Author Topic: K65 - Awesome Keyboard  (Read 4334 times)
Offline jaboki
« on: Fri, 26 July 2013, 12:29:26 »
Since joining the forum not too long ago, I picked up the PokerII since it seemed like one of the popular keyboards to have here. Ever since using it, I can never go back to a normal keyboard, and I needed another keyboard for home use since the PokerII I needed to use primarily at work. I needed something with arrow keys, because the arrow keys on the PokerII were sort of a pain to use when I wanted to quickly access the arrow keys.
I purchased the Corsair K65 from amazon, and man am I happy I did. It is very well built and compact. It works just as well as the PokerII and is awesome to type on. I think most people don't like Corsair's first iterations of mechanical keyboards. All I can say is, in reference to the PokerII, this keyboard is just as good (if not better). Just my .02
Offline Photoelectric
Re: K65 - Awesome Keyboard
« Reply #1 on: Fri, 26 July 2013, 12:32:14 »
Thanks for sharing :)  If you like the small size of the Poker but want arrow keys, I'd recommend looking at Leopold FC660M keyboards.
That one might be my next keyboard if I end up needing a small one.  Plus most of the caps are standard size.
« Last Edit: Fri, 26 July 2013, 12:34:58 by Photoelectric »
Offline HoosTrax
« Reply #2 on: Fri, 26 July 2013, 12:32:47 »
It bugs me that Corsair went with non-standard key sizes on the bottom row. I mean why? It's a TKL, but it can't use a normal TKL keyset.
« Last Edit: Fri, 26 July 2013, 12:35:03 by HoosTrax »
« Reply #3 on: Fri, 26 July 2013, 12:39:57 »
thanks for your thoughts. I think some of why people didn't' like the older corsair keyboards was that the function keys were membrane, and there was some trouble with the controller.
If I may just ask out of curiosity, what switches did you end up with?
Offline jaboki
« Reply #4 on: Fri, 26 July 2013, 12:50:30 »
I believe the K65 only comes with cherry reds, which is what I prefer. I got the PokerII in reds as well.
I saw this one, but to be honest... I was turned off by the placement of the top right buttons.
For me, I'm not really a keyboard "hipster" and I don't need to have fancy keycaps. :)
« Reply #5 on: Fri, 26 July 2013, 14:08:11 »
Completely agree, but, then again, you have to expect something like that from Corsair.  I'd expect them to give some response like "it's better for gaming" if they were asked, then two weeks later, they'd release a thin ABS "gaming" pack for the bottom row and charge $50 + shipping for it.
Offline Lu_e
« Reply #6 on: Fri, 26 July 2013, 14:23:55 »
Didnt even notice the mix of 1.25x and 1.5x ...disappointing since I like the look. Whats the spacebar end up as? something you will never find? although it would be pain, you could get mixed modifiers... just not sure on the spacebar layout. Both size and stem/switch placement.
Just say NO to ABS keycaps
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #7 on: Fri, 26 July 2013, 14:28:54 »
You'd have to get the mother-of-all-Tsangans kits to make any set work with that.
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline HoosTrax
« Reply #8 on: Fri, 26 July 2013, 14:53:19 »
Shame too. It would have been a perfect alternative to the QFR Red, since it has a aluminum base and is about the same price.
Offline Vehementi
« Reply #9 on: Thu, 08 August 2013, 13:27:51 »
I was looking at this keyboard because it's on sale on NCIX, but I don't understand what you mean about smaller keys (caps?).  Could someone please explain a bit for me?  Everything looks normal on GIS except the F-keys being close to the number row...
edit: oh derp, the tiny win keys. Right...
« Last Edit: Thu, 08 August 2013, 13:34:55 by Vehementi »
Offline Hypersphere
« Reply #10 on: Fri, 09 August 2013, 15:27:28 »
Like the look of the Corsair 65 keyboard, although if the dimensions I have for it are correct, it is wider and deeper than a Filco TKL. Good price. Would be nice if it came with a choice of Cherry switches.
If you are looking for a true 60%+ layout, I would second the vote for the Leopold FC660M (Cherry switches) or FC660C (Topre switches). I was initially put off by the seemingly odd placement of the arrow cluster and insert/delete keys, but after using the FC660M, it has become one of my favorite boards. It is natural to type on with its standard key sizing and placement, it has dedicated arrow keys, and the Fn layer is minimal and intuitive. Plus the PBT keycaps feel great.
However, what I would really like to see is something like a Keycool 84 layout, but with the F-key row removed and relegated to the Fn layer.
Offline Sinzz
« Reply #11 on: Sat, 10 August 2013, 04:51:04 »
I too would like a keyboard like the one that rjrich proposed. just a little longer than the regular 60% keyboard, though I'm not complaining since the Pure Pro meets all my requirements anyways and the home end pg up pg down keys aren't that difficult to use.
Keycool 84 MX Blue | Pure Pro | HHKB Pro 2
Offline Hypersphere
« Reply #12 on: Sat, 10 August 2013, 09:05:00 »
I agree that Home, PgUp, etc. are relatively easy to access in the Fn layer. A really good (highly intuitive) implementation of this can be found in the Leopold FC660M, in which Home, PgUp, etc. are mapped to the arrow keys, Fn+LeftArrow, etc.
However, one of the main advantages of the design I have proposed is that the right-shift key is larger than 1x and the staggering in the z-row is standard. This is achieved by moving the arrow cluster to the right. Additional keys are then added for both aesthetic balance and extra functionality. The design is similar to that of the Leopold FC660M but with extra navigation keys. It is also similar to the Race 75, Choc Mini, Keycool 84, or Matias Mini Quiet Pro with the top row of F-keys removed.
