Author Topic: Looking at a few TKLs  (Read 2058 times)
Offline nullptr
« on: Fri, 26 July 2013, 17:45:24 »
Having been infected by the TKL bug, I want to add one of them to my small family of mechanical keyboards. I am a big fan of clicky keys, so I've narrowed down my search parameters to blues and ended up with this list so far:
Filco Ninja Majestouch-2 - Seems like a safe choice, and like the keycaps.
KBT Poker II PBT - Will be hard to get used to, but I love the compact size (I may take the kb travelling).
WASD V2 - I own the V1 and am happy with it, so it may be worth buying another WASD.
I am unable to decide, all of them have properties I like, so I could use some external opinions or even other options.
'11 WASD V1 - '91 IBM Model M (1391401) - Poker II (ordered)
Offline Xenderwind
Re: Looking at a few TKLs
« Reply #1 on: Fri, 26 July 2013, 17:48:55 »
Poker is a 60%, not a tkl.  If you want a tkl then a QFR or filco is a safe choice, very easy to get replacement keycaps.  Depending on how much you want to spend there's also custom keyboard options.
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
Offline nullptr
« Reply #2 on: Fri, 26 July 2013, 18:04:00 »
Thanks for the info, I think with this one I'm going up to about $200. I wasn't aware that that type of keyboard wasn't considered a TKL, but it's a keyboard type I am considering. I got my wife a CM Storm Trigger a while back and am not fond of it myself, so I don't think the QFR or another CM is going to be it.
« Reply #3 on: Fri, 26 July 2013, 18:04:59 »
I think WASD V2 would be a good choice. It seems like they've done a really good job on it.
« Reply #4 on: Fri, 26 July 2013, 18:29:34 »
But is it $150 good?  Considering that you can get a tenkeyless Ducky or Keycool keyboard in the $100-125 range, I'm not sure it is.
« Reply #5 on: Fri, 26 July 2013, 19:24:44 »
QFR is usually a safe choice.
Also consider KeyCool - I have one with reds (other switches usually available), comes with PBT keycaps, very nice.
Have a look in the Reviews section for some reviews of various keyboards to give you additional information.
Offline muad
« Reply #6 on: Sat, 27 July 2013, 15:16:09 »
If you already have a set of keycaps you can just the WASD v2 barebones keyboard for around $100.
http://www.wasdkeyboards.com/index.php/wasd-v2-87-key-barebones-mechanical-keyboard.html
Offline nullptr
« Reply #7 on: Sat, 27 July 2013, 16:08:33 »
I actually went ahead and pulled the trigger on the Poker II. I wanted to try something different, and if it doesn't work out, I can always get the WASD or the Filco.
Offline geekTH
« Reply #8 on: Sat, 27 July 2013, 19:12:54 »
TKL keycool will not cost $100 to $150, less than $100.....
Offline Grim Fandango
« Reply #9 on: Sat, 27 July 2013, 19:31:43 »
Cooler master Quickfire Rapid is pretty good bang for buck.
I have the Filco MJ2 Tenkeyless and am very happy with it.
You are better of first deciding whether you want to go TKL or 60% though. It will narrow your search and make things easier.
Offline Thimplum
  • Master of all Ponies
« Reply #10 on: Sat, 27 July 2013, 20:06:35 »
MJ2
TP4 FOR ADMIN 2013
Offline Thimplum
« Reply #11 on: Sat, 27 July 2013, 20:07:17 »
MJ2 is very well reputed. It seems a safe choice.
TP4 FOR ADMIN 2013
« Reply #12 on: Sat, 27 July 2013, 21:43:38 »
Filco gets a vote, having owned two
