Tully" color scheme. *ahem*  :rolleyes:
Here's the editor right now:
41944-0
Could we do something like this? When I hover over your palette, the tooltips indicate which color chips have been used. But after I select them, I really need to take notes -- if I don't recall what I used, I have to select a few until I find what I had used. It would be so useful if whatever colors I did select from a color chip gamut, showed up somehow. Please don't take this is as a harsh criticism at all -- I feel a bit like you managed to levitate the Statue of Liberty and now I'm asking you to do it a little bit higher, as I still cannot see entirely up her toga. Here's my kludged screenshot:
41946-1
What do you think? Possible? I would love to see more designers using the tool you made, and then being able to output some view that shows all the basic information, screenshot it, and then post it. Most of the GB's out there end up with a screenshot(s) on the OP that give people all the basic info on the color scheme -- if your tool could make that easier to output, that would be great.
Also, Santa, what about an online color chip "ring", that users could use to rifle through the chips, select some to "pull out" and then it would use the higher-res images? Also, I want a Red Ryder bb gun and I totally won't shoot my eye out.
« Last Edit: Thu, 31 October 2013, 09:17:54 by Krogenar »
Offline ijprest
« Reply #132 on: Thu, 31 October 2013, 18:55:37 »
Heh... that's some vivid imagery.  :)
Something like this is certainly possible... it's a question of best presenting the data in the UI, and having a workflow that makes sense and is easy to use.    (And fits in with the other features I have planned.)  One consideration is that you could (theoretically) use different colors on each keycap... so presenting the information in a useful way becomes tricky.
A few ideas:
1. To solve the "I don't remember what color I picked" issue, I could just highlight the current color in the palette (sort of like matt3o's color-scheme picker draws a thick border around the current selection).
2. I plan to implement (at some point) the concept of named keycap prototypes that specify various attributes.  You could have a "alphas" prototype and a "mods" prototype (or whatever; system would be flexible), apply the prototypes to the correct keys, then *quickly* test color schemes, etc., just by changing the colors on the prototype caps.  I'm not sure exactly what the UI will look like, yet, but I've been thinking about something like this mockup:
42012-0
... so another possibility would be to show the scanned chips beside each prototype in the list.
3. Another thing I plan to implement is the ability to add text- or image-based notes/decals to the layout...
-- Lots of uses for this... logos, depicting LED clusters, labelling "row number" information, etc.
-- This idea could be easily extended to allow "color swatch" decals.
-- This would be best (IMO) for taking screenshots to use in GB posts.
Offline ijprest
« Reply #133 on: Mon, 03 February 2014, 20:21:54 »
P.S., There was no NN (black) chip on the chain, but I ordered a blank NN-colored key from SP and scanned it in... the spreadsheets and such that I linked above have been updated.
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #134 on: Tue, 04 February 2014, 06:57:20 »
A few ideas:
That would work -- this is really a great tool you've made.
It sounds like CSS for keycap color schemes! (Inheritance, etc.) -- I think that's a great idea. Matteo's tool does this already -- alphas vs. mods, but over time I've realized that schemes also play with other color "models" -- alternating function row cluster colors, does the tab key get the mod color, or the alpha color? Being able to select/create a grouping of keys would be pretty awesome.
Quote from: ijprest
Do you think you could put together a way of creating an online (or software-based) color chip keyring?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #135 on: Fri, 14 February 2014, 07:16:09 »
I don't remember if we already talked about this. But colors are not constant, they slightly change between batches. So what they today call VAT might be different from VAT a year from now.
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #136 on: Fri, 14 February 2014, 18:32:08 »
Yes, that's been pointed out many times. Also, monitors have different temperatures, too -- so even if everything were perfectly calibrated, it wouldn't be 100% accurate. You could make the argument that SP shouldn't even sell color chips for the same reason -- they'll be different eventually from what you've get. And yet, people still buy the color rings.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #137 on: Sat, 15 February 2014, 01:11:16 »
I mean that... just don't go paranoid about calibration a perfect rgb convertion because it won't last :)
Offline Dianoda
« Reply #138 on: Thu, 27 February 2014, 19:51:35 »
So... I imaged the SP PBT and polycarb rings this evening, RAW files can be found on the GH dropbox, here are the jpegs (sRGB colorspace):
http://min.us/muyOgFJnwJ8hW
Offline jacobolus
« Reply #139 on: Wed, 05 March 2014, 06:34:50 »
Oh, holy ****, this is awesome. Somehow I didn’t realize that these color chips had been measured with a spectrophotometer. Thanks so much. Yay data to play with.
Why is this in the “post wiki workshop” section?
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #140 on: Wed, 05 March 2014, 07:06:50 »
Thanks Dianoda! I need to get to work on cropping these things out. My hope was to crop out rounded sections, to match the actual chips, but it's ... well, very tedious. Anyway, thanks for the scans Dianoda!
Where should it be, if not here? The working plan has been that since the wiki code requires too great a learning curve, that all the information we compile would be in this forum, until a more long-term solution is found. Glad the scans helped you!
Offline Azteca
« Reply #141 on: Wed, 26 March 2014, 18:01:34 »
Great work  :thumb:
Any chance someone knows the PBT color used in darker Realforce keyboards, and better if someone knows the ABS color equivalent (or closest).
Cheers  ;D
