Author Topic: Closest replacement for a Magitronic FK-2000Plus?  (Read 1889 times)
Offline wendell
« on: Wed, 31 July 2013, 13:27:33 »
A long-time user of a Magitronic FK-2000Plus would like to replace it with a Windows/USB keyboard that feels exactly the same. The FK-2000Plus has Alps white clicky switches that I measured to have an average activation force of 57g.
I tried a keyboard with Cherry Blues, but they were too light and had a much less pronounced click. These Alps whites seem to be somewhere between the Blues and IBM buckling-springs in terms of the click.
I thought the Matias keyboards might be a good match, since the switches are supposed to be clones of the Alps, but I read that the weight feels much less than the intended 60g.
Any suggestions?
Re: Closest replacement for a Magitronic FK-2000Plus?
« Reply #1 on: Wed, 31 July 2013, 13:28:04 »
Get a Focus FK-2001?
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #2 on: Wed, 31 July 2013, 14:29:52 »
Uh, yeah. The FK-2000Plus is just a branded FK-2001 essentially.
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline wendell
« Reply #3 on: Wed, 31 July 2013, 15:38:19 »
Repeat: A USB keyboard with Windows keys
« Reply #4 on: Wed, 31 July 2013, 15:40:25 »
Buy a Matias board and a FK-2001, swap the clicky white switches into the Matias. Or if you can get your hands on a Filco Zero do that but those are super rare.
Offline esoomenona
  • Gnillort?
« Reply #5 on: Wed, 31 July 2013, 15:42:24 »
Or get a PS/2 to USB adapter.
« Reply #6 on: Wed, 31 July 2013, 15:44:18 »
I know its preference, but I dont think matias tactile switches are too far off white alps, so the swap might not even be necesary.
I say: buy the matias first, then a donor kb second if it's not close enough.
