Author Topic: Poker 2 question?  (Read 1350 times)
Offline aj-kun
Poker 2 question?
« on: Thu, 18 July 2013, 16:58:08 »
Is there anyway to map Esc to `~ on the poker 2 without a software keymapper?
Pressing FN+ESC to get `~ is a pain.
Offline knotra
  • I ญญญ♥ ⌂ ♫
Re: Poker 2 question?
« Reply #1 on: Thu, 18 July 2013, 17:09:01 »
bump.
I also want to know this as well as how you even change the keymapping on the poker II.
Keyboards: Razer Blackwidow Ultimate, Das Model S Ultimate Tactile Soft, Das Model S Professional Tactile Click, Corsair Vengeance K90, Steelseries 6gv2 Black Switch, Filco Ninja Majestouch-2 Soft Linear Action, Ducky DK9087 Shine II w/ Browns, Ducky DK9008 Shine II w/ Blues, WASD Keyboard v1 w/ Browns, Leopold FC200R Tacticle Touch, White Filco Majestouch-2 TKL Click Action, Ducky DK9008G2 PRO Dark Grey Version PBT w/ Clears, Realforce 87U Tenkeyless 45g White/Grey
Offline mashby
  • What Up Shoney? (ツ)_/ฏ
    • Mashby
« Reply #2 on: Fri, 19 July 2013, 10:45:58 »
According to the manual, you can map "~" to the right CTRL key with dip switch 2.
I don't have a Poker II, but the Poker X has an option, where if you hit "fn + Q" you reverse the "Esc / ~" so that "~" is the default and "Esc" requires the "fn" key.
Hope that helps!
Offline aj-kun
« Reply #3 on: Fri, 19 July 2013, 22:00:05 »
Guess I'll try that then.
Offline keyed1n
« Reply #4 on: Sat, 20 July 2013, 09:43:41 »
Unfortunately, the fn+q combo doesn't seem to work. I've programmed esc to ~ and used the dip for programmed esc to CAPS. Any other suggestions would be greatly appreciated as this has bothered me too :)
« Last Edit: Sat, 20 July 2013, 10:03:42 by keyed1n »
