Author Topic: Teensy modding a PS2 Realforce (98S)  (Read 5222 times)
Offline khaangaaroo
« on: Fri, 19 July 2013, 13:09:44 »
Pretty easy to do. Just needed to mod the case a little bit so that everything fits.
Wired up using motherboard pin connectors and wires from the power and hdd LEDs on a PC tower.
Cut away the risers that held the old cable in place.
Hot glue attach the Teensy.
Make room for the new cable.
USB it up.
« Last Edit: Fri, 19 July 2013, 13:28:35 by khaangaaroo »
Re: Teensy modding a PS2 Realforce (98S)
« Reply #1 on: Fri, 19 July 2013, 13:19:15 »
Crazy man!!
Offline zeros
« Reply #2 on: Sun, 21 July 2013, 09:23:24 »
WOW  :eek:
Offline MJ45
  • HHKB Pro
« Reply #3 on: Sun, 21 July 2013, 12:26:06 »
It looks like your just using the teensy for its mini b plug, and not using the controller. Kind of an expensive usb connector.
Offline khaangaaroo
« Reply #4 on: Sun, 21 July 2013, 12:34:11 »
It's working as a ps2 to usb converter. Unlike the 87u, the 89S has a ps2 connector.
Offline MJ45
  • HHKB Pro
« Reply #5 on: Sun, 21 July 2013, 13:43:19 »
Ok I can see that now. I didn't know those were ps2.
