Author Topic: Do you use an uncommon mx switch or modified switch?  (Read 7130 times)
Offline phx
« on: Fri, 02 August 2013, 08:15:30 »
For mx users who arent using any of the common 4 (blue, brown, red, black), what are you using? Did you pick your current switch over a common one? If so, why? And if you are using a modified switch (lubed, spring/stem swap), why and would you recommend it to others?
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
Re: Do you use an uncommon mx switch or modified switch?
« Reply #1 on: Fri, 02 August 2013, 08:17:33 »
I'm using 62g whites because they're quieter than blues and a little bit heavier. I'd recommend it, still wanna try 62g clears though.
TOO BAD FOR YOU
              Phantom 62g MX Whites
« Reply #2 on: Fri, 02 August 2013, 08:17:58 »
I have a Pure with MX Whites, a KMAC with MX Greens, and my Epsilon will have 65g Blacks. I also plan on modifying the Pure to have MX Black springs and my Leopold to 65g Blues.
Why? I like those switches and how they feel.
« Reply #3 on: Fri, 02 August 2013, 08:21:19 »
I'm loving stock clear switches until I get my phantom and then I will be trying out some crazy options.
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #4 on: Fri, 02 August 2013, 08:23:34 »
I'd love to hear some opinions from 62g Clear users, I've got 100x coming in the post at the moment and I can't decide whether or not to mod them for my next project.
« Reply #5 on: Fri, 02 August 2013, 08:24:58 »
My thoughts on 62g Clears and other modded clears can be found here.
Offline Tarzan
  • formerly known as Greystoke
« Reply #6 on: Fri, 02 August 2013, 08:26:41 »
Typing this on a Ducky with MX Dark Greys.
The other keyboard I've been using at work has Marquardt switches.
I like the heavier switches, started with MX Green before I got tired of the clickiness.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #7 on: Fri, 02 August 2013, 08:28:01 »
Stock reds in my franken-dolch, but sticker, lubed, 55g clears in my poker
Offline phx
« Reply #8 on: Fri, 02 August 2013, 08:30:19 »
hmm... so far most of you seem to be fans of heavier switches, interesting...
I personally can't stand stiff switches.
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #9 on: Fri, 02 August 2013, 08:32:37 »
62g isn't heavy by far. It's a tad bit heavier than red, blue, or brown springs.
TOO BAD FOR YOU
Offline phx
« Reply #10 on: Fri, 02 August 2013, 08:34:12 »
yeah well, I find clears too heavy >.>
maybe I just have girly fingers with no strength.
« Reply #11 on: Fri, 02 August 2013, 08:35:24 »
I can't stand Reds or Browns and I didn't even bother reviewing 45g and 55g springs because those are way way way too light for me. I liked 62g springs but I like 65g spring more. But 62g and 65g fall between Reds/Browns/Blues and Black springs. For more indepth info, check out rkinze's amazing Spring Measurement thread.
Also your signature is hard to read on Nostalgia phx. Black text on black background :(
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #12 on: Fri, 02 August 2013, 08:35:41 »
That's because clears are heavy. They're one of the heaviest switches, which is why people mod them to lighter weights like 62g.
TOO BAD FOR YOU
Offline CommunistWitchDr
  • >implying keyboards
« Reply #13 on: Fri, 02 August 2013, 08:36:30 »
Stock clears - edox
Stock greens - qfr
Stock whites - not in board yet
« Reply #14 on: Fri, 02 August 2013, 08:39:44 »
I don't even notice  :-X
Offline phx
« Reply #15 on: Fri, 02 August 2013, 08:46:30 »
woah really?
is there a place that list what switch use what springs?
was thinking to making an ergo clear board
@CPTBadAss
screw you I'm using the old theme :p
(dont like changes...)
« Last Edit: Fri, 02 August 2013, 08:48:04 by phx »
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #16 on: Fri, 02 August 2013, 08:47:37 »
woah really?
@CPTBadAss
CPTBadAss' link will do you fine sir. http://geekhack.org/index.php?topic=46505.msg982589#msg982589
TOO BAD FOR YOU
Offline phx
« Reply #17 on: Fri, 02 August 2013, 08:50:05 »
wow nice.
I should try the 62g on brown/clear stem.
how many springs do you get from originative per pack?
« Last Edit: Fri, 02 August 2013, 08:51:53 by phx »
« Reply #18 on: Fri, 02 August 2013, 08:55:33 »
wow nice.
You do know brown and clear steams are different right?
and I'm thinking ~100 - 110 on the springs, have not received mine yet however
Offline phx
« Reply #19 on: Fri, 02 August 2013, 08:57:44 »
wow nice.
yep yep, clear has a more pronounced tactile feedback. I was planning on doing an ergo clear mod, was thinking maybe the 62g springs would be better since it's slightly heavier than mx light spring...
Offline MKULTRA
  • telling it how it is
« Reply #20 on: Fri, 02 August 2013, 09:06:02 »
65g clears lubed and stickered.
Offline ___q
« Reply #21 on: Fri, 02 August 2013, 09:53:07 »
I only own as many keyboards as I do because I wanted to try allllllllllllll the cherry switches...
I mostly stick with 62g clears and 62g blacks, though I like browns as well (though only at home -- work is 100% silenced 55g topre).
I haven't tried 65 or 67g clears, but I'm vaguely interested -- 62g feels a _little_ slow to bounce back (though they're still way nicer than stock clears).
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #22 on: Fri, 02 August 2013, 10:45:31 »
Using 80g blues, because I like the heavier feel, more stronger click, since i am using metal keycaps, they are heavier than normal keycaps so they reduce the "real" weight of stock springs.
This setup is the closest I have experienced MX to buckling spring, heavy, tactile and loud!
Offline yasuo
  • spanengan puyeng newbie
« Reply #23 on: Fri, 02 August 2013, 11:01:49 »
can post your keyboard dark grey in here.
what spring? spring stiff 80g like grey or stiff medium like green?
maybe it will be a navy blue, if using a stiff spring 80g (gray) :p
Logitech MK220 Colemak DH
Offline MOZ
  • Busy making stuff
« Reply #24 on: Fri, 02 August 2013, 11:17:52 »
Originative 80g.
Offline yasuo
« Reply #25 on: Fri, 02 August 2013, 11:29:47 »
mean ghetto green :-\
originative korean spring like 80g green spring,unfortunately not navt blue :(
Offline MOZ
  • Busy making stuff
« Reply #26 on: Fri, 02 August 2013, 11:35:08 »
Yes, ghetto green.
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
« Reply #27 on: Fri, 02 August 2013, 14:23:54 »
All of my boards have clears or blacks (and one 38GT with reds).  62g gold springs and vintage blacks are my favorite.  Lubed and stickered, as well.
Offline Photoelectric
« Reply #28 on: Fri, 02 August 2013, 14:38:18 »
I use modified MX Blues (Jailhouse Blues) with o-rings inside and 45g springs.  My absolute favorite, and nothing else comes close.  Also 62g ergo-Clears which I'm on the border about--somehow they feel too tough.  (Both fully lubricated).  I want to try them with stock 60g springs left over from Blues.
I prefer both to common MX switches.
« Reply #29 on: Fri, 02 August 2013, 15:12:05 »
Are you referring to the bottom out or the actuation force? The actuation force on blues is around 55g. The bottom out is around 60.
rkinze has a lovely article about this now. ^__^
« Reply #30 on: Fri, 02 August 2013, 15:35:09 »
Bottoming out, since I compared them to 62g Korean springs.  Hence the "stock 60g" from Blues.
Cool article!
Offline daerid
    • Rossipedia
« Reply #31 on: Fri, 02 August 2013, 15:42:17 »
65g Clears here.
Offline Lastpilot
  • Power stance
« Reply #32 on: Fri, 02 August 2013, 15:57:55 »
My next board will have 55g whites on them :D
I like stock whites a lot, but they are just a bit heavy for me.
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #33 on: Fri, 02 August 2013, 16:00:33 »
55g whites are EXTREMELY light. I prefer either 62 or 65g much more.
TOO BAD FOR YOU
Offline Leslieann
« Reply #34 on: Fri, 02 August 2013, 16:46:40 »
I'm using Jailhouse Blues.
Lubed, short throw blues, no click, with a 45gram actuation point.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #35 on: Fri, 02 August 2013, 16:52:10 »
62g blacks, lube'd and sticker'd.  The feel can't be beat.
Offline Dubsgalore
« Reply #36 on: Fri, 02 August 2013, 18:35:37 »
I use stock clears and stock blacks, but desperately want to play with different springs in my blacks
need to find my sweet spot before the gh60s drop
Offline dadgh
« Reply #37 on: Fri, 02 August 2013, 20:36:10 »
wow nice.
I got 102 in mine.
Offline Ellron
« Reply #38 on: Fri, 02 August 2013, 20:45:28 »
I use Cherry MX Blues for typing and gaming. I don't have any issues with double tapping them, but I know some people have, and it makes sense if you look at how the switch works. I tried reds and blacks, and compared to the blues, it was no contest in my mind.
I really want to try out the green ones, for a much heavier feel.
Offline AKIMbO
  • HHKBro
« Reply #39 on: Fri, 02 August 2013, 20:47:52 »
Uncommon...I use 55g silenced topres because I'm cool like that.
| KBD75 (box reds)
Offline Grimey
« Reply #40 on: Fri, 02 August 2013, 21:18:38 »
Blue stem + black spring on my poker at work.  Not terribly unusual of a combination, but it is quite satisfying.
Erlang your pants off
Offline WhiteFireDragon
    • youtube
« Reply #41 on: Sat, 03 August 2013, 00:17:05 »
50g lubed reds, and 45g mx whites
« Reply #42 on: Sat, 03 August 2013, 00:31:15 »
Is the click even more subdued on those whites?
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #43 on: Sat, 03 August 2013, 11:59:52 »
Right now I use a mix of:
Panda-Clears (Numrow, Shift, Tab, Caps, Enter)
65g-Clears (Index and Middlefinger keys)
62g-Clears (Pinky and Ringfinger keys)
Clears (Ctrl, Alt, Win, Menu, Esc)
Grey (Spacebar) atm.
Aka. The Ergo-Ergo-Clear Board, feels good man!
A Ghost From The Past
Offline mtl
« Reply #44 on: Sat, 03 August 2013, 20:46:24 »
Currently using linear stems with variable-force springs from brown, yellow and black switches.
MX13 SpaceSaver | Phantom | Tactoblack Filco -10 | Realforce 103U-UW | Variable Clicky Deck 82 | Deck Legend
« Reply #45 on: Sat, 03 August 2013, 21:26:17 »
Yellow switches?
  • ~ BOOO ~
« Reply #46 on: Sat, 03 August 2013, 21:32:23 »
Yellow switches?
Chinese Cherry clones...
http://imgur.com/a/7ujle#3
Offline inteli722
« Reply #47 on: Sat, 03 August 2013, 21:49:05 »
Using Greens here. I quite like them, though I guess they're less "uncommon" now that CoolerMaster is mass producing keyboards with them.
Waiting for: Phantom Plate
« Reply #48 on: Sat, 03 August 2013, 22:19:26 »
62g gold Clears only.
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #49 on: Sat, 03 August 2013, 23:12:14 »
I'm using MX Greens on a fullsized Ducky, which I like better than MX Blue, which felt far, far too light on my KBTalking keyboard. I have vintage MX Blacks on a G80-2100, which are linear, non-clicky which I did not expect to like, but they're actually really great to type on. The MX Greens were not nearly as "heavy" as they have been made out to be, and the clickiness is great.
Quote from: Samuel Adams
