Author Topic: QFR Unbranded? QFR Customization?  (Read 2141 times)
Offline Narcix
« on: Sun, 14 July 2013, 09:05:39 »
Heya, I'm still looking for a qfr to replace my qfire pro, and while searching on ebay i found an unbranded one with blues for about 85€ shipping included. But I'd also like to customize it: nothing to fancy, just some nice keycaps...problem is that i dont know which ones are compatible with that keyboard, and i wouldnt like to buy stuff i cant use....also, is there any eu website that sells keycaps or i have to rely on us ones? thanks in advance
Keycool 87 Grey PBT with mx blues
Re: QFR Unbranded? QFR Customization?
« Reply #1 on: Sun, 14 July 2013, 10:26:40 »
QFR has a very standard layout. Most sets out there should fit. If you have any specific sets you're concerned for you can ask here.
As for EU suppliers I have no idea.
Offline Narcix
« Reply #2 on: Sun, 14 July 2013, 10:40:02 »
1 more question: are qfr leds bright? i'd like to put a transparent/backlit key on the scroll lock button, but i dont know if leds are bright enough to light it up....the ones on the qfire pro are almost invisible
« Reply #3 on: Sun, 14 July 2013, 10:48:48 »
They're pretty bright.
« Reply #4 on: Sun, 14 July 2013, 17:00:51 »
Have a look here for our list of keycap vendors.
There are a few in the UK.
