Author Topic: WTS Breakout board for Teensy 2.0 (Closed Both spoken for)  (Read 5200 times)
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Trade Count: (0)
  • Melvang's Desktop Customs
« on: Tue, 23 July 2013, 08:04:44 »
Looking for 2 people to purchase 2 of the 3 break out boards I ordered for a Teensy 2.0.  It has all the holes with solder pads for the legs to solder a Teensy 2.0 into with traces leading to another set of pads for soldering wires.  It also has holes in the corners to mounting with 6-32 thread screws via standard PC motherboard standoffs.
Cost will be $3.40 + shipping.  Conus only please.  Now to be considered for this please post a comment explaining your current build, estimated time of completion, and current state of said build.  The reason for this is because with my lack of electronics knowledge I want the first 2 to go to someone who has the ability to test and debug any issues with the current state of the break out boards.
If anyone wants to use the design untested it can be found at this threat reply #29.
Edit:  Many thanks to OldDataHands for doing the cad work for this.  Without him I could never and gotten this to work.
Melvang
Edit2:  Forgot to take the extra I paid for quicker shipping out before I divided cost by 3 for price per board.  Updated.
Edit3 : Both spoken for  Feel free to use the files from the link in the OP.
« Last Edit: Wed, 07 August 2013, 06:01:30 by Melvang »
  • Trade Count: (0)
Re: WTS Breakout board for Teensy 2.0
« Reply #1 on: Tue, 23 July 2013, 09:04:52 »
This is so cool, I'd buy one but have no projects so hopefully someone who can test it out ASAP will pick it up!! GLWS!!
  • Trade Count: (1)
« Reply #2 on: Tue, 23 July 2013, 09:10:45 »
That little board looks wicked!
Shouldn't there be another hole near the top right leg of the letter "H"?
I have been contemplating building another Teensy converter or 2, but would hate to hide that gem. It should be installed in a clear box if there is such a thing.
- D Trump 2026-10-24
Offline Melvang
  • Trade Count: (0)
« Reply #3 on: Tue, 23 July 2013, 09:24:33 »
If you are referring to the inside legs on the teensy which would be E6 on the bottom and not sure what the top one is but they follow a trace to the far bottom right and top right corner just to the left of the mount holes.
Here is a pic of the final boards, one being mounted onto standard PC standoffs.
29086-0
  • Trade Count: (1)
« Reply #4 on: Tue, 23 July 2013, 09:42:21 »
What does the bottom look like?
I have always used these 4 holes:
Offline Melvang
  • Trade Count: (0)
« Reply #5 on: Tue, 23 July 2013, 09:49:10 »
Tomorrow I will get my Teensy desoldered and have a closer inspection and be checking this out.  Will report back on this but counting the holes they are all there.
Offline alaricljs
  • I be WOT'ing all day...
  • Trade Count: (0)
« Reply #6 on: Tue, 23 July 2013, 09:53:38 »
The pic of 3 has the bottom... of the 3 shown, the left is one side and the right is the other.  Since this is a simple breakout board, top vs bottom doesn't matter as long as all your pins are lined up, the teensy has bilateral symmetry.
« Last Edit: Tue, 23 July 2013, 10:02:52 by alaricljs »
Filco w/ Imsto thick PBT
Offline berserkfan
  • Trade Count: (0)
« Reply #7 on: Tue, 23 July 2013, 09:58:21 »
I think it's awesomely responsible of you as a seller, to make sure the buyer is getting something that he can actually use.
Too many of us (including me of course) buy on impulse because something is cool and we hope to make good use of it someday, only to dump the goodie in a box somewhere and resell it after a year of inaction.
  • Trade Count: (0)
« Reply #8 on: Tue, 23 July 2013, 10:00:05 »
Am I the only one who think these would make awesome keychains!!
I'm serious....no spam, thread crapping or trolling intended.
Offline alaricljs
  • Trade Count: (0)
« Reply #9 on: Tue, 23 July 2013, 10:01:39 »
It wouldn't be too hard to make a neat design and have them made.  Could also include rounded corners (or make the whole thing round) so that you don't destroy your leg/pocket.  That's a whole other topic tho.
Offline esoomenona
  • Gnillort?
  • Trade Count: (0)
« Reply #10 on: Tue, 23 July 2013, 10:06:02 »
What do you do with a breakout board?
Offline alaricljs
  • Trade Count: (0)
« Reply #11 on: Tue, 23 July 2013, 10:08:28 »
It can be used to simplify attaching one device to another, or testing multiple copies of device A.  In this case, the purpose is to have physical tie-down points (the 4 standoff holes) and easy access to solder/resolder all the pin locations of a Teensy 2.0 without risk of damage to the Teensy.
Offline Melvang
  • Trade Count: (0)
« Reply #12 on: Tue, 23 July 2013, 10:10:03 »
The purpose of this board was so I could make use of the Teensy 2.0 in a hard wire matrix with a steel case and not have to worry about the wrong things shorting out and/or relying on an adhesive for mounting.
Offline bueller
  • MX baller
  • Trade Count: (0)
  • Church of the Ergo Clear
« Reply #13 on: Tue, 23 July 2013, 10:11:25 »
If you have trouble finding someone to test them in the US I'll take one for a future build. Currently working on a 65% and a game pad for a disabled friend of mine.
Offline esoomenona
  • Gnillort?
  • Trade Count: (0)
« Reply #14 on: Tue, 23 July 2013, 10:11:40 »
Wouldn't it be easier to provide a slot for the pins of a Teensy presoldered to a board, and then you could just plug it in when needed and unplug it later?
Offline Melvang
  • Trade Count: (0)
« Reply #15 on: Tue, 23 July 2013, 10:14:26 »
If I didn't already have my own monkey fist around a wooden bead for a keychain I would only be selling one of these.
Offline bueller
  • MX baller
  • Trade Count: (0)
« Reply #16 on: Tue, 23 July 2013, 11:28:20 »
Only problem with that is the headers would add too much height to fit in most cases. For a future build I want to try making a couple of additional layers for the bottom of the case to act as both keyboard feet and a place to house the controller and USB.
Offline Melvang
  • Trade Count: (0)
« Reply #17 on: Tue, 23 July 2013, 15:56:37 »
The plate I am using won't allow the use of a PCB  for the matrix but I am wondering if there is room to mount the teensy under this breakout board.  Will have to check that out tomorrow after work.
Offline Melvang
  • Trade Count: (0)
« Reply #18 on: Sun, 04 August 2013, 09:53:46 »
bump
Offline bueller
  • MX baller
  • Trade Count: (0)
« Reply #19 on: Sun, 04 August 2013, 10:22:46 »
I'd love a board but I'm outside the CONUS :(
Offline Melvang
  • Trade Count: (0)
« Reply #20 on: Sun, 04 August 2013, 16:27:04 »
Pm sent to you bueller.
Offline Tarzan
  • formerly known as Greystoke
  • Trade Count: (0)
« Reply #21 on: Mon, 05 August 2013, 10:44:07 »
I'd love to buy one off you, to complete my 122-key terminal board project, but realistically that will probably be a winter break project.  Any plans to make more PCBs?  Or can I replicate your order to the fab shop, "once more, with feeling?"
Offline Melvang
  • Trade Count: (0)
« Reply #22 on: Wed, 07 August 2013, 06:00:36 »
I apologize Greystroke but the 2 spares I have are spoken for.  Sorry for the lack of updates in the OP.  But feel free to use the files that are available in the link in the OP.
Offline Tarzan
  • Trade Count: (0)
« Reply #23 on: Wed, 07 August 2013, 10:02:11 »
Thanks, Melvang!
I may end up ordering a dozen of these, as I have some Alps boards that I want to convert to USB.  Although I think a Teensy is overkill to convert DIN/PS2 to USB, that's the only solution I've seen that doesn't involve using DIN-to-PS2 + PS2-to-USB adapters in a kludgey bundle of wire.
Offline Melvang
  • Trade Count: (0)
Re: WTS Breakout board for Teensy 2.0 (Closed Both spoken for)
« Reply #24 on: Wed, 07 August 2013, 10:09:58 »
Not a problem.  Just one thing if you post build logs on any of this please give OldDataHands credit for the breakout board.  It was my idea but his design and work on the design end.
Offline Tarzan
  • Trade Count: (0)
« Reply #25 on: Wed, 07 August 2013, 10:22:56 »
Absolutely!
By the way, the ordering process for OSH Park was pain free!  These are the first custom PCBs I've ever ordered, really opens my eyes to what's possible nowadays for the home hobbyist.
Offline Melvang
  • Trade Count: (0)
« Reply #26 on: Wed, 07 August 2013, 10:25:54 »
They were my first custom pcbs myself.  Just wait till you get them in.  They look amazing in person.  So much so mine will be visible in my project.
Offline Tarzan
  • Trade Count: (0)
« Reply #27 on: Wed, 07 August 2013, 10:28:58 »
I was also inspired by your mounting solution, so I ordered a couple of M2x050 taps and a bag of brass standoffs.  As nice as the mini-PCB looks in the pictures, I'm planning on leaving it without a case, so anyone opening the Model M or Focus keyboard in the future will see it immediately.
Imitation is the sincerest form of flattery, right?   :p
Edit: M3x050 taps...
« Last Edit: Wed, 07 August 2013, 10:31:33 by Greystoke »
Offline Melvang
  • Trade Count: (0)
« Reply #28 on: Wed, 07 August 2013, 11:02:07 »
Gotcha.  I just double checked the stand offs that I am going to be using on mine and the external threads on them are a M3x.5 and the internal threads are a 6-32.  Which is what the breakout board was designed to accept.
Offline bueller
  • MX baller
  • Trade Count: (0)
« Reply #29 on: Thu, 08 August 2013, 10:00:03 »
Good to know, I just found an electronics shop around the corner that sells every standoff imaginable so this should make life much easier.
