Author Topic: Painting.  (Read 2529 times)
Offline Merloobi
Painting.
« on: Mon, 15 July 2013, 02:11:28 »
Hi All,
  I'm new to this scene and am very interested in getting a few keyboards myself. The keyboard that got me interested was the Limited Edition CM Storm QF TK. I'm a big fan of black on white designs so it instantly got my attention. Unfortunately, I've had no luck trying to buy one so I thought I could buy a normal black QFTK and paint the case white myself. I just a have a few questions.
What kind of paint is best for a plastic case?
Is the paint surface noticeably different from the stock surface in terms of touch?
How easy/hard is it to disassemble a QFTK?
I heard that its a relatively simple mod, but I have no previous modding experience. Are there any good modding guide/resources for beginners like me?
Offline Photoelectric
Re: Painting.
« Reply #1 on: Mon, 15 July 2013, 10:24:56 »
You can use various paint types.  There are paints made specifically for plastics, such as Krylon Fusion and DupliColor vinyl and fabric dye.  You can also use acrylic lacquers and oil enamels, either with an appropriate primer for plastics underneath or some already come formulated to stick to plastic, such as Rust-Oleum Painter's Touch.
Yes, QFR comes with a very thin layer of rubberized coating that gives it color and texture.  The gunmetal color is a fine rubbery layer over black plastic.  The new texture/feel of your painted case will be of whatever paint you choose for it.  It won't be rubbery though.  And you'll want to sand off a fair amount of the rubber coating prior to painting.
Remove one screw from the back, use an old credit card sliding it in under the top cover along the back and front to pop open plastic tabs.  There are probably videos of this.
Yeah I think it's not that bad, especially for simple white.  I helped someone paint their Ducky white with oil enamel, so if that's what you want, send me a PM for tips.  In any case, google computer case painting as well as specific questions and do some reading.  Then practice on random plastic or scrap metal.  Only use very fine layers of paint.  Multiple fine layers > thick wet layers, if you wish to achieve a neat uniform look that will cure well.
Offline Xenderwind
Re: Painting.
« Reply #2 on: Mon, 15 July 2013, 10:37:50 »
He's talking about a quickfire tk, not a QFR.  The quickfire tk (from my googling) has no rubber coating as opposed to the QFR.  Not sure about dissemblance but I am sure there are videos.
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
Re: Painting.
« Reply #3 on: Mon, 15 July 2013, 10:43:27 »
Oops, still half-awake...  Well, in case of the TK, there are screws under the rubber pads for the feet also.
http://geekhack.org/index.php?topic=44060.0
If there's no rubber coating and it's just plastic, you won't really need to sand, just clean very thoroughly.  The surface will feel different after painting anyway.
Offline Merloobi
Re: Painting.
« Reply #4 on: Mon, 15 July 2013, 10:53:31 »
Thank you SO much for the responses. It looks like I have a lot of learning and practice to do  :D
Can't wait!
