Author Topic: Help me find an appropriate keyboard?  (Read 1524 times)
Offline anonymousie
« on: Mon, 29 July 2013, 14:30:41 »
All right, so I'm not an expert on mechanical keyboards, though I am a fan of them. At home, I have a Razer BlackWidow as it was cheap (I got it for 50% off thanks to a NewEgg coupon), and I knew I liked the blue Cherries. It's been all right, for the most part. I still am a fan of the blues, but there is an issue...
They're LOUD. This is a bonus for me, as I enjoy the sound of my keyboard thoroughly. However, people around me aren't fans so much. I want to find a keyboard that will satisfy me and NOT annoy the people around me, for the office.
The feel is most important. I enjoy the feel of the blue switches. Can I get that feel without my much-loved clicky noise? What would you recommend? (Note: The programmable aspect of the BlackWidow is completely unimportant. I do not use it at all and would probably prefer a simpler keyboard anyway.)
Any ideas what switches I should investigate? Or even whole board suggestions? I'm comfortable modifying things as well, though I wouldn't want to build my own board from scratch.
Re: Help me find an appropriate keyboard?
« Reply #1 on: Mon, 29 July 2013, 14:33:59 »
You could try whites, they have a very slight click. Or perhaps jailhouse blues, they have no click due to being modded.
Have a look around and read some peoples impressions of switches.
captain has a wonderful switch write up here
http://geekhack.org/index.php?topic=42669.0
« Last Edit: Mon, 29 July 2013, 14:37:08 by SpAmRaY »
Offline UniClown
« Reply #2 on: Mon, 29 July 2013, 14:36:58 »
I would recommend browns. They are tactile like the blue switches you have used, are fairly common, don't require modding, and they still do make noise just not really a click sound. If you want the clicking, then I would look into white switches, which are considered to have a softer 'click' noise.
Offline anonymousie
« Reply #3 on: Mon, 29 July 2013, 14:41:49 »
Thanks, guys. I've been reading a little, and I was wondering if brown might be ideal, there's just a lot of information out there to digest.
The only thing I know for certain is that Cherry blacks make me angry, but of course that's because they're nothing like what I'm going for.
Offline Narcix
« Reply #4 on: Mon, 29 July 2013, 15:22:14 »
Clears?
Keycool 87 Grey PBT with mx blues
« Reply #5 on: Mon, 29 July 2013, 15:30:18 »
What was the reason you didn't like blacks, the linear motion, the heaviness?
