Author Topic: Homing on 7 & 4  (Read 1122 times)
Offline aj-kun
Homing on 7 & 4
« on: Sat, 27 July 2013, 18:16:50 »
Are they any keysets around that have homing(scoops/point/underscore) on 7 & 4? I find that when I move to that row my fingers get lost at times.
also Braille number row (someone make it happen)
Offline aj-kun
Re: Homing on 7 & 4
« Reply #1 on: Sat, 27 July 2013, 18:17:44 »
Mods can you move this to the keyboard key caps forum
Offline Grim Fandango
Re: Homing on 7 & 4
« Reply #2 on: Sat, 27 July 2013, 18:44:41 »
Actually not a bad idea, though I doubt you need it when you get used to it. Using the 7 and 4 goes naturally for me. As long as I use the right finger it just naturally happens. Just be consistent which finger you use, for me , from the homerow position, when shifting them upward,  each finger naturally hovers over a number key. Only for the 6 I tend to look at the keyboard.
Offline Thimplum
  • Master of all Ponies
Re: Homing on 7 & 4
« Reply #3 on: Sat, 27 July 2013, 20:05:20 »
You could put a tiny dab on epoxy on the cap.
TP4 FOR ADMIN 2013
