Author Topic: Looking to buy an IBM Model M  (Read 9007 times)
Offline Jalberstone
« on: Mon, 29 July 2013, 21:47:54 »
I really want to buy a Model M, but I don't know where to buy one and if it is a trustworthy source. Could anyone tell me where to look? Also is it possible to buy a Model M with a USB connector instead of PS/2? Thanks!
Offline tehsprayer
Re: Looking to buy an IBM Model M
« Reply #1 on: Mon, 29 July 2013, 21:50:14 »
Ebay has a few.
REΛLFORCE 87U - uniform 55g
Offline lcs
  • Lover of Grape Drank
  • はやく
« Reply #2 on: Mon, 29 July 2013, 21:52:33 »
Only PS/2, but you could buy an Unicomp with USB. But with an Adesso adapter everything works fine.
Craiglist has some as well.
http://www.clickykeyboards.com/
If you have patience they eventually will have one. It'd be more expensive, but it'll be trustworthy.
Offline Wall Street
« Reply #3 on: Mon, 29 July 2013, 21:55:45 »
If you want a new board with a USB connector, you can buy a Unicomp.  Their Unicomp Classic model is a new buckling spring keyboards based on the original IBM design.  Some people say the build quality is worse than IBM, however some of the Model M keyboards aren't exactly in the best shape either.  I am trying on a Unicomp right now and it definitely has the feel of what I remember from the keyboard of my youth.
Offline PadawanGeek
« Reply #4 on: Mon, 29 July 2013, 22:13:33 »
I'd gotten a Lexmark Model M (1993) in near mint condition, except that the three LED indicators on the top right of the KB aren't working. It feels awesome typing on it, a tad loud though but that's part of its charm. I'd originally wanted an IBM branded one, but saw some that were not in the best of condition, this Lexmark Model was in the best shape, so I'd jumped on it.
« Last Edit: Mon, 29 July 2013, 22:15:42 by PadawanGeek »
« Reply #5 on: Mon, 29 July 2013, 22:39:07 »
Most Model M are PS/2.
If the one you end up getting has a SDL connector, you can try one of these, which I was recommended: http://www.ebay.com.au/itm/270955553909?ru=http%3A%2F%2Fwww.ebay.com.au%2Fsch%2Fi.html%3F_sacat%3D0%26_from%3DR40%26_nkw%3D270955553909%26_rdc%3D1
If it has a non-removable cable, you could get a separate PS/2 to USB adaptor.
Offline PadawanGeek
« Reply #6 on: Mon, 29 July 2013, 22:45:51 »
What? I was under the impression that Model M's had AT connectors. The one I'd gotten had that, so I simply got a cheap AT to PS/2 adapter (about 4USD) and it works perfectly.
Offline 1391406
« Reply #7 on: Mon, 29 July 2013, 22:48:12 »
I'd take a dirty Model M with a few missing key caps over a brand new Unicomp any day, but that's me.
« Reply #8 on: Mon, 29 July 2013, 22:49:45 »
The older ones are AT, most are PS/2 (as far as I know).  Both of mine are form the 90s and both are PS/2 (one SDL and one not).
I'll take a couple of keycaps from a dirty Model M any day ;)
« Reply #9 on: Tue, 30 July 2013, 08:15:37 »
I second the recommendation of the Orihalcon-made cables. They are clean and fresh and work great.
The very early Model Ms (1390120, most 1390131s, and some 1391401s) had black coiled AT-style cables, after about 1987 they were gray coiled PS/2 cables, either long (5' aka "short") or ultra-long (10' aka "long").
- Bill Roberts 2026-06-17
Offline Jalberstone
« Reply #10 on: Tue, 30 July 2013, 15:17:20 »
So would you recommend staying away from the new unicomp keyboards if so why?
Offline 1391406
« Reply #11 on: Tue, 30 July 2013, 15:58:56 »
If the quality of the keyboard case isn't necessarily of major importance to you then a Unicomp is an acceptable substitute for a Model M, as the typing experience is relatively the same. The build quality of Unicomp cases, however, is another story.
Offline smknjoe
« Reply #12 on: Tue, 30 July 2013, 16:03:30 »
Someone mentioned that the Ms were made of PVC (which contains lead.) Isn't PVC pretty stable and therefore the lead not really a concern?
Are the Unicomps less durable because of different materials or thinner materials or both?
SSKs for everyone!
« Reply #13 on: Tue, 30 July 2013, 16:22:31 »
Unicomp Model Ms are modern Model M keyboards made in the same factory on the same equipment as Model Ms from decades ago.
There have been minor changes in the plastic composition of the cases, other little corners have been cut here and there, and most people agree that quality control has slipped from the IBM days, but they are true Model M buckling spring keyboards in every way. Period.
And they can be bought in different footprints, also in black, and with native USB cables. They are a good buy, do it.
Offline tricheboars
  • Keyboards are Important!
« Reply #14 on: Tue, 30 July 2013, 16:28:08 »
i agree with this man fully. i would also add that i believe most love for the 80's era boards have to do with appearance and nostalgia.   dont get me wrong i love my 80's IBM Model M but i have also typed on a few unicomps and they really do feel just as nice. however if you plan on going with an 80's style one, be sure to get an Adesso Active USB converter, and dont expect NKRO.
However, if you want to talk about IBM Model F AT.... well there is no comparison.
Offline smknjoe
« Reply #15 on: Tue, 30 July 2013, 16:31:03 »
I realize they are the same exact design made on the same exact machines, but it keeps getting repeated over and over and over that they aren't as good. So, the only thing that could possibly be different is the materials used. I was just curious. Never have used a Unicomp but I would guess that it's the same as my IBM models.
Edit: and I also realize that many people like to offer opinions when they have no personal experience. Just the experience of others that they repeat.
« Last Edit: Tue, 30 July 2013, 16:34:02 by smknjoe »
SSKs for everyone!
Offline tricheboars
« Reply #16 on: Tue, 30 July 2013, 16:35:21 »
it is just model m owners spreading the seeds of jealousy. model m boards are hard to get and expensive, or they are in terrible condition. unicomps are reasonably priced, available, and mainstream.
the model m is the hipster of keyboards (along with hhkb). they are cool because you cant buy one in a store NIB.
the true test would be to blindfold a unicomp nay-sayer and let him type on both.  my guess is very few of us model m owners could tell the difference without our eyeballs.
« Reply #17 on: Tue, 30 July 2013, 17:12:23 »
Not quite the same design any more - they just altered the layout of the bottom row of keys.
Offline 0100010
  • Not Sure
« Reply #18 on: Tue, 30 July 2013, 17:21:37 »
Only on the 104 key models, the 101 key units are the same.
Offline 1391406
« Reply #19 on: Tue, 30 July 2013, 18:08:37 »
Model M's aren't hard to get(they're all over eBay), aren't expensive compared to other mechanical keyboards, and can be found in good condition without too much trouble.
No, they're cool because they're built like tanks, feel good to type on, and last forever.
I can absolutely distinguish between a Unicomp and Model M in a blind taste-test on a few levels without actually seeing either board any day of the week via:
1) Physically handling the case
2) Feel - typing on one
3) Sound when being typed on
Offline 1391406
« Reply #20 on: Tue, 30 July 2013, 18:14:01 »
The plastic composition is different, which explains why Unicomp cases are more flexible and creak when flexed, however there's the issue of quality control in the form of flashing around some of the key caps. It's also been pointed out that there are cosmetic defects on the surface of the case which tend to look like smudge marks.
« Last Edit: Tue, 30 July 2013, 18:25:16 by 1391406 »
Offline h2gofast
« Reply #21 on: Wed, 31 July 2013, 17:39:41 »
I would be willing to take the blindfold test.  Model M's are out there, just be patient,
Offline 1391406
« Reply #22 on: Wed, 31 July 2013, 18:49:03 »
They are, and a lot of those listed on eBay right now appear to be in good condition:
Offline wcass
« Reply #23 on: Wed, 31 July 2013, 20:44:04 »
i have both, use them every day (Unicomp at work and IBM at home) and enjoy them both. that said, there is a difference. the older the keyboard, the thicker (stiffer) the steel back plate. and the plastic has changed over the years from thick and brittle (model F), to medium thick and resilient (old IBM model M), to thinner. but if you are looking for native USB and a Win key, your best bet is a (newer) Unicomp.
the older boards often need some semi-skilled work to bring them into the 21st century. classic Ms might need a bolt mod and an active USB converter; terminals need a USB converter/remapper (like Soarer's converter - i prefer to put the adapter in the keyboard case) and maybe an ANSI conversion if ISO is not your thing.
Offline bazemk1979
« Reply #24 on: Wed, 31 July 2013, 20:54:55 »
Or if you really want an IBM board that  will out live you, customized to some degree, bolt modded, extra set of black keycaps pm me then.
« Last Edit: Wed, 31 July 2013, 20:57:18 by bazemk1979 »
« Reply #25 on: Wed, 31 July 2013, 21:00:23 »
Why get a model M when you can get a model F?
« Reply #26 on: Wed, 31 July 2013, 21:10:38 »
Black keycaps?
Are they from Unicomp?
Offline 1391406
« Reply #27 on: Wed, 31 July 2013, 21:19:48 »
Model M's are far more available and less expensive, but I'd definitely recommend an AT Model F over a Model M to anyone that can afford it and runs across one.
Offline 1391406
« Reply #28 on: Wed, 31 July 2013, 21:30:31 »
I'm sure bolt modding can only help when needed, although I will say I've owned more than a few IBM Model M's (1391401) that were never bolt modded and worked fine with a Bluecube adapter straight up. Almost all of them (except for two) were eBay purchases. ANSI vs. ISO is obviously a personal preference.
Offline bazemk1979
« Reply #29 on: Wed, 31 July 2013, 22:37:38 »
Black keycaps?
yes
Offline TimIsABat
  • MX Clears are life
    • Instagram
« Reply #30 on: Wed, 31 July 2013, 23:57:08 »
since we are kinda on the topic. Do the Unicomp caps work on any Model M?
Leopold FC660M MX Reds | Poker X 62g  Ergoclear modded and plate modded (out of comission) | IBM Model M 1391401 | Dell AT101 | Compaq RT101 | HHKB Pro 2 | WASD CODE TKL MX Clears
Avid vape collector and advocate. I used to work at to renowned vape shops here in New Jersey. Message me for any vape related questions.
Main driver : WASD CODE TKL MX Clear
Offline 1391406
« Reply #31 on: Thu, 01 August 2013, 00:07:59 »
Check out this discussion.
Offline TimIsABat
    • Instagram
« Reply #32 on: Thu, 01 August 2013, 00:13:06 »
shpanks
Offline Hypersphere
« Reply #33 on: Thu, 01 August 2013, 13:26:24 »
Currently, the most consistently reliable source for IBM Model M keyboards is clickykeyboards.com.
Offline omegatony
« Reply #34 on: Thu, 01 August 2013, 14:27:32 »
Just received mine from there. They do a great job.
Edit: Anyone know where i can get the IBM Model M SSK? They are impossible to come across now.
« Last Edit: Thu, 01 August 2013, 14:29:36 by omegatony »
Realforce 87U | IBM M SSK | QFR
« Reply #35 on: Thu, 01 August 2013, 14:41:24 »
ebay
$150-200
at least once a month
Offline smknjoe
« Reply #36 on: Thu, 01 August 2013, 14:54:32 »
ebay
$150-200
Yeah, fohat is right. Just do a search for ibm ssk and then hit the Sold Items filter to see what they have gone for. There has been at least 15 or more sell in the last 3 months. Many more have come up on the market recently than I have seen in the past couple of years.
SSKs for everyone!
Offline omegatony
« Reply #37 on: Thu, 01 August 2013, 15:12:45 »
ebay
$150-200
I was watching one last night on eBay. Somebody bought it 3 mins before me for $250. If anyone knows somebody selling, give me a shout  ;D
Offline Toasty_Ohs
« Reply #38 on: Thu, 01 August 2013, 15:32:34 »
Had good luck with these guys on ebay:
http://myworld.ebay.com/itblowoutllc?_trksid=p2047675.l2559
Model M buy it now $50.
The first one I got did not work, I called them, they sent me an RMA and make a swap.  Best part, the keyboard was new in box when I opened it.
Using it right now in fact.
Offline smknjoe
« Reply #39 on: Thu, 01 August 2013, 15:33:44 »
Nice Toasty!
SSKs for everyone!
Offline omegatony
« Reply #40 on: Thu, 01 August 2013, 15:37:08 »
10/10 im jelly
What year is your Model M?
« Last Edit: Thu, 01 August 2013, 15:38:45 by omegatony »
Offline Jalberstone
« Reply #41 on: Thu, 01 August 2013, 15:51:55 »
What's the difference between a Model M and a Model F?
Offline omegatony
« Reply #42 on: Thu, 01 August 2013, 16:12:47 »
I believe the Model F has the Function keys on the left of the board. Very cool layout IMO
Offline 1391406
« Reply #43 on: Thu, 01 August 2013, 17:59:29 »
There are other differences in layout, but a big difference between the two is the switch design; Model M's use buckling spring over membrane, whereas Model F's use buckling spring over capacitive contacts. That said, there's a noticeable difference in feel between the two keyboards. Key strokes on a Model F feel lighter and more crisp to the touch when typing compared to Model M's. In fact, I've never read comments from anyone who has used both and prefers the typing experience of a Model M.
« Last Edit: Thu, 01 August 2013, 18:02:36 by 1391406 »
Offline omegatony
« Reply #44 on: Thu, 01 August 2013, 18:32:56 »
Very cool. I should try one out some day
Offline Jalberstone
« Reply #45 on: Sat, 03 August 2013, 20:40:29 »
I know you guys are probably going to hate me for asking this, but if I get a USB adapter, will it work on a mac?
« Reply #46 on: Sat, 03 August 2013, 21:15:42 »
I'm waiting to find this out myself - a SDL to USB adaptor is in the mail.  Then I can see if my second Model M works (on my Mac).
Following that I hope to get a PS/2 to USB adaptor so I can use my first Model M on my Mac and/or other computers.
Offline Jalberstone
« Reply #47 on: Sat, 03 August 2013, 21:48:02 »
When you get your adapter, please let me know how everything works out.
« Reply #48 on: Sat, 03 August 2013, 21:57:41 »
I might forget this thread, but I will post details to my Model M thread, so please feel free to subscribe to that and you should receive updates.
At the moment the project is on hold pending delivery of the SDL/USB cable.  Once that arrives, I will know how many keycap sets I need to order.
After that I might bolt mod one of them - see how it goes.
