Author Topic: Poker II Mods  (Read 1376 times)
Offline PointyFox
Poker II Mods
« on: Sat, 27 July 2013, 21:27:24 »
Hi, I'd like to know how to do Poker II mods like taking off the case and installing LEDs.  :)
Re: Poker II Mods
« Reply #1 on: Sun, 28 July 2013, 12:23:03 »
Pop the caps, unscrew the PCB from the case, pull it out, drop LEDs in, solder them in place, screw the PCB back into the case, and put your caps back on and you're done.
Offline WhiteFireDragon
    • youtube
Re: Poker II Mods
« Reply #2 on: Sun, 28 July 2013, 12:27:40 »
The LED holes come prefilled with solder, so you must desolder the holes first before they can be inserted. Don't forget to pay attention to positive and negative side of LED and holes.
