Author Topic: Looking for a Tenkeypad/Number Pad  (Read 7953 times)
Offline audukent
« on: Tue, 23 July 2013, 12:19:13 »
Looking for a sweet number pad... any suggestions?  Mechanical one of course.  I have a race mini and was hoping to find a number pad to accompany it.
« Last Edit: Tue, 23 July 2013, 12:21:36 by audukent »
[LZ-GH - 62g mx greens and 62g mx clears]    [Ducky Shine - mx browns]    [RACE mxMini - mxreds]  [POKER II - mx Blacks]    [KPAD - 62g mx blacks]
Offline whiteduck
Re: Looking for a Tenkeypad/Number Pad
« Reply #1 on: Tue, 23 July 2013, 12:24:24 »
http://elitekeyboards.com/products.php?sub=leopold,tenkeypads&pid=fc210tpnb
I grabbed this one and am digging it.  Same keys as my leopold 660c but now I'm freaking out using the topre switches for keyboard and browns for numpad #OCD
-wd
Offline esoomenona
  • Gnillort?
« Reply #2 on: Tue, 23 July 2013, 12:26:49 »
Take a look at the Leopold 210TP over on elitekeyboards. I've been thinking about getting one of those. Nice and sleek with a tight bezel.
If you want programmability, look into a mode 4 G80-3700 (MX 3700).
If you want to spend money, EK also has the Topre 23U.
And then there's the Filco one, though unless you care about matching it to a Filco keyboard, I don't see a reason to get anymore with the introduction of the Leopold, which just looks better all around (though I have yet to compare the two physically).
Offline badcop
  • thorpe thocking master race
« Reply #3 on: Tue, 23 July 2013, 12:33:40 »
go with the leo.  the filco has a stupid 00.
Offline audukent
« Reply #4 on: Tue, 23 July 2013, 12:35:10 »
Yeah, I'm definitely liking that Leo.
Badcop, how you liking that mx green poker?  I'm thinking of indulging >=)
Offline badcop
« Reply #5 on: Tue, 23 July 2013, 12:37:50 »
its "ghetto green" with a green spacebar  :D.  i like it a lot.  it feels very authoritative and strong.  its my daily driver at home.
Offline audukent
« Reply #6 on: Tue, 23 July 2013, 12:39:40 »
haha elaborate on 'ghetto green'.  I was going to start sourcing for green switches and now you've got me thinking ;__;
« Reply #7 on: Tue, 23 July 2013, 12:40:54 »
Ghetto Green = MX Black spring + MX Blue stem.
Offline esoomenona
  • Gnillort?
« Reply #8 on: Tue, 23 July 2013, 12:41:48 »
Also, if you're looking for some Korean in your life, look into the KMAC Pad or the GON Kitty Pad. (There is also a 356Pad, but it is rare and expensive...)
Offline audukent
« Reply #9 on: Tue, 23 July 2013, 12:49:27 »
This made me crack up.  Of course I would like some Korean in my life.  KMAC pad? GON Kitty?  I'll have to check these out.
Thanks for the clarification, sir!  I see, that would imitate the same experience as a green switch.  How well does it hold to the green switches?  I know the greens are hard to find and are close to 60-80 cents a switch.  Is it worth it?  If the 'ghetto greens' are legit, did you do it yourself?
Offline badcop
« Reply #10 on: Tue, 23 July 2013, 12:50:32 »
like cpt said, black springs and blue stems.  i started with blues and harvested the springs from one of these - http://www.ebay.com/itm/G80-11900LUMEU-0-Cherry-Model-MX-11900-USB-CYA-White-Keyboard-W-Touchpad-/271225181010?pt=PCA_Mice_Trackballs&hash=item3f2647d352
and when you're done making ghetto greens you end up with a bunch of ghetto reds haha
Offline badcop
« Reply #11 on: Tue, 23 July 2013, 12:51:57 »
i cant tell the difference between the green switch and the ghetto greens by feel alone if that makes you feel better.  i'll try and do a quick ripometer when i get home to check weight.
« Reply #12 on: Tue, 23 July 2013, 12:52:10 »
I think Ghetto Greens feel pretty much the same as Greens. I got a deal on a QFR with Greens in it that I cannibalized for use in my KMAC. It's pretty easy to do the mod though.
If you're interested, I wrote a review on the Filco Numberpad.
Offline audukent
« Reply #13 on: Tue, 23 July 2013, 12:54:28 »
Great review on the pad bro.  I just finished reading it as you sent it over.
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #14 on: Tue, 23 July 2013, 12:56:22 »
I had a stock green as my spacebar and it felt heavy as all hell, so I swapped a black spring in and it definitely felt lighter. I wouldn't say they're the same, unless the spring that was in my green switch wasn't a green spring :eek:
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline audukent
« Reply #15 on: Tue, 23 July 2013, 13:18:19 »
Looks like I'm going to have to find some green switches.  Curiosity is getting the best of me.
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #16 on: Tue, 23 July 2013, 13:40:10 »
Buy a green QFR :)
TOO BAD FOR YOU
Offline badcop
« Reply #17 on: Tue, 23 July 2013, 15:27:02 »
ok here it is.  i did a quick test of my ghetto greens.  take a look at the link below.
http://imgur.com/a/XWOKU
teaser!
« Reply #18 on: Tue, 23 July 2013, 15:28:59 »
That's cute. I always wondered what the weight tolerances on nickels and dimes were.
Offline esoomenona
  • Gnillort?
« Reply #19 on: Tue, 23 July 2013, 15:33:09 »
+/- 5g...
Offline whiteduck
« Reply #20 on: Tue, 23 July 2013, 15:35:44 »
somone does not know of the rip-o-meter?  for shame!
j/k <3
-wd
Offline velvetdon25
« Reply #21 on: Thu, 25 July 2013, 07:48:57 »
I got myself a filco Tenkeypad that only comes in brown. If your looking to try topre you could give their number pad a try, though you might just go ahead and purchase a topre board altogether once you fall with it lol.
Offline audukent
« Reply #22 on: Thu, 25 July 2013, 07:58:20 »
I'm thinking of going with the GON Kitty Pad.  See the thread below.
http://geekhack.org/index.php?topic=44147.0;topicseen
