Author Topic: Cherry Profile Thick PBT on Ducky Board  (Read 4737 times)
Offline tbc
« on: Sat, 27 July 2013, 02:38:12 »
http://www.ebay.com/itm/KBC-Grey-Blank-Thick-PBT-104-Keyset-Cherry-MX-Keycaps-/330950287238?pt=LH_DefaultDomain_0&hash=item4d0e2c9f86
will these fit on a duck 9087 shine 2?
I'm new to all of this and I'm not sure if there are 'cherry stabilizer' and 'costar stabilizer'-only keycaps
also, I'm told that thick PBT cherry profile black blanks don't and will never exist.  is this set as dark as I can get it?  is there like a 'dark grey' equivalent set out there?
Offline terran5992
  • One With The Cup Rubber
Re: Cherry Profile Thick PBT on Ducky Board
« Reply #1 on: Sat, 27 July 2013, 04:36:08 »
Should have no problem with fitting on your board .
Your ducky board uses cherry stabilizers
Pbt blanks are just really rare and hard to come by.
You can find dark grey or black on taobao.
Enjoy :)
Offline iAmAhab
  • Established member
« Reply #2 on: Sat, 27 July 2013, 05:01:40 »
If you like DSA profile then SP can cater some cheap blank pbt's:
http://keycapsdirect.com/marketplace.php
« Reply #3 on: Sat, 27 July 2013, 05:03:15 »
No different between stabiliser mounts - if a keycap fits one it will fit the other.
The backlighting will not shine through these much.
Offline tbc
« Reply #4 on: Sat, 27 July 2013, 14:18:27 »
okay, I totally didn't read the ebay description - they're usually totally useless.
so I'm under the impression that if I want to put the on cherry stabs, I just put them straight on.  if I want to use them on costars, I need to keep the white plastic peg things.
is there currently a groupbuy for really dark thick pbt cherry profile blanks?  or ebay listing?
« Reply #5 on: Sat, 27 July 2013, 14:58:27 »
What's wrong with the ones you listed?
Offline WhiteFireDragon
    • youtube
« Reply #6 on: Sat, 27 July 2013, 15:30:38 »
Not thick and PBT.
I've been waiting years for a set like this to come out. They don't exist in for this exact type.
Offline PepperPanda
« Reply #7 on: Sat, 27 July 2013, 15:39:01 »
Unfortunately these aren't thick. You could look at imsto's set but I don't think he sells black blanks.
Offline tbc
« Reply #8 on: Sat, 27 July 2013, 18:15:38 »
they're grey.  i would prefer black or otherwise as dark as possible.  I was just wondering if there was a darker set and I want to see for myself how thick pbt actually feels.
EDIT:  at what point do I get to stop entering captchas for posting?
« Reply #9 on: Sat, 27 July 2013, 19:11:41 »
In thinking 10.
