Author Topic: I found this at a secondhand market for 1.5€ need some help  (Read 1371 times)
Offline harghan
Hello,
I love mechanical keyboard and i seek them at Second hand markets.
I found this one for 1.5€ (initially 5€:D)
He look like this:
http://imgur.com/5tnX2FL,R0t2QXb,DxbTRqi,fxgDA2d,Mla5FAI,xTzznwb,KDDGwo3,JttO6Nq#1
http://imgur.com/5tnX2FL,R0t2QXb,DxbTRqi,fxgDA2d,Mla5FAI,xTzznwb,KDDGwo3,JttO6Nq#2
http://imgur.com/5tnX2FL,R0t2QXb,DxbTRqi,fxgDA2d,Mla5FAI,xTzznwb,KDDGwo3,JttO6Nq#3
http://imgur.com/5tnX2FL,R0t2QXb,DxbTRqi,fxgDA2d,Mla5FAI,xTzznwb,KDDGwo3,JttO6Nq#4
http://imgur.com/5tnX2FL,R0t2QXb,DxbTRqi,fxgDA2d,Mla5FAI,xTzznwb,KDDGwo3,JttO6Nq#5
http://imgur.com/5tnX2FL,R0t2QXb,DxbTRqi,fxgDA2d,Mla5FAI,xTzznwb,KDDGwo3,JttO6Nq#6
http://imgur.com/5tnX2FL,R0t2QXb,DxbTRqi,fxgDA2d,Mla5FAI,xTzznwb,KDDGwo3,JttO6Nq#7
So, Wich mechanical key is it ???
The keyboard itself works, and AWSOME FEEL WHILE WRITING WITH IT, except the spacebar the edge hurt my thumb as ****.
2nd Question:
I broke my W key here: http://imgur.com/5tnX2FL,R0t2QXb,DxbTRqi,fxgDA2d,Mla5FAI,xTzznwb,KDDGwo3,JttO6Nq#0
Can i replace it ?
Like i don't use the scroll lock key, how could i replace the mechanism of the scoll lock key to the W ?
Any idea ?
Does this keyboard is fine ?
Btw im french so the azerty layout is perfect for me ;)
Re: I found this at a secondhand market for 1.5€ need some help
« Reply #1 on: Thu, 25 July 2013, 11:54:00 »
It's an NMB/Space Invader switch.
You probably could replace that switch if you can find a replacement...which will be the hard part.
Offline harghan
« Reply #2 on: Thu, 25 July 2013, 12:00:19 »
Can i take the scroll lock key mechanism and replace it on the W, or i have to find a brand new ?
« Reply #3 on: Thu, 25 July 2013, 12:13:13 »
Yes, that is what I would do.
- Oliver Willis 2026-08-01
