Author Topic: Unbranded Buckling Spring  (Read 14630 times)
Offline CaptCarrot
« on: Sat, 18 October 2008, 18:07:45 »
Just won a kb from someones garage.
It is un branded, but I have found out a little about it from it's FCC ID.
FCC ID: IZITK-105M
Now that ID relates to several different products, both wired and wireless, so I can only assume it relates to the chip manufacturer?
Anyway, this board is a standard, modern sized, PS/2 keyboard with 4 extra keys.  [Ins], [Home], [Pg Up], [Del], [End] & [Pg Dn] have been shifted down a row to meet the cursors.  [Prt Scr], [Scrl Lk] and [Brk] have been moved down 2 rows to join the top of the previous block, and in there place have been put [Sleep], [Wake] and [Power].  To the right of the right Shift key is an [Fn] Key.  Having done some research on the FCC ID I found out that there is an easter egg stored in this board.  Make sure you are in a text entry area, then hold Fn and press Prt Scr and you get the following message
Quote from: Fn+Prt Scr
eleen enterprise co., ltd. v1.02
I have taken it apart, and it would appear to be Buckling Spring technology.
Piccies - click to enlarge (will open in new tab/window).
Offline bhtooefr
    • bhtooefr.org
« Reply #1 on: Sat, 18 October 2008, 23:50:29 »
Talk about a weird beast - the design doesn't quite look like IBM's buckling spring system, although better photos would be needed to be sure about that.
It is tactile, correct?
And, most keyboards with that easter egg are the $2 rubber dome boards that are only good for this: http://video.google.com/videoplay?docid=625413727137976232
Offline bhtooefr
    • bhtooefr.org
« Reply #2 on: Sat, 18 October 2008, 23:56:07 »
Offline CaptCarrot
« Reply #3 on: Sun, 19 October 2008, 03:47:51 »
Quote from: bhtooefr;9629
Also, take a look at this: http://web.archive.org/web/20040812042057/http://www.can-tech.com.tw/mechanical.htm
thought I would post that info, as the images on that page do not load who knows how long it'll survive :)
Quote from:
MECHANICAL TOUCH FEELING
  • MECHANICAL TOUCH KEYBOARD SPECIFICATION
  • SPILL RESISTANCE
  • SPECIAL "FN" KEYS FUNCTION:
[LIST=A]
  • KEYBOARD LOCK ON/OFF : PRESS "FN" + "F12"
  • KEYBOARD REPEAT RATE ADJUSTABLE: PRESS "FN" + "F1" ~ F8"
  • NO. OF KEYS:
[LIST=A]
  • US 108 KEYS
  • EUROPE 109 KEYS
  • BRAZILIAN 110 KEYS
  • KOREAN 111 KEYS
  • JAPANESE 112 KEYS
  • LANGUAGE: ALL LANGUAGES LAYOUT AVAILABLE
  • KEY CLICK SOUND: YES
  • KEY SWITCH: PATENTED STAINLESS SPRING KEYSWITCH
  • KEY SWITCH LIFECYCLE : 10 MILLION
  • WINDOWS 95 KEYS AVAILABLE
  • 3 POWER CONTROL KEYS AVAILABLE
  • EURO SIGN AVAILABLE
  • CONNECTION TYPE: AT(DIN) , PS/2, USB
  • OPERATING SYSTEM: ALL MICROSOFT WINDOWS SYSTEMS
  • CERTIFICATION: CE, FCC
  • CABLE LENGTH: 5 FEET
  • PRODUCT COLOR : WHITE
  • KEY TRAVEL : 4  0.3 mm
  • OPERATING FORCE: 55g  8g
  • SPACE KEY FORCE: 55g  8g
  • OPERATING VOLTAGE: + 5V DC  10%
  • OPERATING CURRENT: MAX 250mA at 5V DC
  • STORAGE TEMPERATURE: -20 ~ + 60
  • OPERATING TEMPERATURE: -5 ~ +50
  • HUMIDITY : 5% - 95% RH
Code: [Select]
PACKAGE INFORMATION
           PALM                PCS/   G.W.   CBF/
  MODEL    REST   DIA.(mm)     CTN    (kg)   CTN
CAN-2001W  NO     460*160*41   20     17.8   2.6
CAN-6001W  YES    490*180*50   10     12.5   1.65
CAN-7001W  YES    490*180*50   10     12.5   1.65
Also, the patent numbers off the bottom of my  IZITK-105M
German Patent No. G9211065.7
R.O.C. Patent No. 188557
USA Patent No. 07-691S25
China Patent No. 92232015.2
Offline Chloe
  • Switch Kitten
« Reply #4 on: Sun, 19 October 2008, 06:27:43 »
It looks like the same layout as the Kopek Pacific KB-2 Mechanical Touch Keyboard:
http://www.kopek-pacific.com/computer_keyboard.htm#kb2
The price here seems too good to be true:
http://www.bangkokbest.com/Periperal.htm
What are your impressions of the build quality? How does it feel to type on?
Offline CaptCarrot
« Reply #5 on: Sun, 19 October 2008, 07:57:07 »
Its not bad. not brilliant but not bad.  It has the same spill resistance as an M because of the way the case is molded.  I can't really compare it to other boards that well, but I would say it definately has a springy feel to it.
Here is a quick sound sample [REMOVED]...  I'll post a proper one in the keyboard sound thread when the missus goes out and stops nagging at me.
Offline bhtooefr
    • bhtooefr.org
« Reply #6 on: Sun, 19 October 2008, 07:57:26 »
It's from Web Archive - they must not have gotten the images, and the manufacturer's site has already deleted them, but the text is safe.
As for the bangkokbest link, clicking on the order now button gives you "Your requested e-Store is not found !!"
And, that sound... what sort of compression are you using on that file? Because that sounds like a horribly overcompressed file.
Offline CaptCarrot
« Reply #7 on: Sun, 19 October 2008, 08:02:34 »
I'll redo the sound.  I have got the missus nagging at me, thinking I'm a freak and I can only record in wma, so I tried converting it to mp3 as I can't upload wma.
Ive got to take the missus out now, try and shut her up.  I'll repost later (the original wma sounded fine)
Offline bhtooefr
    • bhtooefr.org
« Reply #8 on: Sun, 19 October 2008, 08:15:46 »
Record it in WAV, and convert to MP3. Sound Recorder FTW. ;)
Rule #1 of converting media: Avoid converting from one lossy format to another.
Offline CaptCarrot
« Reply #9 on: Sun, 19 October 2008, 09:31:10 »
i'll do it on my xp machine. Sound recorder on vista only lists wma as an option.
Offline CaptCarrot
« Reply #10 on: Sun, 19 October 2008, 11:42:41 »
In an effort to give a better recording I am A: recording direct to mp3, and B: recording what I am typing here and not some arbitrary nonsense.  HTH.
Offline bhtooefr
    • bhtooefr.org
« Reply #11 on: Sun, 19 October 2008, 13:37:24 »
OK, that's more helpful.
And, now I want one of these things, just to see how it is. We might have just found the cheap buckling spring board of choice for people who don't want to pay a bunch of money for a new Unicomp, or buy a 13+ year old 1391401 from Goodwill (or, for that matter, a 10-13 year old Lexmark board.)
Although, the layout certainly is NOT US 104...
Offline CaptCarrot
« Reply #12 on: Sun, 19 October 2008, 14:22:50 »
Agreed it is not US 104, but I do believe that it says in that datasheet that all language layouts are available, (US is 108).  Who knows, it may even come as a 105 (only the fn key extra).
here is one on Ebay UK BIEGE MECHANICAL TOUCH AT KEYBOARD FOR WINDOWS95/98 (Item number: 170268428298)
Offline CaptCarrot
« Reply #13 on: Sun, 19 October 2008, 14:57:47 »
You want better pictures of the spring mech... GO HERE
Apart from the fact mine does not say Mechanical Touch where the status LED's are, and is missing the other character imprints on the keys, the text for Caps, Num & Scroll Lock is identical.  The sticker underneath mine says No: 200010  Made in China
Offline CaptCarrot
« Reply #14 on: Sun, 19 October 2008, 15:10:18 »
This Guy Doesn't know when he was onto a good thing.
The keyboard feels very cheap and tacky. The keys wobble and don't feel very firm, and they are quite loud. The plain packaging says in huge letters, "Mechanical touch feeling!", but this just means the keys are very loud and springy. So far there are no actual problems with the keys; I assume the letters won't wear off, and the keys don't seem like they would break loose despite how wobbly they are. Only time will tell whether this keyboard will last a few months or a few years, though the cheapness definitely suggest it will break sooner rather than later.
Offline lowpoly
« Reply #15 on: Sun, 19 October 2008, 15:33:22 »
A new switch, non-understanding SOs, great internet detective work, this thread delivers!
Offline CaptCarrot
« Reply #16 on: Sun, 19 October 2008, 15:45:45 »
Quote from: lowpoly;9665
Just call me Caps Lock Holmes ;)
p.s. whats an SO?
Offline Chloe
  • Switch Kitten
« Reply #17 on: Sun, 19 October 2008, 15:49:56 »
Quote from: CaptCarrot;9662
I'm not sure if this is the same keyboard. The one in the review had 104 keys and 18 multimedia keys. The F21RFXP2 here has a "Mechanical Touch Feeling" option.
Offline CaptCarrot
« Reply #18 on: Sun, 19 October 2008, 15:52:31 »
Quote from: Chloe;9668
Sure, its just he was moaning about the noise and the springiness...  Our Holy Grail
I found that page, noted the following
  Model Number : F21HQ
  • Dimension : ( L x W x H) : 465*175*30 mm
  • Switch activation mechanism : Mechanical type
  • Patented APC Mechanical Key Switch
  • PS2/AT port
  • CE/FCC approved
  • One Year warranty
  • Packing : 10 PCS/CTN;N.W.12.5 Kgs;G.W:15.55Kgs; Measurement: 2.0'
Just wasn't sure it was a spring not a switch.
Offline lowpoly
« Reply #19 on: Sun, 19 October 2008, 16:21:59 »
p.s. whats an SO?
Significant Other.
Offline CaptCarrot
« Reply #20 on: Sun, 19 October 2008, 17:15:20 »
ahhh
Offline CaptCarrot
« Reply #21 on: Mon, 20 October 2008, 14:02:15 »
Quote from: CaptCarrot;9661
Found on the same site...  A really good graphical display of how the IBM switches work.
Look Here
Offline CaptCarrot
« Reply #22 on: Mon, 20 October 2008, 17:34:50 »
Quote from: bhtooefr;9653
Well, I don't know if this has the same key-mech (it appears to have the fn key)... If anyone is willing to take a punt on it and find out, I think some might be interested to know, maybe.
I would, but I can just about justify the price of the board, add shipping to the UK and my mrs would kill me.
The e-bay auction says ps/2.. this uk auction says mac only adb.
Offline CaptCarrot
« Reply #23 on: Mon, 20 October 2008, 17:42:57 »
scratch that - found some specs... sounds like Cherrys...
http://www.datadesktech.com/desktop_base.html
Keyswitch Characteristics
Full-travel, tactile, gold-plated mechanical switches
Rated at 50 million cycles
Operating force:  momentary, 70 - 25g
Switch travel:  3.5 - 0.5 mm
Offline CaptCarrot
« Reply #24 on: Mon, 20 October 2008, 17:59:43 »
Back to the original, looks like the base manufacturer is Can Technologies...
Interesting link to ALPS too...
http://www.can-tech.com.tw/html/history.html
Quote from: Can Technology: Company History
... Mr. Tao Shen Chen, the founder of CAN TECHNOLOGY...
... In 1984, Mr. Chen founded a component plastic injection company named Precision Great Plastic Co. Ltd. ...
... Meanwhile, PGP also had developed ALPS plastic key switch tooling and had produced the plastic components to Forward. ...
...  In 1989,  ... In same year, PGP had started to develop and manufactured PGP's first computer mechanical keyboard, and had also received various patents for stainless spring mechanical switch. ...
... Mr. Chen founded a factory in Zhuhai Nanping, China, which was named President
Computer Technology Co., Ltd ...
... President Computer had started to manufacture mechanical keyboard for TRUST. Later on, President also had started to manufacture rubber membrane keyboard for Logitech, and A4. Besides wired keyboard, President computer had also started to manufacture wireless keyboard for Chic ...
... President Computer had manufactured mid-low range keyboard or mouse for BenQ Darfon, Liteon, and Mitsumi ...
Offline Chloe
  • Switch Kitten
« Reply #25 on: Wed, 22 October 2008, 08:01:31 »
Quote from: CaptCarrot;9631
Here's the patent for the key switches:
http://www.cpsfu.com/H01H/1993/2135825.shtml
English translation
Offline CaptCarrot
« Reply #26 on: Wed, 22 October 2008, 09:09:25 »
Hmmm....
Quote from: China Patent No. 92232015.2
Application (patent)    Ya Sheng Co., Ltd.
In 1993, Sheng Ya (CAN) had created its first branch office in the United States, and named itself as Syncan. Syncan was renamed as CAN TECHNOLOGY Co
Ya Sheng and Sheng Ya, bit of a coincidence?
Offline CaptCarrot
« Reply #27 on: Wed, 22 October 2008, 11:32:39 »
Code: [Select]
PACKAGE INFORMATION
           PALM                PCS/   G.W.   CBF/
That web-archive article appears to have been taken directly from Can technology's website.
Having done some research, I have found the following...
  • CAN-2001W - Appears to be SILENT - mainly on sale in Czech and Slovak countries. Google Search
  • CAN-3001W - This appears to be clicky About 4/5 the way down the page
  • CAN-5001W - metal or plastic frame - key-mech unknown
  • CAN-6001W - multimedia with or without palm rest - key-mech unknown
  • CAN-7001W - multimedia with or without palm rest - key-mech unknown
Offline CaptCarrot
« Reply #28 on: Wed, 22 October 2008, 11:53:22 »
I think I can SAFELY say I have found MY Keyboard
I give you the DISCONTINUED Dabs Value 105 Key AT
And just incase we lose that page:
Discontinued
quicklinx: T3JD1
mfr#: 2001W AT
MECHANICAL TOUCH KEYBOARD SPECIFICATION SPILL RESISTANCE NO. OF KEYS: EUROPE 109 KEYS KEY CLICK SOUND: YES KEY SWITCH: PATENTED STAINLESS SPRING KEYSWITCH KEY SWITCH LIFECYCLE : 10 MILLION EURO SIGN AVAILABLE CONNECTION TYPE: AT(DIN) OPERATING SYSTEM: ALL MICROSOFT WINDOWS SYSTEMS CERTIFICATION: CE, FCC CABLE LENGTH: 5 FEET PRODUCT COLOR : WHITE KEY TRAVEL : 4 0.3 mm OPERATING FORCE: 55g 8g SPACE KEY FORCE: 55g 8g OPERATING VOLTAGE: + 5V DC 10% OPERATING CURRENT: MAX 250mA at 5V DC STORAGE TEMPERATURE: -20 ~ + 60 OPERATING TEMPERATURE: -5 ~ +50 HUMIDITY : 5% - 95% RH
  • Standard AT Keyboard
  • SPILL RESISTANCE
Note the model/mfr number is 2001W AT (CAN-2001W?)
Offline CaptCarrot
« Reply #29 on: Wed, 22 October 2008, 13:10:12 »
Offline bhtooefr
    • bhtooefr.org
« Reply #30 on: Mon, 17 November 2008, 10:47:20 »
Bumping an old thread, but Shengya is definitely the same company - the European Patent Office's entry for that patent: http://v3.espacenet.com/publicationDetails/biblio?KC=Y&date=19930609&NR=2135825Y&DB=EPODOC&locale=en_EP&CC=CN&FT=D
