Author Topic: Quickfire pro keycaps?  (Read 2236 times)
Offline Narcix
« on: Wed, 17 July 2013, 03:55:03 »
Hello, i was wondering if the qfire pro's keycaps can be replaced, like on the rapid. since it has a decent amount of backlit keys, it might be kewl to put some kewl keycaps on it. never seen a picture of one which doesnt mount default ones though. any help? ty
Keycool 87 Grey PBT with mx blues
Re: Quickfire pro keycaps?
« Reply #1 on: Wed, 17 July 2013, 04:33:22 »
Yes, just standard Cherry MX switches, so most sets would come close.
But due to the non-standard bottom row you might have a bit of difficulty there.
Offline IMHB
« Reply #2 on: Wed, 17 July 2013, 11:56:48 »
you should be able to
« Last Edit: Wed, 17 July 2013, 11:59:04 by IMHB »
