Author Topic: WTS 38GT PCB and alu plate (CONUS)  (Read 3528 times)
Offline laden3
  • Trade Count: (0)
« on: Fri, 26 July 2013, 07:37:24 »
http://imgur.com/OTKl0YB
Bought these from GON but they don't fit in the case that I am currently using.
The plate is hard anodized.
Trying to recoup the money I spent on these, so $87 for both. $3 shipping in CONUS. Free diodes will be included.
SOLD And thank you for those kind words and being interested.
« Last Edit: Sat, 27 July 2013, 23:50:02 by laden3 »
I rrrove brrracks.
  • Trade Count: (0)
Re: WTS 38GT PCB and alu plate (CONUS)
« Reply #1 on: Fri, 26 July 2013, 07:41:01 »
GLWS!
Offline BunnyLake
  • The OG HHKB Master
  • Trade Count: (3)
  • X
« Reply #2 on: Fri, 26 July 2013, 07:43:54 »
gorgeous board to have an work on
glws sale, it should go pretty snappy
Offline danielucf
  • Horrible Mailman
  • Trade Count: (0)
  • Hmmmm beer.
« Reply #3 on: Fri, 26 July 2013, 08:33:44 »
What case did the plate not fit? I was planning to get a couple of those plates.
Offline boost
  • BOSTMOBILE
  • Trade Count: (0)
  • NY Giants!!!
« Reply #4 on: Fri, 26 July 2013, 08:43:56 »
would you just sell the PCB?
-Enzo Ferrari
Offline duc_nckt
  • Trade Count: (0)
« Reply #5 on: Fri, 26 July 2013, 09:01:27 »
pm'd
Offline ninjadoc
  • Trade Count: (0)
« Reply #6 on: Fri, 26 July 2013, 15:28:43 »
Gotta repeat Danielucf's question "What case did you try to put that in?" Once you flip the plate over the hole's appear to match a Poker case which there are several group buys going on right now. From my understanding it would not fit a Vortex case and the PCB doesn't have a hole between the G & H but I think the other holes would match a PURE case. I may be misspeaking, if so please correct me so I will learn.
  • Trade Count: (0)
« Reply #7 on: Fri, 26 July 2013, 15:30:23 »
38GT is a 60% board. Vortex is a TKL case so they wouldn't fit. I'm not actually sure what cases the 38GT fits in though.
Offline ninjadoc
  • Trade Count: (0)
« Reply #8 on: Fri, 26 July 2013, 16:36:02 »
Duh! I knew I would misspeak on something. I read about some problem with a Vortex case and I thought it was dealing with a 60% board, Guess not though.
Offline remedyhalopc
  • Trade Count: (0)
« Reply #9 on: Fri, 26 July 2013, 19:33:05 »
I'd be super interested in this if I knew it could fit the Poker 2 casing, Poker X, or Pure.
Offline Smeagol_RP
  • Trade Count: (0)
  • your ad here
    • Steam
« Reply #10 on: Fri, 26 July 2013, 21:38:43 »
Noob question: Excluding switches and leds, what more do I need to buy to assembly it?
  • CM QFR (Clears) | CM QFR (Blues) | KBT Poker II (62g Browns) | CM Alcor
Offline gnubag
  • Trade Count: (0)
« Reply #11 on: Fri, 26 July 2013, 21:45:52 »
there is no picture of the other side of the pcb but I think you need diodes too.
Offline codyeatworld
  • Trade Count: (0)
« Reply #12 on: Fri, 26 July 2013, 22:11:25 »
You need thru hole diodes and smd resistors along with LEDs and switches.
Offline pmh1410
  • Trade Count: (0)
« Reply #13 on: Sat, 27 July 2013, 04:05:22 »
I think that he need more 1set of Cherry PCB mount Stabiliser with spacebar 6.25x wire.
