Author Topic: Model M Dampening  (Read 5346 times)
Offline nsrexler
Model M Dampening
« on: Sat, 03 August 2013, 20:48:00 »
I have a Unicomp Model M that I love, but I don't use it much anymore because it's just so damn loud. I tried the floss mod on it and ended up undoing it because it ruined the feel for me.
The other day I had the case open to clean the keyboard, and I happened to press on a few of the keys just playing around. I noticed that the sound was much quieter than normal, and, on top of that, seemed more precise. This leads me to believe a significant portion of the noise from the Model M comes from reverberation in the case. How can I fix this? Is there some sort of foam I can stuff inside the case to dampen the sound?
Offline rootwyrm
  • The Hands of Steel
    • My Website!
Re: Model M Dampening
« Reply #1 on: Sat, 03 August 2013, 21:23:54 »
You can use damping foam but don't confuse a genuine Model M with a Unicomp. Unicomp has changed the chassis molds and depending on model, designed their own. Any standard non-conductive noise reduction foam is fine, but it sounds a lot more like a lack of rigidity issue to me than anything else.
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline nsrexler
« Reply #2 on: Sun, 04 August 2013, 00:55:01 »
What would you recommend, then? I considered bolt-modding it, but all the rivets are still intact so I'm not sure that there would be significant benefit.
« Reply #3 on: Sun, 04 August 2013, 07:10:30 »
The floss mod is not as nice on a Model M as on an F, but it does not have to harm the action.
If the floss completely fills the spring, the effect is the greatest. Cutting it a little shorter, say, 2/3 to 3/4, will cut the noise almost as much and affect the action less (remember that it has to be more than 1/2 because that is where the spring actually buckles!).
Packing the cavities with soft fluff of some sort will help, but running something like duct tape or rubber cement on the inside of the case will deaden the actual vibrations of the "sounding board" itself.
- Oliver Willis 2026-08-01
Offline TimIsABat
  • MX Clears are life
    • Instagram
« Reply #4 on: Sun, 04 August 2013, 09:25:32 »
You can do this on the original model Ms too? I am getting one soon and if I decide its too loud, I would want to dampen it.
Leopold FC660M MX Reds | Poker X 62g  Ergoclear modded and plate modded (out of comission) | IBM Model M 1391401 | Dell AT101 | Compaq RT101 | HHKB Pro 2 | WASD CODE TKL MX Clears
Avid vape collector and advocate. I used to work at to renowned vape shops here in New Jersey. Message me for any vape related questions.
Main driver : WASD CODE TKL MX Clear
Offline nsrexler
« Reply #5 on: Sun, 04 August 2013, 11:40:42 »
Can you elaborate on this? Where should I apply the duct tape to get the best effect?
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #6 on: Sun, 04 August 2013, 12:04:14 »
never heard of running a little duct tape on the inside, but it sure makes since. did you do this on a model m and where inside?
my f has a pretty pronounced ping at times and i would assume it would do the same........
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
« Reply #7 on: Sun, 04 August 2013, 12:57:39 »
Personally, I have not yet used duct tape, but intend to try it the next time I get into it. I plan to cut rubber strips and sandwich them in with duct tape.
I have used black electrician's friction tape to good effect, and have painted the inside of cases with "rubber paint" of various types. I thought that each made very small, but noticeable improvements.
Just packing the voids can help a fair bit, but have not decided whether I prefer "fluff" like pillow stuffing that just takes up space, or something like foam rubber that exerts forces outwards from itself.
I will focus my next experiments on deadening the resonance of the hard surfaces themselves.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #8 on: Sun, 04 August 2013, 13:13:01 »
keep us posted..........
thanks :thumb:
Offline nsrexler
« Reply #9 on: Sun, 04 August 2013, 22:28:52 »
Alright, well I guess I'll go to the hardware/crafts store and get a couple of different materials and see what works.
Offline Techno Trousers
  • ʘ_ಠ
« Reply #10 on: Mon, 05 August 2013, 01:11:56 »
Has anyone tried one of the automotive sound deadener products like Dynamat? Seems like that might be the ultimate resonance reducer, although it's pretty pricey.
Offline Tarzan
  • formerly known as Greystoke
« Reply #11 on: Mon, 05 August 2013, 10:13:32 »
I was thinking of trying that as well.  Dynamat comes in sheets, but IIRC correctly, they also have a pourable version.
Looks like you can get a 18" x 32" sheet of their thinner version (1/8"?) for $26.00 shipped CONUS.
http://www.amazon.com/Dynamat-10425-Self-Adhesive-Deadener-Xtreme/dp/B00020CAVA/ref=pd_sbs_auto_7
I was amused by this comment, though:
It does have one drawback, and that's the fact that once you stick it on something, you will not be able to get it off without making a big mess. It is essentially tar with a foil outer cover, and trying to get it off just leaves a bunch of sticky tar behind. So, choose the place you want it carefully before sticking it down!
 :p
  • ʘ_ಠ
« Reply #12 on: Mon, 05 August 2013, 11:29:16 »
Yeah, definitely not a reversible process! If you try it, please post a review.
Offline 0100010
  • Not Sure
« Reply #13 on: Mon, 05 August 2013, 19:17:13 »
In my younger years when I used to upgrade the audio systems in my cars, we used a product just like Dynamat, but it was significantly less expensive called RAAM audio mat (though I'm not sure it is any less expensive anymore).
But I don't think I would recommend it for use in a Model M - you would pretty much destroy it inside.  Same goes for something like expanding foam - unless you had the packing version that was contained within its own plastic bag.
You'd probably be better off with felt or maybe drawer liner.  Never really thought about quieting down my daily driver before, the only people it would bother is whoever comes to bug me in my office.
« Reply #14 on: Mon, 05 August 2013, 20:20:20 »
I have used both and like them a lot. The rubber "waffle" drawer liner is a great mat for the board to sit on the desk - non-slip and dampening too.
