Author Topic: Considering getting a QuickFire TK, but a question before I pull the trigger...  (Read 4093 times)
Offline Siva
    • TwitchTV
I want a QuickFire TK, but the lighting scheme on the numpad when Num Lock is turned on seriously bugs me. Is there a way to get a firmware that turns on all number keys when Num Lock is turned on?
Many thanks.
Offline jameslr
You talking about where the arrow keys are not lit? As far as I know there isn't a way to customize it. There are better options for backlit boards. I'm assuming you're interested due to price as I think it's currently on sale at Newegg, right? You could spend a little more and get a way nicer board with a Ducky Zero Shine. I know this doesn't answer your question - just an option I guess.
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
Offline Siva
    • TwitchTV
ah, yessir. The arrow/number keys not being lit really turned me off. I understand it's a superficial thing, but I'm stupid like that.  The reason the TK appealed so much to be is because I wanted a compact-ish board with 10key and but no arrows.
The Keycool 84 caught my attention today, and I really like the 10key and F1-12 layout. Is that a brand worthy of note around here?
Here is a review on the keycool
http://geekhack.org/index.php?topic=45527.msg952788#msg952788
If you want the compact board with a 10-key you could look into trying to get a phantom.
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
7bit that ish! Any cases for the 7bit layout? Found out the phantom I bought has a 7bit plate so if I cutout the little spot above the cluster on my filco case, I could add 5 switches and make this thing even more awesome.
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline kmiller8
  •  Post Reporting Timeout
  • Who is that kmiller8 guy?
I have a QFTK, I'm a bit hesitant to recommend buying it, as with the backlighting "problem" you outlined and a few others I made in this thread http://geekhack.org/index.php?topic=45033.0 Some other backlighting nusiances are that it's nearly impossible to have all keys lit up and usable, because I almost always have the Win Lock off meaning my F12 key LED is turned off, and Fn Lock is disabled as well, meaning another dead LED. It's a very very interesting layout and I'd love to have another keyboard like it, but as I said, I'm a bit hesitant to recommend it to someone.
I think there is another TK board out there, but the name escapes me :/
P.S. It seriously irates me to no end having the far-right enter unusable when arrow keys are on *grumble grumble* (Apparently they've fixed this with newer versions)
P.P.S You could always mod the board to have the LEDs always be on :D
There is also the Plum96 if you can source it. It was one of the first keyboards I wanted but never did find one.
Offline esoomenona
  • Gnillort?
I see no one has mentioned the weird key layout for the bottom row. If you're looking to change those caps in the future, expect this: no replacement spacebars. By my calculations, it is a 6.5x spacebar, whereas the norms are 6.25x, 7x, or sometimes 6x. You'd also have to buy a tsangan every time, to get the 1.5x Ctrls and 1x keys.
Offline kmiller8
I did mention it, in my post, linking to my other post. But yes, the key layout is silly as well :/
Offline esoomenona
  • Gnillort?
I don't be reading posts linking to links linking to other posts!
Offline Siva
    • TwitchTV
Are there any known reputable vendors selling the Plum 96? I ran across Aliexpress selling one, but someone here would have to vouch for their keyboards before I buy one from there. I say this because I'm part of a knife community and pretty much all name brand knives sold through AE are Chinese knockoffs.
I know it sounds like a silly question. But, are there known counterfeit keyboards floating around?
I'm not sure I've not found one yet :(
And personally I wouldn't purchase anything from aliexpress :eek:
Offline Thimplum
  • Master of all Ponies
I think Binge got one from somewhere...
TP4 FOR ADMIN 2013
Offline kmiller8
Oh yeah, one reason to love the QuickFire TK!
CHERRY STABILIZERS. Which are so much better than Crapstar Stabs.
Offline Siva
    • TwitchTV
I can't tell if you're being serious  :-[ :-[
Offline kmiller8
100% srs, I can't stand costar stabs, I literally spent about 15 minutes with a QFR before destroying it because of how bad the stabilized keys were.
Binge hook me up!
Offline Thimplum
Binge hook me up!
I don't know where he got it from. You could ask him.
TP4 FOR ADMIN 2013
Offline Siva
    • TwitchTV
So, I ultimately decided to go with the Yellow LED MX Brown Keycool 84 since I prefer the layout over everything else. I'm just a little concerned about the overall value of the board at $125 (@MKB) compared to some Leopold, Ducky, etc going for less. I know I'm paying a premium for "gamer" frills like backlighting. But, I just don't get how it can go for that price when people seem to be on the fence about its build and key cap quality issues.
Cheers.
