Author Topic: Dell AT101W anyone?  (Read 2294 times)
Offline blueSmoke
  • Life is what happens while you're busy Fixing RSI
Dell AT101W anyone?
« on: Thu, 25 July 2013, 04:45:03 »
Pretty cheap at 27$ each. He says he has 7 available tho I think he may have more. Black ALPS sliders, keys need cleaning/retrobriting. Good for some sort of projects, or may be replace the blacks with macally clears?
http://www.ebay.com/itm/Vintage-Dell-AT101W-Wired-PS-2-Alps-CM-Clicky-Standard-Discolored-Keyboard-/121145445845?pt=PCA_Mice_Trackballs&hash=item1c34d4cdd5
Model M, Filco Tenkeyless White, Few others, few more others, Noise-hater (ongoing project), blah-blah (to be fillled later...)
Re: Dell AT101W anyone?
« Reply #1 on: Thu, 25 July 2013, 05:42:51 »
Curious to try one, but not at the price it would cost to get one to Australia.
And not that yellow.
Offline Techno Trousers
  • ʘ_ಠ
« Reply #2 on: Thu, 25 July 2013, 07:19:58 »
He's been posting these up one at a time for a while now. Must be blowing out final stock now. That is a great price if you've got the patience for retr0brite.
« Reply #3 on: Thu, 25 July 2013, 07:39:13 »
I would say that is about the going rate. If you have patience you would probably get a better one for that price ($31 shipped).
I have tried Retr0brite and never had success. Keys always turn upside-down. I recently got a rubber dome board with MX-style keys, and I plan to glue a set of plunger stems to the bottom of a pan, put the keys in, and fill to cover them with liquid. I feel sure that it will work well.
But I have never seen anything that would hold Alps keys upright, have you? Otherwise, how do you do it?
« Last Edit: Thu, 25 July 2013, 07:45:18 by fohat.digs »
- Oliver Willis 2026-08-01
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #4 on: Thu, 25 July 2013, 10:02:17 »
oxyclean+hydrogen peroxide+sunlight.............
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
  • ʘ_ಠ
« Reply #5 on: Thu, 25 July 2013, 11:46:48 »
I have a board awaiting retr0briting, and I'm planning to do the "paint on gel" method from retr0bright.wikispaces.com so I don't have to leave them immersed.
« Reply #7 on: Fri, 26 July 2013, 19:29:28 »
Prepare to be amazed.
Less than 48 hours after posting that, I find an old Packard Bell keyboard at a salvage store for $3. I almost avoided even touching it, since I have bought a couple of old Packard Bells in the past for their MX-compatible but unexciting ABS key caps, and I don't even need them. (plus, they have bigass Enters and 1.25 Escapes) But curiosity got the best of me, and I popped a cap.
It looked to be Alps-compatible, so I bought it. I got home, and it actually worked! And, although ABS, it looks to be a decent-quality laser printing job!
Almost as important, if not more so, I got a set of Alps-compatible plunger stems, so I can do the same thing and glue them to the bottom of a pan for retr0briting Alps caps from those old Apples.
For keyboard science!
