Author Topic: Do you use an uncommon mx switch or modified switch?  (Read 7132 times)
Offline mtl
Re: Do you use an uncommon mx switch or modified switch?
« Reply #50 on: Sat, 03 August 2013, 23:41:24 »
Currently using linear stems with variable-force springs from brown, yellow and black switches.
Yellow switches?
Chinese Cherry clones...
http://imgur.com/a/7ujle#3
Yep.. Here's a potato pic.
MX13 SpaceSaver | Phantom | Tactoblack Filco -10 | Realforce 103U-UW | Variable Clicky Deck 82 | Deck Legend
Offline tribade
« Reply #51 on: Sat, 03 August 2013, 23:49:59 »
My KMAC Mini has 55g blacks.  I'm really loving them so far.  I don't think I've found a switch I don't like though.  I guess I'm just a little too undiscerning!
KMAC mini w/ blacks | Realforce 87uw 55g w/ Digil0g case | KMAC w/ blacks | Duck Viper w/ clears
"Te occidere possunt sed te edere non possunt nefas est."
Offline mtl
« Reply #52 on: Sun, 04 August 2013, 11:59:40 »
Right now I use a mix of:
Panda-Clears (Numrow, Shift, Tab, Caps, Enter)
65g-Clears (Index and Middlefinger keys)
62g-Clears (Pinky and Ringfinger keys)
Clears (Ctrl, Alt, Win, Menu, Esc)
Grey (Spacebar) atm.
Aka. The Ergo-Ergo-Clear Board, feels good man!
Cool! :)
 I plan to try some Originative springs on my next build, similar to yours but a bit lighter and with clicky stems.
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #53 on: Sun, 04 August 2013, 23:46:39 »
Cool! :)
Nice! Post some feedback about ya findings...
Probably gonna build a linear version as soon the GH60 PCBs arrive :)
A Ghost From The Past
