Author Topic: Hello - Keyboard Specialists' Expertise Needed  (Read 1436 times)
Offline nujwowe
« on: Fri, 26 July 2013, 15:24:35 »
us29504-0Hello geekhack community,
I have a piece of old musical gear that has a 10-key setup for entering note information for playback with a synthesizer. The keypad has gone dead and I have heard that there is an old IBM model keyboard that can serve as replacement parts. How would you suggest that I go about finding out which IBM keyboard is compatible. My electronic musical unit was manufactured in 1981, if that helps. I hope that you can help me as I am desperate!
I have pictures I can share if you need them.
 Thanks for your time and advice,
-Mike
« Last Edit: Fri, 26 July 2013, 15:44:30 by nujwowe »
Re: Hello - Keyboard Specialists' Expertise Needed
« Reply #1 on: Fri, 26 July 2013, 15:25:47 »
The picture would be very helpful I'm sure.
