Author Topic: HHKB Row Heights  (Read 3985 times)
Offline growler
HHKB Row Heights
« on: Thu, 25 July 2013, 06:06:24 »
Hi,
I have done some searching for this, but not managed to find a data sheet or similar to give me confidence I have the right answer ...
I like the idea of a light blue or other wasd mod, but ... I use vim/i3 and basically hjkl are my arrow keys for everything. I guess the ASD are on the same row, so that would fit 3 of the 4 keys, but is the W the same size as the keys below?
The other thing I am considering is buying a completely blank topre for realforce set, just pilfering the keys from that. At least this one set could do keyboards as I could also pinch the F and 3 others from this row and maintain the 'bump' on the J key. Obiously this only works for completely blank keysets.
Any thoughts on this, or have I missed something very simple?
Don't just stare at it ...
Offline Dgsbllx
Re: HHKB Row Heights
« Reply #1 on: Thu, 25 July 2013, 06:11:43 »
W is a different profile to A, S + D
Offline growler
« Reply #2 on: Thu, 25 July 2013, 07:41:43 »
Fair enough, thanks.
What about the ASDF rows on Realforce -vs- HHKB, are they at least the same do you know?
Offline Dgsbllx
« Reply #3 on: Thu, 25 July 2013, 07:45:48 »
I'm going to say they are the same because i have an Orange WASD set from Elitekeyboards which fits Topre Realforce and HHKB
Offline growler
« Reply #4 on: Thu, 25 July 2013, 08:06:46 »
Right then. Should I go for $110 realforce blank set, to get two usable hjkl sets... I guess EK is the only place to buy these?
Hmm, there is some Japan festival on in London this weekend, maybe there is a PFU or Topre stand!? :P
Offline cdmccart
« Reply #5 on: Thu, 25 July 2013, 11:49:12 »
I saw on another thread that someone has a hhkb pro jp and they purchased a blue set of topre keys off amazon JP.
http://www.amazon.com/Topre-Japanese-Replacement-Realforce-Sa0100-kt2/dp/B004U8IVPE/ref=sr_1_4?s=electronics&ie=UTF8&qid=1374770903&sr=1-4
Offline growler
« Reply #6 on: Thu, 25 July 2013, 12:02:00 »
Nice spot! I'll see if I can find any blank sets... might work out a bit cheaper.
Offline cdmccart
« Reply #7 on: Thu, 25 July 2013, 13:27:50 »
I think the only issue you will encounter with the realforce keys is the issue with the Right shift.  There isn't a direct key swap.  I've heard of people rotating caps lock (?) to achieve it.
I'm thinking about swapping the alphabet keys / numbers for something similar to the blue.  I'll leave all the other grey keys alone.  I'll post pics when i find money for it [or land on community chest]
Offline cdmccart
« Reply #8 on: Thu, 25 July 2013, 14:53:10 »
found the missing link (sort of)
jdcarpe is behind this one:
http://deskthority.net/photos-videos-f8/hhkb-pro-jp-t3524.html
the board I was thinking of earlier...
now, do these keys also work on the standard HHKB pro 2?  maybe someone else can fill in that answer.
thanks!
