Author Topic: What are alps/topre like?  (Read 5225 times)
Offline xSpartanCx
« on: Sun, 21 July 2013, 13:53:23 »
I will have at least one switch of each Cherry MX switch soon, and I have a Model M, but I've never been able to feel a topre/any type of alps switch. Is there anywhere where I can buy a single key? Can someone explain what they feel like in comparison to MX switches? I'm interested in a keyboard but don't want to spend a lot on topre and I've never felt an alps, so I don't know what I would be looking for, let alone if I would want one.
Offline jabar
Re: What are alps/topre like?
« Reply #1 on: Sun, 21 July 2013, 13:56:58 »
The only current production ALPS are Matias: clicky and silent tactile. All other ALPS and their dozens of varieties and knockoffs can only be found on boards, most of them used ones.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline Dgsbllx
« Reply #2 on: Sun, 21 July 2013, 13:58:36 »
Yup there are many different versions of Alps like mx. Topre keychains are available but they are rare/expensive so really you need to buy a board. Cheapest topre board is going to be an f600c probably, unless you get a deal second hand. And even then there are different topre weights!
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #3 on: Sun, 21 July 2013, 13:59:48 »
Topre can only be compared to MX browns due to the tactile bump. That being said, they're completely different. It's a nice, crisp, smooth switch that makes a wonderful sound and just feels amazing. It's got a tactile bump at the very top and beginning of the keypress which then becomes nice and smooth all the way down to the bottom. The different boards that are out there are also completely different. A variable will feel worlds apart from a uniform board, and then a uniform 45g will feel worlds apart from a uniform 55g. In that way, Topre's are unique along themselves just as the Cherry switches are. For alps, I've only tried complicated oldschool blues and they were surprisingly nice. Had a high actuation point with a nice plastic-y click to them that just felt nice.
Also, the Topre Type Heaven is the cheapest at 170 which is a nice price for a topre board. Uniform 45g, though it only comes with lasered ABS caps.
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline smknjoe
« Reply #4 on: Sun, 21 July 2013, 14:01:32 »
Topres are very refined rubber domes. Smoother, and lighter. Very nice, but not tactile unless you bottom out. ALPS are like a cheaper MX to me. Not bad, not mind blowing.
SSKs for everyone!
Offline Flamingo
« Reply #5 on: Sun, 21 July 2013, 14:07:54 »
There is also the Topre Type Heaven!
http://www.amazon.com/Topre-Type-Heaven-104-key-Keyboard/dp/B00DGJALYW/ref=sr_1_1?ie=UTF8&qid=1374433550&sr=8-1&keywords=type+heaven
And since its amazon you can easily try it out and if you really don't like it you can return it  :D
« Reply #6 on: Sun, 21 July 2013, 14:14:33 »
Alps are like an improved MX to me.
Provided that they are good ones. Deteriorated and/or dirty Alps are not nice. But old or used does not mean deteriorated by any means.
- D Trump 2026-10-24
Offline smknjoe
« Reply #7 on: Sun, 21 July 2013, 14:16:57 »
The fake white ones I have are very "scratchy". Like there is a grain of sand in the switch. They are heavier though which I like.
SSKs for everyone!
« Reply #8 on: Sun, 21 July 2013, 14:27:23 »
The white ones can be all over the board. I have an actual Alps brand board that is nice but a bit too heavy to make me feel good.
A lot of people really like the dampened cream Alps in the Apple Extended Keyboard II which is plentiful and cheap (but requires an adapter).
Offline Photoelectric
« Reply #9 on: Sun, 21 July 2013, 14:28:44 »
How would you compare Matias's "quiet" Alps in terms of reliability and quality?  I know people have different favorites among Cherry MX switches, but at least they are all consistently good and reliable--just different in feel.  But I have no good feel for how Matias' Alps versions stack up against other [overwhelmingly numerous] Alps competition.
Offline do_Og@n
« Reply #10 on: Sun, 21 July 2013, 14:38:15 »
I have a BNIB FK-2001 with simplified ALPS and it types like a dream. I like to use it more because it is firmer than MX Blues but not as much as greens and the click is like cocking a shotgun with each key press.
I've tried Topre and they aren't for me. Everything for them is expensive and to me they feel like an expensive Dell QuietKey.
BUT!!! this is just my opinion and everybody is different. You will need to try them out yourself and see what you think.
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #11 on: Sun, 21 July 2013, 14:49:09 »
Another thing that many people (including myself) neglect to say about Topre's is that they are capacitive, meaning, you don't need to bottom out for the keypress to register like on normal rubber domes.
TOO BAD FOR YOU
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #12 on: Sun, 21 July 2013, 15:09:09 »
fake alps scratchy-- exactly
example............acer so called alps (aka- acer switch)- very scratchy, but i have seen worse.
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
« Reply #13 on: Sun, 21 July 2013, 15:10:39 »
If you're interesting, I've written down my thoughts on Alps and Topre switches here.
Offline vivalarevolución
« Reply #14 on: Sun, 21 July 2013, 16:20:15 »
One big difference about most Alps switches and Topre compared to Cherry is that the actuation point is much higher on the key press than with cherry switches.  The actuation for Cherry tends to be more in the middle of the keypress.
« Reply #15 on: Sun, 21 July 2013, 16:21:49 »
And this is a very good thing. I think that is the greatest appeal of the jailhouse blues.
Offline AKIMbO
  • HHKBro
« Reply #16 on: Sun, 21 July 2013, 16:31:14 »
Topre feels like a softer ALPs switch. Both Topre and ALPs have a high actuation point and essentially force you to bottom out.
I'm a little partial, but ALPs got clicky switches right with the blue alps switch and linear switches right with the complicated green alps switch.  Topre got the tactile switch right with plate mounted 55g or HHKB plastic plate mounted 45g.
Orange ALPs are most akin to Topre switches.
| KBD75 (box reds)
« Reply #17 on: Mon, 22 July 2013, 02:33:09 »
I would classify the Topre as tactile. The 30g keys are not very tactile, but there is a bump there, which is more pronounced in heavier keys. They don't feel like linear mechanical switches at all.
Topre Realforce are high quality rubber dome keyboards throughout. You could say that they are the First Class of rubber dome keyboards.
Alps came in many varieties and revisions made by different companies. The original manufactured by Alps is called "complicated" because of the design of its innards. Some clones also have the Alps logo, so all are not that easy to identify. There are several types of linear, clicky and tactile.
Some do feel a bit like some rubber dome keyboards, because the tactile point is pretty high up.That is especially true of the "Cream" Alps, which is dampened. Alps are also a bit sensitive to dust, so used Alps boards can feel either great or awful depending on their history.
« Last Edit: Mon, 22 July 2013, 02:42:27 by Findecanor »
Offline esoomenona
  • Gnillort?
« Reply #18 on: Mon, 22 July 2013, 05:54:21 »
Read my profile, and find the truth about both.
Offline tgujay
« Reply #19 on: Mon, 22 July 2013, 10:07:57 »
Black Acers are one of my favorite switches.
Gotta collect them all
Offline knotra
  • I ­­­♥ ⌂ ♫
« Reply #20 on: Mon, 22 July 2013, 21:04:10 »
I have a Realforce 87U 45g and i am absolutely in love with it. It's hard to describe the feeling. I asked the same question before I bought mine and I got answers that were way off what I ended up experiencing. If I were to describe the feeling of Topre, I would say it was very tactile and it bump is at the top but some people say the 45gs are 'mushy' so I dunno :P
Keyboards: Razer Blackwidow Ultimate, Das Model S Ultimate Tactile Soft, Das Model S Professional Tactile Click, Corsair Vengeance K90, Steelseries 6gv2 Black Switch, Filco Ninja Majestouch-2 Soft Linear Action, Ducky DK9087 Shine II w/ Browns, Ducky DK9008 Shine II w/ Blues, WASD Keyboard v1 w/ Browns, Leopold FC200R Tacticle Touch, White Filco Majestouch-2 TKL Click Action, Ducky DK9008G2 PRO Dark Grey Version PBT w/ Clears, Realforce 87U Tenkeyless 45g White/Grey
