Author Topic: ebay: Bundeswehr Keyboard  (Read 6858 times)
Offline lcs
  • Lover of Grape Drank
  • はやく
Re: ebay: Bundeswehr Keyboard
« Reply #1 on: Thu, 25 July 2013, 13:27:09 »
It has nice colours!
Offline foxtrott
« Reply #2 on: Thu, 25 July 2013, 13:31:40 »
yes...  but which switch ?
Offline Tarzan
  • formerly known as Greystoke
« Reply #3 on: Thu, 25 July 2013, 13:41:30 »
I have no idea what switch it uses, but I want one.   ;D
Can you proxy for me?
Those keycaps look like one of the forum pics on DT, different colors though.
Edit: After some quick searching, it looks like a Tandberg Data keyboard, usually sold as terminal keyboards with Norsk Data systems:
http://en.wikipedia.org/wiki/TDV_2200
I also found a PDF of a Norsk Data terminal user manual, and if the picture on page 52 is correct, the keyboard may have MX-compatible keycaps.  I've also seen other references on DT to this brand using foam-and-foil switches, which were pretty common in the 1980s.
https://2cdd03e6-a-62cb3a1a-s-sites.googlegroups.com/site/tingox/TDV-393541-0-EN%20TDV%202200%20Hardware%20Manual.pdf?attachauth=ANoY7cpPg-W2KaKQM5eD3gG76M0vM9J4Edh1ugGhlHJg9Ciq-_Qxsk8B1oFL4CShAalOfHE5FrqFvHrq7Jztajz1HBGxUpSATVSz7hIvyDLvOivpdGmEsnuGqtESbqgTmeOu4IHOZ0QVUEqTDML3IptgSFpDtqO4Un-Szw7IKRVlW39eYOXSRfkJAPhENhEWtdq7yfHHZNib7FuA66-Z-zAVS1CHUmu_B4O6SS-RqdDUCS1s_RMe4SpqZ2VuEOpSbslctgH_eYxS&attredirects=0
« Last Edit: Thu, 25 July 2013, 13:58:19 by Greystoke »
Offline Halvar
Offline Tarzan
Offline foxtrott
« Reply #6 on: Thu, 25 July 2013, 14:24:34 »
I have here something from Bundeswehr too. .. but I can not sell because I do not have 60 posts ..
with Doubleshots and Marquart..
Offline Tarzan
« Reply #7 on: Thu, 25 July 2013, 14:32:03 »
Yeah, I bought four of those from the eBay.de seller.   :p
Only kept one for myself, and might be interested in a second one, but shipping costs for those slabs of aluminium are crazy.  Let me think it over, and I'll let you know by Monday!
You'll get to 60 posts in no time, don't worry.
Offline foxtrott
« Reply #8 on: Thu, 25 July 2013, 14:48:46 »
ok i´m waiting.. .. way, I have all the caps yet .. but the F7 button is broken
you're right .. The keyboard is very heavy  ;D
Offline Halvar
« Reply #9 on: Thu, 25 July 2013, 15:11:39 »
Are you sure? Colors and design are definitely very nice, but it's not a PC-compatible keyboard controller, the switches are unbeknownst to most of mankind, the caps are doubleshot but flat, the layout will be hard to use with a PC, and it's used.
If you still want it and you don't work out anything with foxtrott I can proxy.
Offline Tarzan
« Reply #10 on: Fri, 26 July 2013, 08:44:13 »
I'm afraid you're right.  As much as I love the look of those keycaps, knowing they'd take major modification to make them work on MX switches takes a lot of the appeal out of it.   :'(
They are beautiful, though...
Has anyone made a converter for this keyboard?  Until now I'd never even heard of RAFI switches.
Offline SeriouSSpotS
  • 60% is love, 60% is life
« Reply #11 on: Fri, 26 July 2013, 09:32:10 »
I really like those colours.
« Reply #12 on: Fri, 26 July 2013, 10:33:29 »
rafi switches are the hall effect ones used by cortronics, and others. There are a few keyboards with them on eBay. A surplusser didn't have any luck selling them and recently relisted all his. If you're interested, I can find the link. They were $80-$120 or best offer depending on condition.
you can get rafi hall effect swithces that use a dome for the spring, it's one of the few domes based boards with nkro. there were a few devlin ones that popped up in canada not too long ago that I should have bought but didn't
Offline poxeclipse
  • Hit me with music ... yes, me friend
« Reply #13 on: Fri, 26 July 2013, 18:22:38 »
Some newer versions have ML switches.
Offline OleVoip
« Reply #14 on: Sat, 07 February 2015, 14:54:53 »
These keyboards were made by Tandberg Data A/S and have Siemens STB 21 switches, not RAFIs. Siemens controlled Tandberg Data when these keyboards were made.
