Author Topic: Disabling the function layer on a KBC poker II  (Read 3636 times)
Offline jlebrech
« on: Fri, 02 August 2013, 10:14:26 »
Is there a way to disable the fn layer altogether on the kbc poker?
what about replacing the holtek chip? does it use a different chip to the kbc poker 1 and would that one have a better fn layer?
is there a programmable chip that i could replace it with and reprogram with usb?
Thanks.
Offline domoaligato
Re: Disabling the function layer on a KBC poker II
« Reply #1 on: Fri, 02 August 2013, 12:51:07 »
why would you want to disable the fn layer?
Offline esoomenona
  • Gnillort?
« Reply #2 on: Fri, 02 August 2013, 12:54:15 »
Remove the Fn switch?
Offline domoaligato
« Reply #3 on: Fri, 02 August 2013, 12:59:32 »
this is what I was thinking. but by doing this he would have a empty space because you can not attach a keycap without a switch.
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #4 on: Fri, 02 August 2013, 13:03:19 »
Remove the diode for the switch?
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline domoaligato
« Reply #5 on: Fri, 02 August 2013, 13:10:11 »
ding! ding! ding!
:( i need more caffeine.
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #6 on: Fri, 02 August 2013, 13:13:56 »
ding! ding! ding!
I need caffeine in general. Good thing drinks are free at work ;D
TOO BAD FOR YOU
Offline jlebrech
« Reply #7 on: Sat, 03 August 2013, 10:42:17 »
I want to change the PN key to be a "Hyper key", or just reprogram the function layer.
Maybe low profile mx keys would prevent accidently hitting an fn key, but I don't really want to activate a mode by accident, i'm fine with doing fn+another key (which is more purposeful)
but hitting a combo that put's it into a mode I don't have a clue off is a no-no.
maybe i got the wrong keyboard :D
i want to also disable the fn layer so that I can reprogram it in the OS to my liking. so some kind of no thrills replacement chip which just sends a keycode for each key would be cool.
« Last Edit: Sat, 03 August 2013, 10:44:31 by jlebrech »
