Author Topic: NEO KB-87 II Switch replacement  (Read 6613 times)
Offline Abortion0
« on: Tue, 16 July 2013, 16:00:28 »
I saw an old thread about this (http://geekhack.org/index.php?topic=44252.msg913661#msg913661) but no one specified how to change the switches, I was wondering if anyone could offer some insight on how to do this, and just some general information about the board.
Also here's a cool mod someone on reddit did a while ago. http://imgur.com/a/FSQJG
Re: NEO KB-87 II Switch replacement
« Reply #1 on: Tue, 16 July 2013, 16:05:00 »
With the way it's mounted you can just pop off the top pieces (there are 2 slots/tabs on each side) and change the spring/stem.
Offline Abortion0
« Reply #2 on: Tue, 16 July 2013, 16:07:45 »
Thanks, I'm also wondering where the hell I can buy some green switches, but this seems to be a universal problem...
« Reply #3 on: Tue, 16 July 2013, 16:08:15 »
They're probably on pre order over at deskthority.net :\
Offline Abortion0
« Reply #4 on: Tue, 16 July 2013, 16:13:36 »
Have you ever used this keyboard?
« Reply #5 on: Tue, 16 July 2013, 16:14:20 »
Nope
Offline Abortion0
« Reply #6 on: Tue, 16 July 2013, 16:15:38 »
Nope
Actually I thought of another question, do you know of a cheap crappy keyboard with green switches that I could buy to harvest keys?
« Last Edit: Tue, 16 July 2013, 16:24:17 by Abortion0 »
Offline RabRhee
« Reply #7 on: Tue, 16 July 2013, 16:31:55 »
You could always go for ghetto greens, blue switches with black springs. if your board has black or blues on now the other half could be easier to source than true greens.
-Life is good-          Crafting: |  Keychains |  More.   .Keychains | Crowdsource Key | Budget Keycap Board |
Offline Abortion0
« Reply #8 on: Tue, 16 July 2013, 16:44:06 »
I isn't that still like 10g off? I'd like to try it, but I don't have the tools needed to open the switch up or black switches sitting around.
Offline RabRhee
« Reply #9 on: Tue, 16 July 2013, 17:06:34 »
I don't think ghetto greens are as heavy as real greens, but sourcing a set of black springs will probably be a fraction of the cost of some green switches for a decent version of heavier blues, plus pretty fast for you to swap to try.
There's a couple of guides on fabricating switch opening tools, very useful as you have an easy open switch keyboard, or make yourself a pair a bit like The_Beast's switch opening tool, pictures are somewhere....
Post on the topic - http://geekhack.org/index.php?topic=45447.0
Bulldog clip version - http://www1.kbdmania.net/xe/tipandtech/3520312
« Reply #10 on: Tue, 16 July 2013, 17:07:50 »
You don't need to make switch opening tools. I use a small screwdriver like this
Offline Abortion0
« Reply #11 on: Wed, 17 July 2013, 15:10:05 »
Alright, as long as we're talking there's another thing. Right now I've got blues on my keyboard (das model-s professional) and I almost always bottom them out form typing would some rubber o-rings be the way to go?
« Reply #12 on: Wed, 17 July 2013, 17:42:41 »
That's one technique that many people use, so you are bottoming out on rubber, which is much nicer. You can also go with switches with stronger springs, such as greens.
Offline Abortion0
« Reply #13 on: Wed, 17 July 2013, 17:46:56 »
Alright thanks would the best place to buy descent cheap o-rings be wasdkeyboards or somewhere else?
Offline RabRhee
« Reply #14 on: Wed, 17 July 2013, 17:57:36 »
Good post here about O-rings, including an Amazon link to some cheap ones. - http://geekhack.org/index.php?topic=45241.msg944195#msg944195
Somehow I read the line about not having tools as 'I wouldn't open 80 without a tool', but yes, you can open them fine without fancy schmancy tools. Anyway, heres the post and pic of Beast's cherry switch tool too - http://geekhack.org/index.php?topic=36677.msg878775#msg878775
Offline Abortion0
« Reply #15 on: Wed, 17 July 2013, 18:17:48 »
Offline sth
  • 2 girls 1 cuprubber
« Reply #16 on: Wed, 17 July 2013, 18:55:01 »
i wanted one of these for a long time when i used cherry... cool board :)
Offline Abortion0
« Reply #17 on: Wed, 17 July 2013, 21:20:16 »
What do you use now?
Offline sth
« Reply #18 on: Wed, 17 July 2013, 21:21:30 »
pretty much just a hhkb. i'm loaning my realforce 87u to a friend.
Offline Abortion0
« Reply #19 on: Wed, 17 July 2013, 21:25:57 »
Cool switches?
Offline sth
« Reply #20 on: Wed, 17 July 2013, 21:26:59 »
the very best ;) they are both topre.
Offline Abortion0
« Reply #21 on: Thu, 18 July 2013, 11:46:32 »
Nice, I've wanted to try topres, but I'd like to try some out before I dumped some money on them, I wish there was a place where I could go to try out all of these switches.
« Reply #22 on: Thu, 18 July 2013, 11:48:17 »
Go to a GeekHack meetup or sign up for tours like Hashbaz's Universal Switch Tester or my own tour. That's how I tried most switches.
Offline Abortion0
« Reply #23 on: Thu, 18 July 2013, 12:32:38 »
You have a link to a thread about some of those? I might be able to go to one in Chicago.
« Reply #24 on: Thu, 18 July 2013, 13:00:43 »
http://geekhack.org/index.php?topic=44762.0
« Reply #25 on: Thu, 18 July 2013, 13:07:26 »
Universal Switch Tester: http://geekhack.org/index.php?topic=44880.0
And I bet if you read all of my info real carefully, you can find my tour :P (It's in my signature/profile)
Offline Abortion0
« Reply #26 on: Thu, 18 July 2013, 13:45:26 »
haha wow, I actually don't live to far away from Cincinnati, you know where warren dunes is?
« Reply #27 on: Thu, 18 July 2013, 13:58:17 »
I've only been living here for a little while and I'm horrible with the local geography. I don't have a clue what Warren Dunes is.
Offline Metr0
  • HHKB or nuttin
« Reply #28 on: Thu, 18 July 2013, 15:29:22 »
Hey there, thought I'd do a little follow up since I've seen this thread. I actually sold the keyboard 2~3 weeks after receiving it. The build quality was absolutely abysmal, like the worst I have ever seen. I really recommend you not to get this board, caused me far too many problems :(
[WTB] BLANK PINK HHKB ARROW CLUSTER
Offline Abortion0
« Reply #29 on: Thu, 18 July 2013, 17:54:31 »
I actually would've been surprised if you did, it's up from you in southwest MI kinda by New Buffalo.
Alright, I was thinking about just settling for a qfr stealth with green switches anyways. Thanks for the heads up.
Offline harkomatic
« Reply #30 on: Thu, 07 November 2013, 15:23:54 »
Hi,
Apologies for bumping this topic but I am looking to change out the black switches that came with this with the blues found in my old das keyboard. Unfortunately I cant harvest the das's keys since they are soldered in.
Can anyone point me in the right direction for where I should go to buy the correct mx blue switches?
« Last Edit: Thu, 07 November 2013, 15:53:51 by harkomatic »
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #31 on: Thu, 07 November 2013, 16:24:38 »
What part of world are you in? One supplier may be better than other for shipping fees.
Offline harkomatic
« Reply #32 on: Thu, 07 November 2013, 16:58:39 »
USA.
I cant stand the black switches- Feels like I am typing while drunk
