Author Topic: Which would you buy?  (Read 3572 times)
Offline ninjadoc
« on: Sun, 21 July 2013, 17:41:41 »
Lusting over the Korean keyboards. There is a KMAC LE, KMAC 1.2, and an LZ-MX mini. Which would you rather buy and why? I'm leaning toward the LZ-MX mini but if there was a KMAC mini floating around I might change my mind. Opinions please?
« Last Edit: Mon, 22 July 2013, 22:21:18 by ninjadoc »
Offline Neo.X
Re: Whjich would yhou buy
« Reply #1 on: Sun, 21 July 2013, 17:59:21 »
Doesn't matter, you will end up buying them all.  ;)
All those keyboards will be lost in time....
Offline llovro
« Reply #2 on: Mon, 22 July 2013, 02:07:42 »
there are not only kmacs and lz-mx out there :D
you have the cheat, koala, lz series, kingsaver, 356, 456, 356mini, 2tu ...
But out of all customs I'd mostly like to have 456gt :D
Offline Tony
« Reply #3 on: Mon, 22 July 2013, 03:58:37 »
Yeahh, yhou will buy them all, so whjich will be the fihrst doesn't matteh at allh.
If you can't decide which, let the coins help.
Offline ninjadoc
Re: Which would you buy?
« Reply #4 on: Mon, 22 July 2013, 22:22:03 »
No matter which keyboard apparently I can't type worth a flip!!!
Offline jabar
« Reply #5 on: Mon, 22 July 2013, 22:28:46 »
save your money and get a high quality keyboard, maybe a Topre
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline CommunistWitchDr
  • >implying keyboards
« Reply #6 on: Mon, 22 July 2013, 23:37:47 »
Every keyboard he listed makes (almost) every topre look cheap. I don't think money is the reason he's getting a cherry.
Offline sth
  • 2 girls 1 cuprubber
« Reply #7 on: Tue, 23 July 2013, 00:01:07 »
cherry makes a keyboard feel cheap :P realforce keyboards are housed in plastic but they feel very sturdy. heck, the standard of sturdiness is an IBM model M and those can be had for $20.
 hhkb with a plastic case might not feel as heavy as a metal plate keyboard but it still feels solid and works fine.
that said the 356mini with cherry doubleshots is pretty sleek :)
« Last Edit: Tue, 23 July 2013, 00:02:46 by sth »
« Reply #8 on: Tue, 23 July 2013, 08:40:23 »
>plastic case
>sturdy
Now a model f, beam spring, or old hall effect board is the definition of a sturdy keyboard.
« Last Edit: Tue, 23 July 2013, 08:48:18 by CommunistWitchDr »
« Reply #9 on: Tue, 23 July 2013, 08:43:34 »
Do you actually live in the city limits of Cincinnati ninjadoc? If you want, we can meet up and you can try my KMAC. I actually have a ton of boards if you wanted to talk shop/try boards. PM me if you don't want your info public.
Offline esoomenona
  • Gnillort?
« Reply #10 on: Tue, 23 July 2013, 09:02:30 »
Hey, CPT. Make sure to bring that thing... I've never actually ever typed on a KMAC...
« Reply #11 on: Tue, 23 July 2013, 09:03:08 »
Why? So you can mock the lack of MY switches in it?
Offline esoomenona
  • Gnillort?
« Reply #12 on: Tue, 23 July 2013, 09:04:22 »
I'm going to through throw it in one of the rivers because it doesn't even SUPPORT MY!
« Last Edit: Tue, 23 July 2013, 10:16:20 by esoomenona »
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #13 on: Tue, 23 July 2013, 09:04:45 »
Unlike MY Phantom
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline ninjadoc
« Reply #14 on: Sat, 27 July 2013, 08:19:29 »
Yes I actually live on the east side. I will give you my cell and text or call me sometime. I really want to see the KMAC. I'm too ignorant on some of these boards and already have spent too much money.
Offline Thimplum
  • Master of all Ponies
« Reply #15 on: Sat, 27 July 2013, 08:47:33 »
Oh.
Don't worry.
You'll spend more.
TP4 FOR ADMIN 2013
Offline ninjadoc
« Reply #16 on: Wed, 25 June 2014, 05:11:05 »
Oh.
Don't worry.
You'll spend more.
That is a HUGE understatement. We won't go there!!!
Offline Defect
« Reply #17 on: Wed, 25 June 2014, 06:03:38 »
LOOOOL
« Reply #18 on: Wed, 25 June 2014, 19:15:40 »
LOOOOL
High quality?
Build a Korean custom yourself and do your own QA!
