Author Topic: Lots of learning ahead of me.  (Read 1985 times)
Offline Siva
    • TwitchTV
« on: Sun, 28 July 2013, 21:58:36 »
Hey, guys. I just came across this place and I'm utterly astounded by the amount of information everyone here seems to have.
Considering that I'm into livestreaming; I'm in the process of picking out a keyboard superior to my Dell pos membrane keyboard. So, I'll ask a couple questions in the keyboard forum pertaining to one's I'm looking at and we'll see what happens.
cheers.
Offline Rule16
  • R.I.P. SmallFry
Re: Lots of learning ahead of me.
« Reply #1 on: Sun, 28 July 2013, 22:01:20 »
I'm assuming you'd want something very quiet, yes?
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
Offline Siva
    • TwitchTV
« Reply #2 on: Sun, 28 July 2013, 22:08:10 »
Yessir. Something quiet-ish. I've been investigating the QuickFire TK with Browns. But, the lighting scheme on the 10key is bugging me. I'd snag it if i knew someone out there could rewrite the firmware to allow more sane lighting.
Offline Rule16
  • R.I.P. SmallFry
« Reply #3 on: Sun, 28 July 2013, 23:53:35 »
If you want something as quiet as a rubber dome, but much nicer feeling you could get http://elitekeyboards.com/products.php?sub=topre_keyboards,rftenkeyless&pid=rf_se070s -or- http://elitekeyboards.com/products.php?sub=topre_keyboards,rftenkeyless&pid=rf_se170s. However, these are quite expensive for a first keyboard, but I'm worried if you're live streaming that MX Browns may be too loud.
Dvorak Only Zone
Offline Siva
    • TwitchTV
« Reply #4 on: Mon, 29 July 2013, 00:10:17 »
I really like those suggestions, Rule16. I never heard of switch like that. But, bringing up 87key boards raises a question; I'm a huge fan of the integrated numpad on models like the Keycool 84. Do 87key boards have a similar function?
Offline Rule16
  • R.I.P. SmallFry
« Reply #5 on: Mon, 29 July 2013, 19:10:11 »
Yes there are a few, including the ones I linked you :P
The only other ones I can think of are no longer available (unless you buy used) such as the Model M SpaceSaver, and the MiniTouch (this one isn't too great unless you get the blue monterrey switches).
Dvorak Only Zone
