Author Topic: IBM Model M Spacebar Stabilizer  (Read 3989 times)
Offline bener
« on: Tue, 23 July 2013, 02:43:17 »
Hi all,
After lots of lurking around here and other sites, I have finally sourced an IBM Model M keyboard, and it is amazing!
The only real issue is that the space bar is missing its stabilizer, so only works when pushed right in the middle.  I was wondering if anyone
would be willing to measure one up for me so I can make a new one?  I have no reference and I have only been able to find one vague image
online.
I also have a couple of keys that don't click like they should - I have played around with the springs to no avail - reseating (used a toothpick similar
to 'chopstick of death' method), angled board when putting key back on etc. but to no avail - any advice on fixing this issue would also be appreciated!
I feel very proud to be part of the 'buckling spring club' now...!
Offline bener
Re: IBM Model M Spacebar Stabilizer
« Reply #1 on: Tue, 23 July 2013, 03:06:29 »
I am from New Zealand by the way, which makes ordering parts somewhat expensive - hence the need for DIY
alternatives!
« Reply #2 on: Tue, 23 July 2013, 05:54:08 »
Welcome to Geekhack!
Here's a few images of one of mine (from a 101 key Model M):
Offline bener
« Reply #3 on: Tue, 23 July 2013, 06:15:58 »
Oh mate! You are a legend!  I may even try making one tonight...
Here's some quick pics of the keyboard in question: http://imgur.com/a/9g0e2
First step, sort out stabilizer, next step, big clean up!  Trying to source a sticker now, blue
left hand side, 82G2383 (made by Lexmark).  I might end up making something to suit, we'll see how it goes.
Thanks again, your effort is very much appreciated!
Offline E TwentyNine
    • Some of My Keyboards
« Reply #4 on: Tue, 23 July 2013, 15:38:03 »
I had used a wire hanger to create one a while back:  http://geekhack.org/index.php?topic=43223.msg881239#msg881239
Very easy, just eyeballed it, even being a little off the spacebar still feels fine.
Offline bener
« Reply #5 on: Tue, 23 July 2013, 17:13:39 »
That's a good idea - I used a piece of old wire I had around as a tester, but it was a bit heavy and didn't work too well...
Thanks for the image, I'm not sure why I didn't stumble upon that thread on my searches...
