Author Topic: Looking for a keyboard for a friend with RSI  (Read 3670 times)
Offline gaffer
« on: Sat, 13 July 2013, 20:22:41 »
A friend of mine is dealing with a messed up wrist at the moment, and is looking for a better office setup.
So, I'm looking for a bit of advice on keyboards (poss. mouse advice also) that actually help, since there's a lot of ****ty advertising out there.
Is the Kinesis Freestyle split keyboard model a good direction to go, or is something like the Truly Ergonomic Keyboard (although maybe a less expensive variant) more useful?
Offline blueSmoke
  • Life is what happens while you're busy Fixing RSI
Re: Looking for a keyboard for a friend with RSI
« Reply #1 on: Sun, 14 July 2013, 04:34:50 »
RSI stage? how long?
fixes/remedies tried?
office? home office? coworker noise sensitivity? workplace authorization?
programmere? IT guy? heavy computer user? casual user?
finally budget?
more details maybe?
Model M, Filco Tenkeyless White, Few others, few more others, Noise-hater (ongoing project), blah-blah (to be fillled later...)
Offline blueSmoke
« Reply #2 on: Mon, 15 July 2013, 04:12:46 »
come on... dont be shy.
we all couple of friends with RSI.
Offline vatin
« Reply #3 on: Mon, 15 July 2013, 04:17:51 »
Kinesis advantage will give you good result, provided you're willing to learn new layout.
HHKB Professional Classic
Offline Tony
« Reply #4 on: Mon, 15 July 2013, 23:21:37 »
You can change layout to Colemak/Dvorak/Workman, it also helps by reducing the finger travel, making typing more comfortable.
Offline vivalarevolución
« Reply #5 on: Tue, 16 July 2013, 20:17:17 »
I would strongly consider the type of mouse that your friend is using as well.  For me personally, the mouse is actually a larger source of pain.
Offline hoggy
  • * Moderator
« Reply #6 on: Wed, 17 July 2013, 17:54:00 »
Has your friend seen a doctor?
Offline Lanx
« Reply #7 on: Mon, 22 July 2013, 01:29:01 »
you're friend needs to voice his problems really. like if he has wrist pain, that might be ergonomic, if he has tendon pain, that might be rubber dome vs mechanical.
