Author Topic: Ducky Cherry MX Thick PBT Grey Keycaps  (Read 2828 times)
Offline jameslr
« on: Tue, 30 July 2013, 15:59:59 »
Found this on fleabay. Not a bad price considering it's not in stock anywhere. http://www.ebay.com/itm/NEW-Ducky-Grey-Cherry-MX-Thick-PBT-108-Count-Keyboard-Keycaps-Set-BrandNew-OEMs-/171090943541?pt=PCA_Mice_Trackballs&hash=item27d5d09e35
Edit: looks like these were pulled from a 9087G2Pro with the PBT caps.
« Last Edit: Tue, 30 July 2013, 16:02:35 by jameslr »
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
Offline missalaire
  • Great Finder of Great Finds
Re: Ducky Cherry MX Thick PBT Grey Keycaps
« Reply #1 on: Tue, 30 July 2013, 20:09:37 »
Not a great deal imo. If you really wanted the caps, you're better off buying the actual board from mechanicalkeyboards.com and selling the barebones board.
Offline jameslr
« Reply #2 on: Tue, 30 July 2013, 20:11:48 »
I was just going off what the other Thick PBT sets are going for (Feng's eBay), and these are $20 cheaper. If you don't want the hassle of dumping an additional board wouldn't these be the way to go?
Offline missalaire
« Reply #3 on: Tue, 30 July 2013, 20:28:31 »
It's still really not worth imo. They are awfully expensive for the PBT caps alone when you consider this:
The DK9008G2 Pro w/ ABS caps is just over $100.
If you bought the DK9008G2 Pro w/ PBT caps, you can probably sell the barebones board for around $100 (depending on the switches), which would make the PBT caps only cost you about $30-40ish.
