Author Topic: Wood polishing systems?  (Read 2174 times)
« on: Fri, 26 July 2013, 02:59:03 »
I don't know how much experience many of you aside from The_Beast have with wood working, but I've been looking for some affordable wood buffing systems to give a nice lustrous finish to some of my projects.  I can't seem to find any in the $50 or less range though.  The closest good one I found is the Beall system that comes with three wheels, a Tripoli bar, a white rouge bar, and a bar of Carnuba wax, but it's $75 and I'm not 100% sure it would work with my lather (stupid thing uses a #0 Morse Taper, an uncommon taper for lathes.
Anyone know of any decent affordable linen/cotton buffing wheels that can work with a drill or standalone motor or any other affordable systems?
Offline esoomenona
  • Gnillort?
Re: Wood polishing systems?
« Reply #1 on: Fri, 26 July 2013, 03:11:18 »
I call them hands.
And oh do I polish my wood with them.
Offline asura
  • not a duck
« Reply #2 on: Fri, 26 July 2013, 03:48:39 »
Something like these any use?
Cotton buffs.
Felt buffs
« Reply #3 on: Fri, 26 July 2013, 06:50:36 »
I call them hands.
Does that help with your typing on switches that otherwise might be considered 'heavy'?
Offline pasph
« Reply #4 on: Fri, 26 July 2013, 07:29:05 »
I call them hands.
Offline esoomenona
  • Gnillort?
« Reply #5 on: Fri, 26 July 2013, 07:36:02 »
I call them hands.
That's about what it's like for me.
« Reply #6 on: Fri, 26 July 2013, 11:46:24 »
The problem with that is that a French Polish is a more brittle finish than others.  You can get a more durable finish by working down to a fine grit sand paper, then onto pumice stone and rottenstone, Tripoli bar to white rouge, or white rouge on a buffing wheel, then finish with Carnuba wax.  You can get a high gloss from poly too, but I really hate polyurethane.
