Author Topic: WASD V2 Pre Orders open  (Read 4662 times)
Offline daerid
    • Rossipedia
Offline WhiteFireDragon
    • youtube
Re: WASD V2 Pre Orders open
« Reply #1 on: Fri, 19 July 2013, 16:22:50 »
I'm really digging the new shape of the case, but don't like the gap/seems between the top and bottom piece.
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #2 on: Fri, 19 July 2013, 16:23:03 »
V2 Features
Cherry MX Mechanical Key Switches
- High quality, gold plated switches rated at 50 million cycles
- Select between Cherry MX Blue, Brown, Black, Red, and Clear variants
N/6-Key Rollover
- True N-Key Rolloverover PS/2 with included adpater
- Modified 6-Key Rollover over USB allows additional key presses after 6 keys to be recognized
Configurable Key Output
- Switch between QWERTY, Mac, Dvorak, and Colemak output modes
- Switch Caps Lock to Ctrl
Gaming Features
- Windows Lock mode allows toggling the Windows Keys on and off with Scroll Lock
- Fully disable Windows Keys operation
Multimedia Shortcuts
- Play, Stop, Next, Prev, Vol Up, Vol Down, and Mute shortcuts
- Optimized shortcut locations
- Can be disabled enable the default "Menu" key
Case Design
- Detachable USB cable
- 5-way cable routing system
- Low profile case for a more comfortable and natural typing position
- Red LED lock indicators
- No logo
- Rubberized flip out feet
Accessories
- 1.8m (70.8in) Micro USB cable with cable tie
- Wire keycap puller
- USB to PS/2 adapter
V2 Specifications
Dimensions: 363x142x30mm (14.3x5.6x1.2in)
Weight: 907g (2.0 lbs)
Interface: USB / PS2
Compatibility: Windows, Mac, Linux
Case Material: ABS
Keycap Material: ABS
Made in Taiwan. Designed and customized in USA.
Offline gnubag
« Reply #3 on: Fri, 19 July 2013, 16:23:44 »
is the gap between the case parts intentional?
Offline whiteduck
« Reply #4 on: Fri, 19 July 2013, 16:25:08 »
ordered... ^.^
-wd
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #5 on: Fri, 19 July 2013, 16:26:10 »
I feel like it should at least come with PBT keycaps for that price, am I out of line here? Like the option for MX Clears however.
Offline Danule
« Reply #6 on: Fri, 19 July 2013, 16:28:51 »
mmm looks yummy. i wonder how the quality of the PCB compares to filco.
45g Brown Brown Blue
Offline Rafen
« Reply #7 on: Fri, 19 July 2013, 16:30:53 »
No I feel the same way. A QFR w/reds and PBT would be cheaper. I think that I am going to pass on this board.
Offline CommunistWitchDr
  • >implying keyboards
« Reply #8 on: Fri, 19 July 2013, 16:46:56 »
The hardware colemak is nice, though nowhere near as nice as total programmability, I mean there are programmable controllers for pretty cheap. Just use one and pass the cost on to the buyer if need be.
Offline SkyCorrigan
  • Formerly known as "sloth_mc"
« Reply #9 on: Sat, 20 July 2013, 23:35:37 »
Probably not. Filco is King. Anyone that disagrees is using a Blackwidow.
Sloth with that QWERTY know-how
Offline terran5992
  • One With The Cup Rubber
« Reply #10 on: Sun, 21 July 2013, 02:10:28 »
There goes my money :(
Offline TimIsABat
  • MX Clears are life
    • Instagram
« Reply #11 on: Sun, 21 July 2013, 02:30:48 »
I'm not the only one that thinks this board is a bit overprice? I can just get a QFR or a Leopold TKL instead of paying for this...
Leopold FC660M MX Reds | Poker X 62g  Ergoclear modded and plate modded (out of comission) | IBM Model M 1391401 | Dell AT101 | Compaq RT101 | HHKB Pro 2 | WASD CODE TKL MX Clears
Avid vape collector and advocate. I used to work at to renowned vape shops here in New Jersey. Message me for any vape related questions.
Main driver : WASD CODE TKL MX Clear
Offline terran5992
« Reply #12 on: Sun, 21 July 2013, 02:41:30 »
You can choose what type of switches you want and you can customize the keycaps that it comes with.
Offline Lu_e
« Reply #13 on: Sun, 21 July 2013, 02:55:22 »
...lol
to continue the above, it has a bunch of small very custom touches which is added cost not seen by some companies that 'pick' their product from a catalog more or less. and some also manufacture in China. (For the record WASD and qfr is made in Taiwan)
Obviously by pricing their v2 this way, they are basically saying: its as good (or better) than a filco... since they are the same price.
custom features like;
DIP switching abilities
apparently quite low profile body (measuring my qfr; the width is the only measurement sorta different)
double rubber feet
more cable routing
I would hope a high quality build, PCB, and solder... (who will be first to crack one open?)
nice cable puller is worth mentioning
modified media layout
"modified 6 key rollover" ? "allows additional key presses after 6 keys to be recognized" ? sounds neat if im not misinterpreting it.
SO in summary is a filco worth it? if so, and this product is of equal quality (with the aforementioned custom touches);
How is it not worth it ;)
« Last Edit: Sun, 21 July 2013, 03:01:49 by Lu_e »
Just say NO to ABS keycaps
Offline jabar
« Reply #14 on: Sun, 21 July 2013, 09:09:31 »
because a wide variety of Cherry TKL boards aka Ducky, Keycools can be had with standard PBT for less than 2/3 the price.
The only advantage V2 has is custom lasered ABS keycaps (if that is a must for you) and the DIP switch. Everything else has been done for less.
It's hilarious that some switch options even ADD to the price. Pony up another $20 and the cheapest Topre board is the same price!
PS we already have a thread up here http://geekhack.org/index.php?topic=43077.0
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline TheProfosist
  • Custom Layouts Only!
« Reply #15 on: Sun, 21 July 2013, 09:14:54 »
This keyboard should not be directly compared to other standard tkl keyboards because of versatality due to the dip switches. I think the only thing that comes some what close out of the box is a leopold 700R. Also the other thing many of you see to be missing is that the preorder is for full custom boards only. I imagine this is due to the initial limited supply.
« Reply #16 on: Sun, 21 July 2013, 09:26:54 »
Yes but do you get a selection of 10 ish different colors for yhe caps and in this case any cap can be any of those colors.
Also WASD has tried to get PBT keycaps before more than once. After the last time where he had an issue with the company making the molds he decided to focus on designing and releasing a new line of keyboards.
So your saying this keyboard itsnt unique or special at all even though it has many features people have been asking for for some time. Many of these features not available at all on a retail mechanical keyboard much less all together on one board.
Aparently you havent been around for long as it quite common for the less common switches to cost more. This is like due to the amount of each that is being ordered.
Yes you could get a type heaven with a completly different switch type and none of the same features or even the same layout. That argument makes no sense.
I dont know why you guys think WASD is trying to compete with the likes of the cheap boards out there today. That isnt the case and never has been.
Offline TimIsABat
    • Instagram
« Reply #17 on: Sun, 21 July 2013, 17:10:15 »
That would make sense for the price. If they sell this at much cheaper price than their competitors than maybe I would consider it, because I would rather buy a cheaper board and bay for better doubleshot or PBT keycaps with a better profile than get this...the customization makes it more understandable with this price range.
Offline BliTzKiN
« Reply #18 on: Mon, 22 July 2013, 20:51:04 »
Well, until someone gets their hand on it, no one knows. It could possibly be worth the price tag. But based on pictures, loving the casing, hating the gap :(
Offline Lu_e
« Reply #19 on: Mon, 22 July 2013, 20:52:13 »
^ agreed. my only turn-off
Offline knotra
  • I ญญญ♥ ⌂ ♫
« Reply #20 on: Mon, 22 July 2013, 20:57:02 »
I would agree, or at least have the option to have PBTs.
Keyboards: Razer Blackwidow Ultimate, Das Model S Ultimate Tactile Soft, Das Model S Professional Tactile Click, Corsair Vengeance K90, Steelseries 6gv2 Black Switch, Filco Ninja Majestouch-2 Soft Linear Action, Ducky DK9087 Shine II w/ Browns, Ducky DK9008 Shine II w/ Blues, WASD Keyboard v1 w/ Browns, Leopold FC200R Tacticle Touch, White Filco Majestouch-2 TKL Click Action, Ducky DK9008G2 PRO Dark Grey Version PBT w/ Clears, Realforce 87U Tenkeyless 45g White/Grey
Offline wasdkeyboards
  • * Commercial Vendor
« Reply #21 on: Mon, 22 July 2013, 23:09:13 »
I understand the styling won't appeal to every person, but we really wanted to make something that looked a little different from other keyboards without adding any extreme changes.
The gap also serves a purpose of keeping the case tabs accessible for service or modding. You can't see in the pictures, but we even added extra holes where the tabs are so they can be released more easily.
« Last Edit: Mon, 22 July 2013, 23:14:48 by wasdkeyboards »
Questions and comments, please visit our Geekhack: WASD Keyboards Vendor Forum
WASDKeyboards.com - Custom Mechanical Keyboards
Offline jabar
« Reply #22 on: Tue, 23 July 2013, 18:22:22 »
*makes keyboard more conducive to modding*
*doesn't make mod-friendly plate*
Phantom 7bit
Offline Lu_e
« Reply #23 on: Wed, 24 July 2013, 13:45:13 »
Barebones v2 is out! $99.99; blues & blacks. (clears for $109.99)
http://www.wasdkeyboards.com/index.php/wasd-v2-87-key-barebones-mechanical-keyboard.html
If/when mine craps out... (or i get a wild hair)... next board fo sho
Offline Tarzan
  • formerly known as Greystoke
« Reply #24 on: Wed, 24 July 2013, 14:01:02 »
I can't tell if this has already been asked, but is there any word when the full-size V2 will be available?
Offline Danule
« Reply #25 on: Wed, 24 July 2013, 14:22:38 »
as soon as some one gets one please post pictures i want to see this case.  If its lower than a filco i may be interested in getting one :)
Offline ImperfectLink
« Reply #26 on: Wed, 24 July 2013, 15:09:13 »
I agree with the sentiment about the price but I have a feeling it will live up to it's value. Also, to be fair the gap doesn't appear to be any greater than the Filco Tenkeypad:
Offline limniscate
« Reply #27 on: Wed, 24 July 2013, 17:40:49 »
Awe man, I thought you could switch capslock with control, not just assign control to capslock.
