Author Topic: Blank white keycaps for Poker II  (Read 4697 times)
Offline pixel5
    • pixel5
« on: Mon, 15 July 2013, 14:05:22 »
I need some help... I'm looking for the cheapest way to get a set of blank white keycaps for my Poker II (I will be dyeing some of them). I'd prefer PBT obviously, but ABS might be fine for the right price...not sure how it accepts dyes. The cheapest/best deal I can find so far is Signature Plastics for $37 + shipping (87 keys, intended for TKL).
Is there a better deal out there than that? Thanks!
Poker II
Quickfire Rapid
BUY MY CRAP
Offline Lastpilot
  • Power stance
Re: Blank white keycaps for Poker II
« Reply #1 on: Mon, 15 July 2013, 16:18:56 »
As long as you are fine with the DSA profile, those keycaps would be your best deal.
Offline pixel5
    • pixel5
« Reply #2 on: Mon, 15 July 2013, 16:22:17 »
What profile is standard on the Poker II? (if you know...)
Poker II
Quickfire Rapid
BUY MY CRAP
« Reply #3 on: Mon, 15 July 2013, 16:22:45 »
Probably OEM
Offline pixel5
    • pixel5
« Reply #4 on: Mon, 15 July 2013, 16:24:41 »
Probably OEM
OEM profile? OEM is 'original equipment manufacturer'...didn't realize that was a standard profile.
Poker II
Quickfire Rapid
BUY MY CRAP
« Reply #5 on: Mon, 15 July 2013, 16:25:12 »
It's not, each OEM has it's own profile.
Offline badcop
  • thorpe thocking master race
« Reply #6 on: Mon, 15 July 2013, 16:26:38 »
dsa is going to be shorter than what you have on your poker right now.
http://keycapsdirect.com/pdfs/DSAFamily.pdf
Photo credit: Chicken chaser
for you to get an idea of the shape from the top.
« Last Edit: Mon, 15 July 2013, 16:28:48 by badcop »
« Reply #7 on: Mon, 15 July 2013, 16:27:11 »
"OEM profile" refers to the taller than cherry profile caps like from stock Filco, WASD, a lot of Chinese caps, etc. Unless we've stopped using that term.
« Reply #8 on: Mon, 15 July 2013, 16:28:41 »
We voted to stop using it. Also, get off the island.
« Reply #9 on: Mon, 15 July 2013, 16:30:02 »
http://deskthority.net/wiki/Keyboard_profile#OEM_Profile
"Example keyboards include keyboards made by Costar (such as Filco Majestouch and WASD Keyboards), Das Keyboard (III), iOne, SteelSeries, Chicony, etc"
As I previously mentioned
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #10 on: Mon, 15 July 2013, 21:38:11 »
DSA is probably cheapest. Since you want to dye you need to stay away from ABS, is too hard to dye without melting it. Next cheapest is probably blank set of imsto Cherry profiles if you want something more normal sculpted style.
