Author Topic: 55g and 62g spring  (Read 3310 times)
Offline turtle
55g and 62g spring
« on: Tue, 23 July 2013, 10:13:16 »
Hi I have purchased 55g and 62g springs from a recent gb. I am planning to use 62g on my clears (heard a lot of prefer that set up). I am wondering if anyone use 55g and what switch you use? Trying to put these in use! Thanks in advance for the help!
Offline turtle
Re: 55g and 62g spring
« Reply #1 on: Wed, 24 July 2013, 15:23:49 »
Bump.
« Reply #2 on: Wed, 24 July 2013, 15:25:54 »
55g are far too light for me and I didn't even bother looking into them. I did try 62g and documented my thoughts in a review thingy. I've heard people like 55g Clears and Whites but I've mostly ignored that spring weight.
Offline Larken
« Reply #3 on: Wed, 24 July 2013, 22:41:24 »
I use 55g ergoclears. My favorite switch, even though I know not every one will like it. It's fine for typing, but I don't like it for gaming (although it can be used). I just type alot on it. 55g clears aren't meant for use on modifier keys either, imo. I do it with a mix of ergoclears and browns for mods.
62g on the other hand, feels too stiff for me, but I've always preferred light switches.
| Ergodox #1 | Ergodox #2 |
Offline TimIsABat
  • MX Clears are life
    • Instagram
« Reply #4 on: Fri, 26 July 2013, 00:10:43 »
I went from using the very light MX red switches to 62g clears on my Poker.
I have to say. The heavier weight feels so much better as it feels more like a cushion than strain.
I bottom out and avoid misclicks more than when I used a lighter spring. So, I would say go with the 62g spring, and maybe lube them (don't know how this feels yet but have read that it just has a nicer feel to them).
Leopold FC660M MX Reds | Poker X 62g  Ergoclear modded and plate modded (out of comission) | IBM Model M 1391401 | Dell AT101 | Compaq RT101 | HHKB Pro 2 | WASD CODE TKL MX Clears
Avid vape collector and advocate. I used to work at to renowned vape shops here in New Jersey. Message me for any vape related questions.
Main driver : WASD CODE TKL MX Clear
