Author Topic: Does anyone still use SysRq?  (Read 2128 times)
Offline 1391406
« on: Mon, 05 August 2013, 10:12:54 »
Other than the Magic SysRq key(in Linux), does anyone really use it anymore?
Offline esoomenona
  • Gnillort?
Re: Does anyone still use SysRq?
« Reply #1 on: Mon, 05 August 2013, 10:14:56 »
I use it to grab a Print Screen grab, but even that is becoming obsolete with the Snipping Tool...
Offline 1391406
« Reply #2 on: Mon, 05 August 2013, 10:25:23 »
Print Screen is somewhat useful on occasion, in my opinion, but I wonder if SysRq (which, I believe, was invoked using Alt+SysRq) has any real usefulness at all anymore, though, or if manufacturers can safely expunge that print from keyboards altogether now?
Offline esoomenona
  • Gnillort?
« Reply #3 on: Mon, 05 August 2013, 10:27:04 »
To be quite honest, I had no idea what it did, and I imagine many others don't either. That was the point of my post. I think you're right in your thought that it serves no real purpose anymore...
Offline EDI
« Reply #4 on: Mon, 05 August 2013, 10:32:14 »
In modern Windows environment, the SysRq key (alt+print screen) behaves almost same as the normal printscreen.
However instead of taking screen capture from whole monitor, it only captures the current active window.
Other than that, the SysRq key has no use in Windows environment.
