Author Topic: Got a defective keyboard, what are my options?  (Read 2102 times)
Offline 3doog
« on: Tue, 23 July 2013, 22:13:20 »
Just got a FC660M from qtan and the 'i' key doesn't work. I am still waiting his email response to this.
Does anybody know what could cause the 'i' key to not work? What are my options?
I don't know how qtan deal with this, does anybody have an experience with defective product from qtan?
Can I just fix it myself?
WASD Keyboard V1
Offline Photoelectric
Re: Got a defective keyboard, what are my options?
« Reply #1 on: Tue, 23 July 2013, 22:18:49 »
If you can't get it resolved with qtan, the next step would be to check the switch: if could have a bad solder joint, in which case you just need to resolder it.  Could be the actual switch mechanism being faulty.  Either way, resoldering the existing switch or swapping in a new Blue switch will most likely fix it.  These things can happen, sadly.
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #2 on: Tue, 23 July 2013, 22:58:02 »
I have a defective keyboard from him. I e-mailed him asking what I can do, and he told me I can return it for a refund.
