Author Topic: Need help repair keyboard  (Read 2420 times)
Offline 3doog
« on: Wed, 24 July 2013, 11:24:39 »
So I got my keyboard and the 'i' key doesn't work. Didn't want to return it if I can fix it myself.
I did a continuity check on the 'i' switch and it beep when I pressed it, so it's suppose to be alright, but if I check the voltage, when I pressed the switch it does not become equal between the two legs of the switch. Other switch voltage became equal when press it. If I short the two legs of the switch, then a press is registered.
 What does this mean? Bad solder joint?
« Last Edit: Wed, 24 July 2013, 11:26:28 by 3doog »
WASD Keyboard V1
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
Re: Need help repair keyboard
« Reply #1 on: Wed, 24 July 2013, 11:27:29 »
Could be a bad diode maybe?
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline 3doog
« Reply #2 on: Wed, 24 July 2013, 11:30:14 »
But if I short the switch, a key press is register.
WASD Keyboard V1
Offline 3doog
« Reply #3 on: Wed, 24 July 2013, 11:53:56 »
AHHHHHHHH, it's a bad joint, resoldered, fixed!  :p :p :p
WASD Keyboard V1
« Reply #4 on: Wed, 24 July 2013, 11:57:16 »
Glad you got it sorted out.
Offline 3doog
« Reply #5 on: Wed, 24 July 2013, 12:11:27 »
Thanks  ;D
WASD Keyboard V1
