Author Topic: [MOD]Recessing Space mounts  (Read 2729 times)
Offline aj-kun
« on: Sat, 27 July 2013, 21:15:14 »
Mod showing how to lower the an OEM space profile to match cherry profile(or close enough)
How to do it?
I used a nail cutter & some files to slowly cut away at the mounts to lower recess the mount a bit more.
BEFORE (same height as the key I modded)
AFTER
WHOLE PROFILE
POTATO hack picture
Another potato hack pic.
I'm sure someone with a desk vice and a dremel could do a nicer looking job. I guess this is more of a proof of concept xD
(I do have a dremel but was too lazy to pull it out
Offline esoomenona
  • Gnillort?
Re: [MOD]Recessing Space mounts
« Reply #1 on: Mon, 29 July 2013, 11:26:35 »
I'm sure you could also file on the stem of the switches and stab inserts to go even lower.
Offline aj-kun
« Reply #2 on: Mon, 29 July 2013, 14:10:18 »
That wouldn't work.
Offline esoomenona
  • Gnillort?
« Reply #3 on: Mon, 29 July 2013, 14:23:34 »
I don't mean solely. I mean in conjunction with your suggestion, to get them a bit lower (that is, if the stem of the switches and stabilizers is hitting the top of the inside of the hole they insert into).
Offline gnubag
« Reply #4 on: Mon, 29 July 2013, 14:33:10 »
before you do that make sure the keycap doesn't hit the plate. :)
