Author Topic: My HHKB Pro 2 Review  (Read 2770 times)
Offline pexon
  • El Jefe of Sleeving
    • Pexon PCs
« on: Sun, 14 July 2013, 07:09:51 »
Can anyone give me some feedback in regards to my review of the HHKB Pro2?
http://pexonpcs.co.uk/blog/
Thanks a ton
Offline meiosis
  • Time
Re: My HHKB Pro 2 Review
« Reply #1 on: Sun, 14 July 2013, 07:16:34 »
I'll do some edits,
Pmd :3.
Great honest review, from a consumer perspective
« Last Edit: Sun, 14 July 2013, 07:41:40 by Meiosis »
Keyboards:
Aripeko TKL
Offline pexon
    • Pexon PCs
« Reply #2 on: Sun, 14 July 2013, 07:29:25 »
Thanks for your feedback. Its my first review, I just wanted an outside view.
Apart from what your have pointed out, what do you think?
« Reply #3 on: Sun, 14 July 2013, 15:18:41 »
Very comprehensive (says a fellow HHKP2Pro owner).
There is allegedly a Caps Lock - Fn + Tab is labelled as "Caps", and rumour has it that this is the case, but mine has never worked, simply returning a tab.
Although I am using it on a Mac, don't know if this makes any difference.
I have relatively large, strong hands, and although I rarely accidentally press a key, I do find that I can rattle off a quick sentence or two much more easily with the Topre switches.
Offline pexon
    • Pexon PCs
« Reply #4 on: Sun, 14 July 2013, 15:48:28 »
Thanks for the positive feedback.
I can access the Caps lock key by using Fn and Tab. I use the dip switches, 2 and 6 in the Windows environment.
I dont find the Topre switches on the HHKB light and I do tend to type heavy handed, I do make more mistakes on this board than my others.
