Author Topic: Keycap suggestions for Quickfire XT  (Read 2904 times)
Offline Flyersfan1
  • Hi!
« on: Thu, 25 July 2013, 21:25:32 »
Hey friends! I'm getting my new Quickfire XT in the mail tomorrow and would like to waste no time in getting a new set of keycpaps on it.  I'm super excited to try the board out, but I read somewhere on this forum that the stock key caps leave a little to be desired.  Ideally, I'd love to throw a set of the ninja key caps that come on Filco's but I haven't been able to find any place that actually sells them separately.  I would jump into some of the key cap group buys that are done through this community but I unfortunately do not use Paypal so that kind of limits what I can and can't purchase from here.  I was just wondering if anyone had any suggestions for a good set I could look into.  Thanks so much!
Quote from: Photekq
Re: Keycap suggestions for Quickfire XT
« Reply #1 on: Thu, 25 July 2013, 21:41:55 »
You can buy key caps at techkeys.us or mechanicalkeyboards.com or from feng's eBay store
And why no PayPal, its really convenient.
Offline Flyersfan1
  • Hi!
« Reply #2 on: Thu, 25 July 2013, 21:47:24 »
I had a bad experience with them regarding a fraudulent buyer on eBay a few years ago.  I was just really put off by the whole situation that I decided to stop using their services.  I'll probably come around soon and reactivate my account since it seems to be what most people on this website use.  I have been using Amazon Payments for a little while and seems to be just as good, just not as widely used.   Thank you so much for referring me to those places, i'll be sure to check both out.
Quote from: Photekq
Offline jameslr
« Reply #3 on: Thu, 25 July 2013, 23:37:41 »
Not trying to threadjack, but I'm in the same boat as you. I just got a QFR and I want PBT dye sub caps for it. The same color scheme as the dark grey and blue Ducky G2 on MK here: http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=473 .
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
Offline TimIsABat
  • MX Clears are life
    • Instagram
« Reply #4 on: Thu, 25 July 2013, 23:49:40 »
Unicorn vomit.
Leopold FC660M MX Reds | Poker X 62g  Ergoclear modded and plate modded (out of comission) | IBM Model M 1391401 | Dell AT101 | Compaq RT101 | HHKB Pro 2 | WASD CODE TKL MX Clears
Avid vape collector and advocate. I used to work at to renowned vape shops here in New Jersey. Message me for any vape related questions.
Main driver : WASD CODE TKL MX Clear
Offline mroldmanfunk
« Reply #5 on: Fri, 26 July 2013, 01:52:36 »
You could make your own design using the wasd website.
http://www.wasdkeyboards.com/index.php/wasd-v1-custom-keyboard.html
« Reply #6 on: Fri, 26 July 2013, 06:52:48 »
Oh and I forgot about sherryton, you can get some GMK caps from originative.com
Offline Flyersfan1
  • Hi!
« Reply #7 on: Fri, 26 July 2013, 09:14:37 »
Thanks Ray, you've been a big help.   :D
Quote from: Photekq
Offline suparnemo
« Reply #8 on: Fri, 26 July 2013, 16:42:13 »
I've been looking for some like this too.
