Author Topic: How to swap PCB mount switches  (Read 1804 times)
Offline PointyFox
« on: Thu, 18 July 2013, 20:01:52 »
If I had a Poker with switches I didn't like, how would I get different switches and swap them?
Re: How to swap PCB mount switches
« Reply #1 on: Thu, 18 July 2013, 20:03:45 »
The first generation poker that's PCB mounted you just remove the switch tops and you can put in different stems and springs.
I'm on my phone but you can see some switch replacement action in Mooses mod thread, also in captains spring swap thread.
There is also a video out there.
« Last Edit: Thu, 18 July 2013, 20:09:16 by SpAmRaY »
Offline esoomenona
  • Gnillort?
« Reply #2 on: Thu, 18 July 2013, 20:07:40 »
Look in the thread I told you of, and you can see exactly how. XD
Offline PointyFox
« Reply #3 on: Thu, 18 July 2013, 20:08:13 »
How do I remove the switch tops?  I don't have any special tools for that, just a ton of pliers and screwdrivers.  Where is a good place to buy switch parts from?
Offline esoomenona
  • Gnillort?
« Reply #4 on: Thu, 18 July 2013, 20:11:40 »
You could do it with some smaller screwdrivers. Buying switch parts? The best place is right here, of course. Start a WTB thread. You should find Black stems easily enough.
Offline PointyFox
« Reply #5 on: Thu, 18 July 2013, 20:13:46 »
I have vintage blacks, but they're plate mount and I think I'd have to desolder those, right?
Offline esoomenona
  • Gnillort?
« Reply #6 on: Thu, 18 July 2013, 20:15:33 »
If they're attached to a plate mount board, then yes.
Offline PointyFox
« Reply #7 on: Thu, 18 July 2013, 20:18:45 »
Time to buy that desoldering equipment I wanted  ^-^
Though it would be a shame to ruin a $30 board.  :-[
« Reply #8 on: Thu, 18 July 2013, 20:54:56 »
You can get some black switches for cheap from whiskytango.
http://geekhack.org/index.php?topic=45679.0
« Last Edit: Thu, 18 July 2013, 20:59:03 by SpAmRaY »
Offline PointyFox
« Reply #9 on: Thu, 18 July 2013, 21:12:30 »
Looks like he has only plate mount?
Offline esoomenona
  • Gnillort?
« Reply #10 on: Thu, 18 July 2013, 21:14:37 »
Plate mount is fine. All you need are the springs and stems. You open all the switches on the board, and all the switches you buy, replace the springs and stems, and close them back up.
