Author Topic: Which boards come with Ergo Clears?  (Read 2404 times)
Offline digi
  • elite af tbh
  • keyboard game on fleek
« on: Fri, 19 July 2013, 11:15:20 »
Could anyone tell please me which keyboards come with MX Clears? Are there any Cherry branded keyboards that come with Clears?
Re: Which boards come with Ergo Clears?
« Reply #1 on: Fri, 19 July 2013, 11:16:01 »
Clears or ergo clears?
You can get a ducky full size with clears from mechanicalkeyboards.com
And you can get the FC660M with clears from qtan.
I think at one time their was a leopold with clears and I've seen some oni boards with clears on taobao.
I'm sure there are more.
But ergo clears is custom modding of a clear switch they don't make those factory.
« Last Edit: Fri, 19 July 2013, 11:18:50 by SpAmRaY »
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #2 on: Fri, 19 July 2013, 11:17:09 »
Some older boards will, nothing new that I know of. Nothing will come with "Ergo-Clears" from the factory as that's a custom mod. You might be able to find someone selling an ergo-clear modded board on here at some point however. Check eBay, just type in Cherry MX Clear and see what pops up every now and then.
TOO BAD FOR YOU
              Phantom 62g MX Whites
« Reply #3 on: Fri, 19 July 2013, 11:17:17 »
No keyboard on the market comes with ergo-clears.
Offline digi
  • elite af tbh
« Reply #4 on: Fri, 19 July 2013, 11:17:18 »
Oh, are Ergo's custom? I guess Clears then?
Offline Jack Karneval
  • I'm gunna pop some keys, only got $20 in my pocket
« Reply #5 on: Fri, 19 July 2013, 11:17:55 »
Curses, you beat me to it!
: CM Storm Trigger (MX Green) : KBT Pure Pro (MX Blue) :
Offline Tarzan
  • formerly known as Greystoke
« Reply #6 on: Fri, 19 July 2013, 11:18:02 »
Some of the SkiData boards (available used on eBay.de) had MX Clears.
Offline Hazel
« Reply #7 on: Fri, 19 July 2013, 11:22:13 »
The WASD v2 will be available with Clears.
Offline linziyi
  • The one with many questions
« Reply #8 on: Fri, 19 July 2013, 11:23:53 »
What is the cheapest way to source clear switches then?
Ducky DK9008G2 Pro
"Much to learn you still have" --Yoda
Offline digi
  • elite af tbh
« Reply #9 on: Fri, 19 July 2013, 11:24:22 »
Thanks for all the info, imma mx clear nub.
Offline DrinkTea
« Reply #10 on: Fri, 19 July 2013, 11:30:44 »
I heard cherry would consider making clears with lighter springs if they got a large enough order.
« Reply #11 on: Fri, 19 July 2013, 11:39:22 »
That will be a special edition with white plate and non customizable key caps called the 'code', I believe.
It probably depends on how many you want/need.
And if you care if they are new and/or used. You could buy a cheap board with clears if you can find it and desolder them.
You can get them from 7bit's group buy on DT, there was recently a groub buy on here for clears and some vendors sell them mouser, rapid etc.
And the stem would be purple/dark pinkish I think.  :o
« Reply #12 on: Fri, 19 July 2013, 11:39:59 »
Buy old keyboards that have MX Clears in them. I missed out on buying an old Cherry board that had Clears. It was going for like $45 in the classifieds.
